Computer hangs when using Optimus manager to switch between Intel/Nvidia/Hybrid
Hello all.
This is not a big problem, more of an annoyance.
So recently I set up optimus-manager, three times (I was changing DE at the time so no worries) and I have discovered that while changing between Intel/Nvidia/Hybrid on Gnome, my computer freezes before getting into the login screen again.
I did not experience this on KDE or XFCE DE, but somehow Gnome has really grown on me (considering I really dis-liked it to begin with).
The switching "does work" if I change the start-up mode in the optimus settings and restart the computer, but it is kind of an extra step.
I used this guide to get optimus settings working. Now, I have noticed some differences between the guide and my system in general. First of all, I had no graphical files in /etc/X11/xorg.conf.d/ before starting the process of setting up optimus (this was different on both KDE and XFCE). I am guessing that is not very important. Currently there are only 2 files in that folder, 00-keyboard.conf and 10-optimus-manager.conf. Don't know if that is relevant or not.
I was also going to have steam use the graphic card natively, but in the guide the location of steam.conf is in ~/.local/share/application/ while on my computer that file is literally in /olividir/desktop. Again, not sure if that is relevant or not.
Now, like I said, this is more of an annoyance than a deal breaker, but it would be nice to have it working properly. I know this is work in progress.
My inxi
  Host: HP Kernel: 5.7.0-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  Desktop: Gnome 3.36.3 Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
  date: 04/21/2020
  ID-1: BAT1 charge: 37.3 Wh condition: 37.3/52.8 Wh (71%)
  model: Hewlett-Packard PABAS0241231 status: Full
  Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 8192 KiB
  bogomips: 36812
  Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 440.82 bus ID: 01:00.0
  Display: x11 server: X.org 1.20.8 driver: nvidia
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.0.7
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  Sound Server: ALSA v: k5.7.0-3-MANJARO
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_pci v: N/A port: 4000 bus ID: 02:00.0
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  Local Storage: total: 1.60 TiB used: 428.56 GiB (26.2%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
  ID-2: /dev/sda type: USB vendor: Toshiba model: External USB 3.0
  ID-3: /dev/sdb type: USB vendor: Western Digital
  model: WD My Passport 0740 size: 465.73 GiB
  ID-1: / size: 233.43 GiB used: 65.14 GiB (27.9%) fs: ext4
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 54.0 C mobo: 29.8 C
  Processes: 357 Uptime: 1h 15m Memory: 15.53 GiB used: 4.93 GiB (31.7%)
  Init: systemd Compilers: gcc: 10.1.0 Shell: zsh v: 5.8 inxi: 3.0.37
If you are trying to use prime
(I dont remember if optimus-manager uses bumblebee too, or what)
Then you shouldnt be on i915 for the intel.
intel+nvidia prime can only be used if the intel is using modesetting driver.
(for bumblebee i915 is fine .. but bumblebee is not the preferred method)
What do you have installed in mhwd?
mhwd -li
I did not install bumblebee, and according to the guide, it is not recommended.
~ >>> mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-intel-nvidia-440xx-prime            2019.10.25               false            PCI
Either remove video-linux or install video-modesetting
Will do when I get home from work.
If you switched to Gnome and GDM, you need to switch to gdm-prime and edit the file /etc/gdm/custom.conf, remove the # before the line #WaylandEnable=false.
Even then GDM is often problematic with optimus-manager. Let me quote documentation:
Another quirk of GDM is that the X server may not automatically restart after a GPU switch. If you see an empty black screen or a black screen with a blinking cursor, try switching back to an empty TTY (with Ctrl+Alt+F5 for instance), then back to TTY1 with Ctrl+Alt+F1. See this FAQ question.
Freezes probably indicate some DM problems, so you need to check your DM logs after switch attempt:
journalctl -u gdm.service
By the way, you can still use SDDM for Gnome if you like, it's not like you are stuck with GDM.
Sorry, but I am not sure what GDM is. Is that something I need to install?
Will check how to switch to it when I get home and try your solution.
It's the Gnome Display Manager. If your profile info is correct and you are in fact using KDE, you probably are using Simple Desktop Display Manager (SDDM).
I am not using KDE, I am using GNOME, might have mixed up my inxi, sorry about that.
Nope, my bad. I did not see your inxi, just went with the info from your forum profile.
Ok, tried that, did not work, still get stuck on black screen, but Ctrl + Alt + F5 and then Ctrl + Alt + F1 got it going again, thanks for that @michaldybczak, however, I have already un-commented WaylandEnable=false.
~ >>> journalctl -u gdm.service
-- Logs begin at Sun 2020-06-14 18:21:52 GMT, end at Mon 2020-06-29 19:23:02 GM>
jún 14 18:21:55 HP systemd[1]: Starting GNOME Display Manager...
jún 14 18:21:55 HP systemd[1]: Started GNOME Display Manager.
jún 14 18:22:07 HP gdm-password][1380]: gkr-pam: unable to locate daemon contro>
jún 14 18:22:07 HP gdm-password][1380]: gkr-pam: stashed password to try later >
jún 14 18:22:07 HP gdm-password][1380]: pam_unix(gdm-password:session): session>
jún 14 18:22:07 HP gdm-password][1380]: gkr-pam: gnome-keyring-daemon started p>
jún 14 18:33:45 HP gdm[834]: Tried to look up non-existent conversation gdm-lau>
jún 14 18:33:45 HP gdm[834]: Freeing conversation 'gdm-launch-environment' with>
jún 14 18:33:45 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 18:33:45 HP gdm[834]: Failed to contact accountsservice: Error calling S>
jún 14 18:33:45 HP gdm[834]: Freeing conversation 'gdm-password' with active job
jún 14 18:33:45 HP systemd[1]: gdm.service: Succeeded.
jún 14 18:33:45 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 18:34:07 HP systemd[1]: Starting GNOME Display Manager...
jún 14 18:34:07 HP systemd[1]: Started GNOME Display Manager.
jún 14 18:34:22 HP gdm-password][1434]: gkr-pam: unable to locate daemon contro>
jún 14 18:34:22 HP gdm-password][1434]: gkr-pam: stashed password to try later >
jún 14 18:34:22 HP gdm-password][1434]: pam_unix(gdm-password:session): session>
jún 14 18:34:23 HP gdm-password][1434]: gkr-pam: gnome-keyring-daemon started p>
jún 14 18:34:26 HP gdm[711]: Child process -1091 was already dead.
jún 14 18:46:45 HP systemd[1]: Stopping GNOME Display Manager...
I'll update my profile info :slight_smile:
DM is short for Display Manager - it's a thing that starts either X or Wayland graphical session. When it fails, there is no graphical session, only tty mode (like on server).
Each major DE has its own DM, so KDE has SDDM, Gnome has GDM. There are others like LightDM and more.
When you switched to Gnome, you had probably some instruction how to switch DMs from SDDM to GDM, it needs activation, if you just installed Gnome yourself parallel to Plasma. If you installed it from install disk, then it was all done for you.
The instruction for optimus-manager was to use a fork of GDM, because the default GDM is missing some small functionality, hence the need to install gdm-prime from AUR. Then, you check the config and edit it as showed. Then, maybe it is needed to activate or actually enable GDM again, although I suspect it should swap the default GDM and services should be intact. But if the uninstallation is disabling services, you need to enable it. Check out Arch wiki for info how to swap DMs. If you fail at that, your graphical session won't start and you end up in black screen and tty only mode.
You need to understand how this all works before trying to use optimus-manager.
As to your log, your lines are cut off when the terminal window is not maximized. So check out the log again, maximize window and copy it again. Or simpler, make the output be saved into text file:
journalctl -u gdm.service>gdm.log
Then post it here.
Unfortunately, DM logs are not always clear. Sometimes they help and show the issue, oftentimes they are cryptic. GDM is often at fault here, so I can't promise to solve your issue even if you post the whole GDM log, but we can at least try. Another bad thing about GDM is, that it often doesn't work well with optimus-manager, even if you change it to gdm-prime.
I made the log.
I guess installing gdm-prime is in the tutorial, because it is already installed. and it seems like I have done all the steps beforehand.
Just to let you know, I made a clean install when I went from KDE to GNOME. So I suspect GDM being installed for me from that.
I knew optimus can be buggy, and if it is not possible to solve this, then I will live with it. Not the biggest problem in the world. But if it is possible to fix this, I would be very glad.
Thank you for the help.
-- Logs begin at Sun 2020-06-14 18:21:52 GMT, end at Mon 2020-06-29 20:55:08 GMT. --
jún 14 18:22:07 HP gdm-password][1380]: gkr-pam: unable to locate daemon control file
jún 14 18:22:07 HP gdm-password][1380]: gkr-pam: stashed password to try later in open session
jún 14 18:22:07 HP gdm-password][1380]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 18:22:07 HP gdm-password][1380]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 18:33:45 HP gdm[834]: Tried to look up non-existent conversation gdm-launch-environment
jún 14 18:33:45 HP gdm[834]: Freeing conversation 'gdm-launch-environment' with active job
jún 14 18:33:45 HP gdm[834]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
-- Reboot --
jún 14 18:34:22 HP gdm-password][1434]: gkr-pam: unable to locate daemon control file
jún 14 18:34:22 HP gdm-password][1434]: gkr-pam: stashed password to try later in open session
jún 14 18:34:22 HP gdm-password][1434]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 18:34:23 HP gdm-password][1434]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 18:46:45 HP gdm[711]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 14 18:46:46 HP gdm[711]: Freeing conversation 'gdm-password' with active job
jún 14 18:46:46 HP systemd[1]: gdm.service: Succeeded.
jún 14 18:46:46 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 18:47:19 HP systemd[1]: Starting GNOME Display Manager...
jún 14 18:47:19 HP systemd[1]: Started GNOME Display Manager.
jún 14 18:48:41 HP gdm-password][1422]: gkr-pam: unable to locate daemon control file
jún 14 18:48:41 HP gdm-password][1422]: gkr-pam: stashed password to try later in open session
jún 14 18:48:41 HP gdm-password][1422]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 18:48:41 HP gdm-password][1422]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 18:54:16 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 18:54:16 HP gdm[879]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 14 18:54:16 HP gdm[879]: Freeing conversation 'gdm-password' with active job
jún 14 18:54:16 HP gdm[879]: Tried to look up non-existent conversation gdm-launch-environment
jún 14 18:54:16 HP gdm[879]: Freeing conversation 'gdm-launch-environment' with active job
jún 14 18:54:16 HP gdm[879]: Child process -1070 was already dead.
jún 14 18:54:16 HP systemd[1]: gdm.service: Succeeded.
jún 14 18:54:16 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 18:54:38 HP systemd[1]: Starting GNOME Display Manager...
jún 14 18:54:38 HP systemd[1]: Started GNOME Display Manager.
jún 14 18:54:46 HP gdm-password][1386]: gkr-pam: unable to locate daemon control file
jún 14 18:54:46 HP gdm-password][1386]: gkr-pam: stashed password to try later in open session
jún 14 18:54:46 HP gdm-password][1386]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 18:54:47 HP gdm-password][1386]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 18:59:06 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 18:59:07 HP gdm[1057]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 14 18:59:07 HP gdm[1057]: GLib: g_hash_table_foreach: assertion 'version == hash_table->version' failed
jún 14 18:59:07 HP systemd[1]: gdm.service: Succeeded.
jún 14 18:59:07 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 18:59:27 HP systemd[1]: Starting GNOME Display Manager...
jún 14 18:59:27 HP systemd[1]: Started GNOME Display Manager.
jún 14 18:59:38 HP gdm-password][1369]: gkr-pam: unable to locate daemon control file
jún 14 18:59:38 HP gdm-password][1369]: gkr-pam: stashed password to try later in open session
jún 14 18:59:38 HP gdm-password][1369]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 18:59:38 HP gdm-password][1369]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 19:01:02 HP gdm[2366]: [6] INFO: # Xorg pre-start hook
jún 14 19:01:02 HP gdm[2366]: [6] INFO: Requested mode is: hybrid
jún 14 19:01:02 HP gdm[2366]: [6] INFO: Checking for GDM display servers
jún 14 19:01:02 HP gdm[2366]: [26] INFO: Found a Xorg GDM process (PID 1070), killing it...
jún 14 19:01:02 HP gdm[2366]: [209] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
jún 14 19:01:02 HP gdm[2366]: [209] INFO: Unloading modules ['nouveau'] (if loaded)
jún 14 19:01:02 HP gdm[2366]: [239] INFO: Loading module nvidia
jún 14 19:01:02 HP gdm[2366]: [468] INFO: Loading module nvidia_drm
jún 14 19:01:04 HP gdm[2366]: [2269] INFO: Loaded extra Intel Xorg options (0 lines)
jún 14 19:01:04 HP gdm[2366]: [2270] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
jún 14 19:01:04 HP gdm[2366]: [2270] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20200614T190102', 'requested_mode': 'hybrid'}
jún 14 19:01:04 HP gdm[2366]: [2270] INFO: Xorg pre-start hook completed successfully.
jún 14 19:02:33 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 19:02:33 HP systemd[1]: gdm.service: Succeeded.
jún 14 19:02:33 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 19:02:55 HP systemd[1]: Starting GNOME Display Manager...
jún 14 19:02:55 HP systemd[1]: Started GNOME Display Manager.
jún 14 19:03:05 HP gdm-password][1366]: gkr-pam: unable to locate daemon control file
jún 14 19:03:05 HP gdm-password][1366]: gkr-pam: stashed password to try later in open session
jún 14 19:03:05 HP gdm-password][1366]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 19:03:05 HP gdm-password][1366]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 19:03:29 HP gdm[1952]: [6] INFO: # Xorg pre-start hook
jún 14 19:03:29 HP gdm[1952]: [6] INFO: Requested mode is: hybrid
jún 14 19:03:29 HP gdm[1952]: [6] INFO: Checking for GDM display servers
jún 14 19:03:29 HP gdm[1952]: [25] INFO: Found a Xorg GDM process (PID 952), killing it...
jún 14 19:03:29 HP gdm[1952]: [205] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
jún 14 19:03:29 HP gdm[1952]: [205] INFO: Unloading modules ['nouveau'] (if loaded)
jún 14 19:03:29 HP gdm[1952]: [237] INFO: Loading module nvidia
jún 14 19:03:30 HP gdm[1952]: [465] INFO: Loading module nvidia_drm
jún 14 19:03:31 HP gdm[1952]: [2260] INFO: Loaded extra Intel Xorg options (0 lines)
jún 14 19:03:31 HP gdm[1952]: [2261] INFO: Loaded extra Intel Xorg options (0 lines)
jún 14 19:03:31 HP gdm[1952]: [2261] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
jún 14 19:03:31 HP gdm[1952]: [2261] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20200614T190329', 'requested_mode': 'hybrid'}
jún 14 19:03:31 HP gdm[1952]: [2261] INFO: Xorg pre-start hook completed successfully.
jún 14 19:04:41 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 19:04:41 HP systemd[1]: gdm.service: Succeeded.
jún 14 19:04:41 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 19:05:02 HP systemd[1]: Starting GNOME Display Manager...
jún 14 19:05:02 HP systemd[1]: Started GNOME Display Manager.
jún 14 19:05:12 HP gdm-password][1367]: gkr-pam: unable to locate daemon control file
jún 14 19:05:12 HP gdm-password][1367]: gkr-pam: stashed password to try later in open session
jún 14 19:05:12 HP gdm-password][1367]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 19:05:12 HP gdm-password][1367]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 19:06:37 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 19:06:37 HP gdm[738]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 14 19:06:37 HP gdm[738]: Freeing conversation 'gdm-password' with active job
jún 14 19:06:37 HP gdm[738]: Tried to look up non-existent conversation gdm-launch-environment
jún 14 19:06:37 HP gdm[738]: Freeing conversation 'gdm-launch-environment' with active job
jún 14 19:06:37 HP gdm[738]: Child process -1078 was already dead.
jún 14 19:06:37 HP systemd[1]: gdm.service: Succeeded.
jún 14 19:06:37 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 14 19:07:00 HP systemd[1]: Starting GNOME Display Manager...
jún 14 19:07:00 HP systemd[1]: Started GNOME Display Manager.
jún 14 19:07:13 HP gdm-password][1382]: gkr-pam: unable to locate daemon control file
jún 14 19:07:13 HP gdm-password][1382]: gkr-pam: stashed password to try later in open session
jún 14 19:07:13 HP gdm-password][1382]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 14 19:07:13 HP gdm-password][1382]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 14 23:39:27 HP systemd[1]: Stopping GNOME Display Manager...
jún 14 23:39:27 HP gdm[1070]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 14 23:39:27 HP gdm[1070]: Freeing conversation 'gdm-password' with active job
jún 14 23:39:27 HP gdm[1070]: Tried to look up non-existent conversation gdm-launch-environment
jún 14 23:39:27 HP gdm[1070]: Child process -1092 was already dead.
jún 14 23:39:27 HP gdm[1070]: Freeing conversation 'gdm-launch-environment' with active job
jún 14 23:39:28 HP gdm[1070]: Child process -1092 was already dead.
jún 14 23:39:28 HP systemd[1]: gdm.service: Succeeded.
jún 14 23:39:28 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 15 17:40:46 HP systemd[1]: Starting GNOME Display Manager...
jún 15 17:40:46 HP systemd[1]: Started GNOME Display Manager.
jún 15 17:40:58 HP gdm-password][6774]: gkr-pam: unable to locate daemon control file
jún 15 17:40:58 HP gdm-password][6774]: gkr-pam: stashed password to try later in open session
jún 15 17:40:58 HP gdm-password][6774]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 15 17:40:58 HP gdm-password][6774]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 15 22:57:15 HP systemd[1]: Stopping GNOME Display Manager...
jún 15 22:57:15 HP gdm[2798]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 15 22:57:16 HP gdm[2798]: Freeing conversation 'gdm-password' with active job
jún 15 22:57:16 HP gdm[2798]: Tried to look up non-existent conversation gdm-launch-environment
jún 15 22:57:16 HP gdm[2798]: Freeing conversation 'gdm-launch-environment' with active job
jún 15 22:57:16 HP gdm[2798]: Child process -2932 was already dead.
jún 15 22:57:16 HP systemd[1]: gdm.service: Succeeded.
jún 15 22:57:16 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 16 07:01:16 HP systemd[1]: Starting GNOME Display Manager...
jún 16 07:01:16 HP systemd[1]: Started GNOME Display Manager.
jún 16 07:01:33 HP gdm-password][1778]: gkr-pam: unable to locate daemon control file
jún 16 07:01:33 HP gdm-password][1778]: gkr-pam: stashed password to try later in open session
jún 16 07:01:33 HP gdm-password][1778]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 16 07:01:33 HP gdm-password][1778]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 16 07:43:37 HP systemd[1]: Stopping GNOME Display Manager...
jún 16 07:43:38 HP gdm[1439]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 16 07:43:38 HP gdm[1439]: Freeing conversation 'gdm-password' with active job
jún 16 07:43:38 HP gdm[1439]: Tried to look up non-existent conversation gdm-launch-environment
jún 16 07:43:38 HP gdm[1439]: Freeing conversation 'gdm-launch-environment' with active job
jún 16 07:43:38 HP gdm[1439]: Child process -1461 was already dead.
jún 16 07:43:38 HP systemd[1]: gdm.service: Succeeded.
jún 16 07:43:38 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 16 18:57:24 HP systemd[1]: Starting GNOME Display Manager...
jún 16 18:57:24 HP systemd[1]: Started GNOME Display Manager.
jún 16 18:57:34 HP gdm-password][1719]: gkr-pam: unable to locate daemon control file
jún 16 18:57:34 HP gdm-password][1719]: gkr-pam: stashed password to try later in open session
jún 16 18:57:34 HP gdm-password][1719]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 16 18:57:34 HP gdm-password][1719]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 16 23:23:18 HP gdm[1393]: Tried to look up non-existent conversation gdm-launch-environment
jún 16 23:23:18 HP systemd[1]: Stopping GNOME Display Manager...
jún 16 23:23:18 HP gdm[1393]: Freeing conversation 'gdm-launch-environment' with active job
jún 16 23:23:18 HP gdm[1393]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 16 23:23:18 HP gdm[1393]: Freeing conversation 'gdm-password' with active job
jún 16 23:23:19 HP gdm[1393]: Child process -1415 was already dead.
jún 16 23:23:19 HP systemd[1]: gdm.service: Succeeded.
jún 16 23:23:19 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 17 08:55:34 HP systemd[1]: Starting GNOME Display Manager...
jún 17 08:55:34 HP systemd[1]: Started GNOME Display Manager.
jún 17 08:56:21 HP gdm-password][1779]: gkr-pam: unable to locate daemon control file
jún 17 08:56:21 HP gdm-password][1779]: gkr-pam: stashed password to try later in open session
jún 17 08:56:21 HP gdm-password][1779]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 17 08:56:21 HP gdm-password][1779]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 17 17:48:31 HP gdm[13510]: [6] INFO: # Xorg pre-start hook
jún 17 17:48:31 HP gdm[13510]: [6] INFO: Requested mode is: nvidia
jún 17 17:48:31 HP gdm[13510]: [6] INFO: Checking for GDM display servers
jún 17 17:48:31 HP gdm[13510]: [25] INFO: Found a Xorg GDM process (PID 1425), killing it...
jún 17 17:48:31 HP gdm[13510]: [45] INFO: Loaded extra Intel Xorg options (0 lines)
jún 17 17:48:31 HP gdm[13510]: [46] INFO: Loaded extra Intel Xorg options (0 lines)
jún 17 17:48:31 HP gdm[13510]: [46] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
jún 17 17:48:31 HP gdm[13510]: [46] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20200617T174831', 'requested_mode': 'nvidia'}
jún 17 17:48:31 HP gdm[13510]: [46] INFO: Xorg pre-start hook completed successfully.
jún 17 17:48:52 HP systemd[1]: Stopping GNOME Display Manager...
jún 17 17:48:52 HP systemd[1]: gdm.service: Succeeded.
jún 17 17:48:52 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 17 17:49:29 HP systemd[1]: Starting GNOME Display Manager...
jún 17 17:49:29 HP systemd[1]: Started GNOME Display Manager.
jún 17 17:49:38 HP gdm-password][1724]: gkr-pam: unable to locate daemon control file
jún 17 17:49:38 HP gdm-password][1724]: gkr-pam: stashed password to try later in open session
jún 17 17:49:38 HP gdm-password][1724]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 17 17:49:38 HP gdm-password][1724]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 17 17:50:05 HP systemd[1]: Stopping GNOME Display Manager...
jún 17 17:50:05 HP gdm[1394]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 17 17:50:05 HP gdm[1394]: Freeing conversation 'gdm-password' with active job
jún 17 17:50:05 HP gdm[1394]: Tried to look up non-existent conversation gdm-launch-environment
jún 17 17:50:05 HP gdm[1394]: Freeing conversation 'gdm-launch-environment' with active job
jún 17 17:50:05 HP gdm[1394]: Child process -1416 was already dead.
jún 17 17:50:05 HP systemd[1]: gdm.service: Succeeded.
jún 17 17:50:05 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 17 17:50:38 HP systemd[1]: Starting GNOME Display Manager...
jún 17 17:50:38 HP systemd[1]: Started GNOME Display Manager.
jún 17 17:50:50 HP gdm-password][1708]: gkr-pam: unable to locate daemon control file
jún 17 17:50:50 HP gdm-password][1708]: gkr-pam: stashed password to try later in open session
jún 17 17:50:50 HP gdm-password][1708]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 17 17:50:50 HP gdm-password][1708]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 17 22:46:55 HP systemd[1]: Stopping GNOME Display Manager...
jún 17 22:46:56 HP gdm[1390]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 17 22:46:56 HP gdm[1390]: Freeing conversation 'gdm-password' with active job
jún 17 22:46:56 HP gdm[1390]: Tried to look up non-existent conversation gdm-launch-environment
jún 17 22:46:56 HP gdm[1390]: Freeing conversation 'gdm-launch-environment' with active job
jún 17 22:46:56 HP gdm[1390]: Child process -1412 was already dead.
jún 17 22:46:56 HP systemd[1]: gdm.service: Succeeded.
jún 17 22:46:56 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 18 06:52:54 HP systemd[1]: Starting GNOME Display Manager...
jún 18 06:52:54 HP systemd[1]: Started GNOME Display Manager.
jún 18 06:53:09 HP gdm-password][1790]: gkr-pam: unable to locate daemon control file
jún 18 06:53:09 HP gdm-password][1790]: gkr-pam: stashed password to try later in open session
jún 18 06:53:09 HP gdm-password][1790]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 18 06:53:09 HP gdm-password][1790]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 18 07:48:08 HP systemd[1]: Stopping GNOME Display Manager...
jún 18 07:48:08 HP gdm[1458]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 18 07:48:08 HP gdm[1458]: Freeing conversation 'gdm-password' with active job
jún 18 07:48:08 HP gdm[1458]: Tried to look up non-existent conversation gdm-launch-environment
jún 18 07:48:09 HP gdm[1458]: Freeing conversation 'gdm-launch-environment' with active job
jún 18 07:48:09 HP gdm[1458]: Child process -1480 was already dead.
jún 18 07:48:09 HP systemd[1]: gdm.service: Succeeded.
jún 18 07:48:09 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 18 19:21:43 HP systemd[1]: Starting GNOME Display Manager...
jún 18 19:21:43 HP systemd[1]: Started GNOME Display Manager.
jún 18 19:22:04 HP gdm-password][1736]: gkr-pam: unable to locate daemon control file
jún 18 19:22:04 HP gdm-password][1736]: gkr-pam: stashed password to try later in open session
jún 18 19:22:04 HP gdm-password][1736]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 18 19:22:04 HP gdm-password][1736]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 18 22:58:17 HP systemd[1]: Stopping GNOME Display Manager...
jún 18 22:58:17 HP gdm[1401]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 18 22:58:17 HP gdm[1401]: Freeing conversation 'gdm-password' with active job
jún 18 22:58:17 HP gdm[1401]: Tried to look up non-existent conversation gdm-launch-environment
jún 18 22:58:18 HP gdm[1401]: Freeing conversation 'gdm-launch-environment' with active job
jún 18 22:58:18 HP gdm[1401]: Child process -1423 was already dead.
jún 18 22:58:18 HP systemd[1]: gdm.service: Succeeded.
jún 18 22:58:18 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 19 06:36:12 HP systemd[1]: Starting GNOME Display Manager...
jún 19 06:36:12 HP systemd[1]: Started GNOME Display Manager.
jún 19 06:36:27 HP gdm-password][1738]: gkr-pam: unable to locate daemon control file
jún 19 06:36:27 HP gdm-password][1738]: gkr-pam: stashed password to try later in open session
jún 19 06:36:27 HP gdm-password][1738]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 19 06:36:28 HP gdm-password][1738]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 19 07:46:35 HP gdm[1409]: Tried to look up non-existent conversation gdm-launch-environment
jún 19 07:46:36 HP systemd[1]: Stopping GNOME Display Manager...
jún 19 07:46:36 HP gdm[1409]: Freeing conversation 'gdm-launch-environment' with active job
jún 19 07:46:36 HP gdm[1409]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 19 07:46:36 HP gdm[1409]: Freeing conversation 'gdm-password' with active job
jún 19 07:46:36 HP gdm[1409]: Child process -1431 was already dead.
jún 19 07:46:37 HP systemd[1]: gdm.service: Succeeded.
jún 19 07:46:37 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 19 17:34:55 HP systemd[1]: Starting GNOME Display Manager...
jún 19 17:34:55 HP systemd[1]: Started GNOME Display Manager.
jún 19 17:35:12 HP gdm-password][1738]: gkr-pam: unable to locate daemon control file
jún 19 17:35:12 HP gdm-password][1738]: gkr-pam: stashed password to try later in open session
jún 19 17:35:12 HP gdm-password][1738]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 19 17:35:12 HP gdm-password][1738]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 20 00:09:18 HP gdm[1405]: Tried to look up non-existent conversation gdm-launch-environment
jún 20 00:09:18 HP systemd[1]: Stopping GNOME Display Manager...
jún 20 00:09:19 HP gdm[1405]: Freeing conversation 'gdm-launch-environment' with active job
jún 20 00:09:19 HP gdm[1405]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 20 00:09:19 HP gdm[1405]: Freeing conversation 'gdm-password' with active job
jún 20 00:09:19 HP gdm[1405]: Child process -1427 was already dead.
jún 20 00:09:19 HP systemd[1]: gdm.service: Succeeded.
jún 20 00:09:19 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 20 06:58:23 HP systemd[1]: Starting GNOME Display Manager...
jún 20 06:58:23 HP systemd[1]: Started GNOME Display Manager.
jún 20 06:58:36 HP gdm-password][1808]: gkr-pam: unable to locate daemon control file
jún 20 06:58:36 HP gdm-password][1808]: gkr-pam: stashed password to try later in open session
jún 20 06:58:36 HP gdm-password][1808]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 20 06:58:37 HP gdm-password][1808]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 20 09:45:44 HP gdm[1478]: Tried to look up non-existent conversation gdm-launch-environment
jún 20 09:45:44 HP systemd[1]: Stopping GNOME Display Manager...
jún 20 09:45:44 HP gdm[1478]: Freeing conversation 'gdm-launch-environment' with active job
jún 20 09:45:44 HP gdm[1478]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 20 09:45:44 HP gdm[1478]: Freeing conversation 'gdm-password' with active job
jún 20 09:45:45 HP gdm[1478]: Child process -1500 was already dead.
jún 20 09:45:45 HP systemd[1]: gdm.service: Succeeded.
jún 20 09:45:45 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 20 16:46:39 HP systemd[1]: Starting GNOME Display Manager...
jún 20 16:46:39 HP systemd[1]: Started GNOME Display Manager.
jún 20 16:46:48 HP gdm-password][1836]: gkr-pam: unable to locate daemon control file
jún 20 16:46:48 HP gdm-password][1836]: gkr-pam: stashed password to try later in open session
jún 20 16:46:48 HP gdm-password][1836]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 20 16:46:48 HP gdm-password][1836]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 20 22:27:54 HP gdm[1505]: Tried to look up non-existent conversation gdm-launch-environment
jún 20 22:27:54 HP systemd[1]: Stopping GNOME Display Manager...
jún 20 22:27:54 HP gdm[1505]: Freeing conversation 'gdm-launch-environment' with active job
jún 20 22:27:54 HP gdm[1505]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 20 22:27:54 HP gdm[1505]: Freeing conversation 'gdm-password' with active job
jún 20 22:27:54 HP gdm[1505]: Child process -1527 was already dead.
jún 20 22:27:55 HP systemd[1]: gdm.service: Succeeded.
jún 20 22:27:55 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 21 09:14:45 HP systemd[1]: Starting GNOME Display Manager...
jún 21 09:14:45 HP systemd[1]: Started GNOME Display Manager.
jún 21 09:14:56 HP gdm-password][1810]: gkr-pam: unable to locate daemon control file
jún 21 09:14:56 HP gdm-password][1810]: gkr-pam: stashed password to try later in open session
jún 21 09:14:56 HP gdm-password][1810]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 21 09:14:57 HP gdm-password][1810]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 21 18:44:11 HP gdm[1480]: GLib: Source ID 73 was not found when attempting to remove it
jún 21 23:35:00 HP systemd[1]: Stopping GNOME Display Manager...
jún 21 23:35:00 HP gdm[1480]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 21 23:35:00 HP gdm[1480]: Freeing conversation 'gdm-password' with active job
jún 21 23:35:00 HP gdm[1480]: Tried to look up non-existent conversation gdm-launch-environment
jún 21 23:35:00 HP gdm[1480]: Freeing conversation 'gdm-launch-environment' with active job
jún 21 23:35:01 HP gdm[1480]: Child process -1502 was already dead.
jún 21 23:35:01 HP systemd[1]: gdm.service: Succeeded.
jún 21 23:35:01 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 22 07:06:24 HP systemd[1]: Starting GNOME Display Manager...
jún 22 07:06:24 HP systemd[1]: Started GNOME Display Manager.
jún 22 07:06:39 HP gdm-password][1854]: gkr-pam: unable to locate daemon control file
jún 22 07:06:39 HP gdm-password][1854]: gkr-pam: stashed password to try later in open session
jún 22 07:06:39 HP gdm-password][1854]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 22 07:06:39 HP gdm-password][1854]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 22 07:46:46 HP systemd[1]: Stopping GNOME Display Manager...
jún 22 07:46:46 HP gdm[1522]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 22 07:46:46 HP gdm[1522]: Freeing conversation 'gdm-password' with active job
jún 22 07:46:46 HP gdm[1522]: Tried to look up non-existent conversation gdm-launch-environment
jún 22 07:46:46 HP gdm[1522]: Freeing conversation 'gdm-launch-environment' with active job
jún 22 07:46:46 HP gdm[1522]: Child process -1544 was already dead.
jún 22 07:46:47 HP systemd[1]: gdm.service: Succeeded.
jún 22 07:46:47 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 22 19:04:08 HP systemd[1]: Starting GNOME Display Manager...
jún 22 19:04:08 HP systemd[1]: Started GNOME Display Manager.
jún 22 19:05:27 HP gdm-password][1837]: gkr-pam: unable to locate daemon control file
jún 22 19:05:27 HP gdm-password][1837]: gkr-pam: stashed password to try later in open session
jún 22 19:05:27 HP gdm-password][1837]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 22 19:05:27 HP gdm-password][1837]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 22 21:56:55 HP systemd[1]: Stopping GNOME Display Manager...
jún 22 21:56:55 HP gdm[1457]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 22 21:56:55 HP gdm[1457]: Freeing conversation 'gdm-password' with active job
jún 22 21:56:55 HP gdm[1457]: Tried to look up non-existent conversation gdm-launch-environment
jún 22 21:56:55 HP gdm[1457]: Freeing conversation 'gdm-launch-environment' with active job
jún 22 21:56:56 HP gdm[1457]: Child process -1479 was already dead.
jún 22 21:56:56 HP systemd[1]: gdm.service: Succeeded.
jún 22 21:56:56 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 23 06:57:11 HP systemd[1]: Starting GNOME Display Manager...
jún 23 06:57:11 HP systemd[1]: Started GNOME Display Manager.
jún 23 06:57:24 HP gdm-password][1796]: gkr-pam: unable to locate daemon control file
jún 23 06:57:24 HP gdm-password][1796]: gkr-pam: stashed password to try later in open session
jún 23 06:57:24 HP gdm-password][1796]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 23 06:57:24 HP gdm-password][1796]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 23 07:26:23 HP systemd[1]: Stopping GNOME Display Manager...
jún 23 07:26:23 HP gdm[1465]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 23 07:26:23 HP gdm[1465]: Freeing conversation 'gdm-password' with active job
jún 23 07:26:23 HP gdm[1465]: Tried to look up non-existent conversation gdm-launch-environment
jún 23 07:26:24 HP gdm[1465]: Freeing conversation 'gdm-launch-environment' with active job
jún 23 07:26:24 HP gdm[1465]: Child process -1487 was already dead.
jún 23 07:26:24 HP systemd[1]: gdm.service: Succeeded.
jún 23 07:26:24 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 23 17:37:55 HP systemd[1]: Starting GNOME Display Manager...
jún 23 17:37:55 HP systemd[1]: Started GNOME Display Manager.
jún 23 17:38:10 HP gdm-password][1779]: gkr-pam: unable to locate daemon control file
jún 23 17:38:10 HP gdm-password][1779]: gkr-pam: stashed password to try later in open session
jún 23 17:38:10 HP gdm-password][1779]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 23 17:38:10 HP gdm-password][1779]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 23 19:48:51 HP systemd[1]: Stopping GNOME Display Manager...
jún 23 19:48:51 HP gdm[1450]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 23 19:48:51 HP gdm[1450]: Freeing conversation 'gdm-password' with active job
jún 23 19:48:51 HP gdm[1450]: Tried to look up non-existent conversation gdm-launch-environment
jún 23 19:48:51 HP gdm[1450]: Freeing conversation 'gdm-launch-environment' with active job
jún 23 19:48:51 HP gdm[1450]: Child process -1472 was already dead.
jún 23 19:48:51 HP systemd[1]: gdm.service: Succeeded.
jún 23 19:48:51 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 23 19:49:30 HP systemd[1]: Starting GNOME Display Manager...
jún 23 19:49:30 HP systemd[1]: Started GNOME Display Manager.
jún 23 19:49:51 HP gdm-password][1788]: gkr-pam: unable to locate daemon control file
jún 23 19:49:51 HP gdm-password][1788]: gkr-pam: stashed password to try later in open session
jún 23 19:49:51 HP gdm-password][1788]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 23 19:49:51 HP gdm-password][1788]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 23 21:35:02 HP gdm[1457]: Tried to look up non-existent conversation gdm-launch-environment
jún 23 21:35:02 HP systemd[1]: Stopping GNOME Display Manager...
jún 23 21:35:02 HP gdm[1457]: Freeing conversation 'gdm-launch-environment' with active job
jún 23 21:35:02 HP gdm[1457]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 23 21:35:02 HP gdm[1457]: Freeing conversation 'gdm-password' with active job
jún 23 21:35:02 HP gdm[1457]: Child process -1479 was already dead.
jún 23 21:35:03 HP systemd[1]: gdm.service: Succeeded.
jún 23 21:35:03 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 23 21:35:37 HP systemd[1]: Starting GNOME Display Manager...
jún 23 21:35:37 HP systemd[1]: Started GNOME Display Manager.
jún 23 21:35:47 HP gdm-password][1799]: gkr-pam: unable to locate daemon control file
jún 23 21:35:47 HP gdm-password][1799]: gkr-pam: stashed password to try later in open session
jún 23 21:35:47 HP gdm-password][1799]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 23 21:35:47 HP gdm-password][1799]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 23 22:07:32 HP gdm[1471]: Tried to look up non-existent conversation gdm-launch-environment
jún 23 22:07:32 HP systemd[1]: Stopping GNOME Display Manager...
jún 23 22:07:32 HP gdm[1471]: Freeing conversation 'gdm-launch-environment' with active job
jún 23 22:07:32 HP gdm[1471]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 23 22:07:32 HP gdm[1471]: Freeing conversation 'gdm-password' with active job
jún 23 22:07:32 HP gdm[1471]: Child process -1493 was already dead.
jún 23 22:07:33 HP systemd[1]: gdm.service: Succeeded.
jún 23 22:07:33 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 24 06:36:30 HP systemd[1]: Starting GNOME Display Manager...
jún 24 06:36:30 HP systemd[1]: Started GNOME Display Manager.
jún 24 06:37:37 HP gdm-password][1850]: gkr-pam: unable to locate daemon control file
jún 24 06:37:37 HP gdm-password][1850]: gkr-pam: stashed password to try later in open session
jún 24 06:37:37 HP gdm-password][1850]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 24 06:37:37 HP gdm-password][1850]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 24 07:41:48 HP gdm[1471]: Tried to look up non-existent conversation gdm-launch-environment
jún 24 07:41:48 HP systemd[1]: Stopping GNOME Display Manager...
jún 24 07:41:48 HP gdm[1471]: Freeing conversation 'gdm-launch-environment' with active job
jún 24 07:41:48 HP gdm[1471]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 24 07:41:48 HP gdm[1471]: Freeing conversation 'gdm-password' with active job
jún 24 07:41:49 HP gdm[1471]: Child process -1493 was already dead.
jún 24 07:41:49 HP systemd[1]: gdm.service: Succeeded.
jún 24 07:41:49 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 24 17:41:27 HP systemd[1]: Starting GNOME Display Manager...
jún 24 17:41:27 HP systemd[1]: Started GNOME Display Manager.
jún 24 17:41:52 HP gdm-password][1827]: gkr-pam: unable to locate daemon control file
jún 24 17:41:52 HP gdm-password][1827]: gkr-pam: stashed password to try later in open session
jún 24 17:41:52 HP gdm-password][1827]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 24 17:41:53 HP gdm-password][1827]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 24 23:40:59 HP systemd[1]: Stopping GNOME Display Manager...
jún 24 23:40:59 HP gdm[1475]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 24 23:41:00 HP gdm[1475]: Freeing conversation 'gdm-password' with active job
jún 24 23:41:00 HP gdm[1475]: Tried to look up non-existent conversation gdm-launch-environment
jún 24 23:41:00 HP gdm[1475]: Freeing conversation 'gdm-launch-environment' with active job
jún 24 23:41:00 HP gdm[1475]: Child process -1497 was already dead.
jún 24 23:41:00 HP systemd[1]: gdm.service: Succeeded.
jún 24 23:41:00 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 25 07:01:50 HP systemd[1]: Starting GNOME Display Manager...
jún 25 07:01:50 HP systemd[1]: Started GNOME Display Manager.
jún 25 07:02:04 HP gdm-password][1821]: gkr-pam: unable to locate daemon control file
jún 25 07:02:04 HP gdm-password][1821]: gkr-pam: stashed password to try later in open session
jún 25 07:02:04 HP gdm-password][1821]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 25 07:02:04 HP gdm-password][1821]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 25 07:40:14 HP systemd[1]: Stopping GNOME Display Manager...
jún 25 07:40:14 HP gdm[1492]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 25 07:40:14 HP gdm[1492]: Freeing conversation 'gdm-password' with active job
jún 25 07:40:14 HP gdm[1492]: Tried to look up non-existent conversation gdm-launch-environment
jún 25 07:40:14 HP gdm[1492]: Freeing conversation 'gdm-launch-environment' with active job
jún 25 07:40:14 HP gdm[1492]: Child process -1514 was already dead.
jún 25 07:40:14 HP systemd[1]: gdm.service: Succeeded.
jún 25 07:40:14 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 25 17:51:58 HP systemd[1]: Starting GNOME Display Manager...
jún 25 17:51:58 HP systemd[1]: Started GNOME Display Manager.
jún 25 17:52:12 HP gdm-password][1819]: gkr-pam: unable to locate daemon control file
jún 25 17:52:12 HP gdm-password][1819]: gkr-pam: stashed password to try later in open session
jún 25 17:52:12 HP gdm-password][1819]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 25 17:52:12 HP gdm-password][1819]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 25 22:58:22 HP systemd[1]: Stopping GNOME Display Manager...
jún 25 22:58:23 HP gdm[1490]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 25 22:58:23 HP gdm[1490]: Freeing conversation 'gdm-password' with active job
jún 25 22:58:23 HP gdm[1490]: Tried to look up non-existent conversation gdm-launch-environment
jún 25 22:58:23 HP gdm[1490]: Freeing conversation 'gdm-launch-environment' with active job
jún 25 22:58:23 HP gdm[1490]: Child process -1512 was already dead.
jún 25 22:58:23 HP systemd[1]: gdm.service: Succeeded.
jún 25 22:58:23 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 26 06:47:24 HP systemd[1]: Starting GNOME Display Manager...
jún 26 06:47:24 HP systemd[1]: Started GNOME Display Manager.
jún 26 06:47:35 HP gdm-password][1844]: gkr-pam: unable to locate daemon control file
jún 26 06:47:35 HP gdm-password][1844]: gkr-pam: stashed password to try later in open session
jún 26 06:47:35 HP gdm-password][1844]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 26 06:47:35 HP gdm-password][1844]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 26 07:40:11 HP systemd[1]: Stopping GNOME Display Manager...
jún 26 07:40:11 HP gdm[1516]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 26 07:40:11 HP gdm[1516]: Freeing conversation 'gdm-password' with active job
jún 26 07:40:11 HP gdm[1516]: Tried to look up non-existent conversation gdm-launch-environment
jún 26 07:40:11 HP gdm[1516]: Freeing conversation 'gdm-launch-environment' with active job
jún 26 07:40:12 HP gdm[1516]: Child process -1538 was already dead.
jún 26 07:40:12 HP systemd[1]: gdm.service: Succeeded.
jún 26 07:40:12 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 26 20:10:04 HP systemd[1]: Starting GNOME Display Manager...
jún 26 20:10:04 HP systemd[1]: Started GNOME Display Manager.
jún 26 20:10:13 HP gdm-password][1823]: gkr-pam: unable to locate daemon control file
jún 26 20:10:13 HP gdm-password][1823]: gkr-pam: stashed password to try later in open session
jún 26 20:10:13 HP gdm-password][1823]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 26 20:10:13 HP gdm-password][1823]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 27 00:27:43 HP systemd[1]: Stopping GNOME Display Manager...
jún 27 00:27:43 HP gdm[1489]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 27 00:27:43 HP gdm[1489]: Freeing conversation 'gdm-password' with active job
jún 27 00:27:43 HP gdm[1489]: Tried to look up non-existent conversation gdm-launch-environment
jún 27 00:27:43 HP gdm[1489]: Freeing conversation 'gdm-launch-environment' with active job
jún 27 00:27:44 HP gdm[1489]: Child process -1511 was already dead.
jún 27 00:27:44 HP systemd[1]: gdm.service: Succeeded.
jún 27 00:27:44 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 27 08:36:35 HP systemd[1]: Starting GNOME Display Manager...
jún 27 08:36:35 HP systemd[1]: Started GNOME Display Manager.
jún 27 08:36:44 HP gdm-password][1787]: gkr-pam: unable to locate daemon control file
jún 27 08:36:44 HP gdm-password][1787]: gkr-pam: stashed password to try later in open session
jún 27 08:36:44 HP gdm-password][1787]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 27 08:36:45 HP gdm-password][1787]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 27 10:49:42 HP gdm[1456]: Tried to look up non-existent conversation gdm-launch-environment
jún 27 10:49:42 HP systemd[1]: Stopping GNOME Display Manager...
jún 27 10:49:42 HP gdm[1456]: Freeing conversation 'gdm-launch-environment' with active job
jún 27 10:49:43 HP gdm[1456]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 27 10:49:43 HP gdm[1456]: Freeing conversation 'gdm-password' with active job
jún 27 10:49:43 HP gdm[1456]: Child process -1478 was already dead.
jún 27 10:49:43 HP systemd[1]: gdm.service: Succeeded.
jún 27 10:49:43 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 27 17:01:56 HP systemd[1]: Starting GNOME Display Manager...
jún 27 17:01:56 HP systemd[1]: Started GNOME Display Manager.
jún 27 17:02:09 HP gdm-password][1819]: gkr-pam: unable to locate daemon control file
jún 27 17:02:09 HP gdm-password][1819]: gkr-pam: stashed password to try later in open session
jún 27 17:02:09 HP gdm-password][1819]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 27 17:02:09 HP gdm-password][1819]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 27 20:38:46 HP gdm[1491]: GLib: Source ID 68 was not found when attempting to remove it
jún 28 00:32:24 HP gdm[1491]: Tried to look up non-existent conversation gdm-launch-environment
jún 28 00:32:24 HP systemd[1]: Stopping GNOME Display Manager...
jún 28 00:32:24 HP gdm[1491]: Freeing conversation 'gdm-launch-environment' with active job
jún 28 00:32:24 HP gdm[1491]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 28 00:32:24 HP gdm[1491]: Freeing conversation 'gdm-password' with active job
jún 28 00:32:24 HP gdm[1491]: Child process -1513 was already dead.
jún 28 00:32:25 HP systemd[1]: gdm.service: Succeeded.
jún 28 00:32:25 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 28 08:43:41 HP systemd[1]: Starting GNOME Display Manager...
jún 28 08:43:41 HP systemd[1]: Started GNOME Display Manager.
jún 28 08:43:52 HP gdm-password][1822]: gkr-pam: unable to locate daemon control file
jún 28 08:43:52 HP gdm-password][1822]: gkr-pam: stashed password to try later in open session
jún 28 08:43:52 HP gdm-password][1822]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 28 08:43:53 HP gdm-password][1822]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 28 12:12:39 HP systemd[1]: Stopping GNOME Display Manager...
jún 28 12:12:39 HP gdm[1493]: Tried to look up non-existent conversation gdm-launch-environment
jún 28 12:12:39 HP gdm[1493]: Freeing conversation 'gdm-launch-environment' with active job
jún 28 12:12:39 HP gdm[1493]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 28 12:12:40 HP gdm[1493]: Freeing conversation 'gdm-password' with active job
jún 28 12:12:40 HP gdm[1493]: Child process -1516 was already dead.
jún 28 12:12:40 HP systemd[1]: gdm.service: Succeeded.
jún 28 12:12:40 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 28 17:05:10 HP systemd[1]: Starting GNOME Display Manager...
jún 28 17:05:10 HP systemd[1]: Started GNOME Display Manager.
jún 28 17:05:34 HP gdm-password][1850]: gkr-pam: unable to locate daemon control file
jún 28 17:05:34 HP gdm-password][1850]: gkr-pam: stashed password to try later in open session
jún 28 17:05:34 HP gdm-password][1850]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 28 17:05:34 HP gdm-password][1850]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 28 22:22:28 HP gdm[20632]: [6] INFO: # Xorg pre-start hook
jún 28 22:22:28 HP gdm[20632]: [6] INFO: Requested mode is: nvidia
jún 28 22:22:28 HP gdm[20632]: [6] INFO: Checking for GDM display servers
jún 28 22:22:28 HP gdm[20632]: [35] INFO: Found a Xorg GDM process (PID 1526), killing it...
jún 28 22:22:28 HP gdm[20632]: [56] INFO: Loaded extra Intel Xorg options (0 lines)
jún 28 22:22:28 HP gdm[20632]: [57] INFO: Loaded extra Intel Xorg options (0 lines)
jún 28 22:22:28 HP gdm[20632]: [57] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
jún 28 22:22:28 HP gdm[20632]: [57] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20200628T222228', 'requested_mode': 'nvidia'}
jún 28 22:22:28 HP gdm[20632]: [57] INFO: Xorg pre-start hook completed successfully.
jún 28 22:23:03 HP systemd[1]: Stopping GNOME Display Manager...
jún 28 22:23:03 HP systemd[1]: gdm.service: Succeeded.
jún 28 22:23:03 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 28 22:23:35 HP systemd[1]: Starting GNOME Display Manager...
jún 28 22:23:35 HP systemd[1]: Started GNOME Display Manager.
jún 28 22:23:44 HP gdm-password][1852]: gkr-pam: unable to locate daemon control file
jún 28 22:23:44 HP gdm-password][1852]: gkr-pam: stashed password to try later in open session
jún 28 22:23:44 HP gdm-password][1852]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 28 22:23:44 HP gdm-password][1852]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 28 23:14:49 HP systemd[1]: Stopping GNOME Display Manager...
jún 28 23:14:49 HP gdm[1510]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 28 23:14:49 HP gdm[1510]: Freeing conversation 'gdm-password' with active job
jún 28 23:14:49 HP gdm[1510]: Tried to look up non-existent conversation gdm-launch-environment
jún 28 23:14:49 HP gdm[1510]: Freeing conversation 'gdm-launch-environment' with active job
jún 28 23:14:49 HP gdm[1510]: Child process -1532 was already dead.
jún 28 23:14:49 HP systemd[1]: gdm.service: Succeeded.
jún 28 23:14:49 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 29 07:46:23 HP systemd[1]: Starting GNOME Display Manager...
jún 29 07:46:23 HP systemd[1]: Started GNOME Display Manager.
jún 29 07:46:33 HP gdm-password][1879]: gkr-pam: unable to locate daemon control file
jún 29 07:46:33 HP gdm-password][1879]: gkr-pam: stashed password to try later in open session
jún 29 07:46:33 HP gdm-password][1879]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 29 07:46:33 HP gdm-password][1879]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 29 07:53:27 HP gdm[1545]: Tried to look up non-existent conversation gdm-launch-environment
jún 29 07:53:27 HP systemd[1]: Stopping GNOME Display Manager...
jún 29 07:53:27 HP gdm[1545]: Freeing conversation 'gdm-launch-environment' with active job
jún 29 07:53:27 HP gdm[1545]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 29 07:53:27 HP gdm[1545]: Freeing conversation 'gdm-password' with active job
jún 29 07:53:27 HP gdm[1545]: Child process -1567 was already dead.
jún 29 07:53:28 HP systemd[1]: gdm.service: Succeeded.
jún 29 07:53:28 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 29 19:07:06 HP systemd[1]: Starting GNOME Display Manager...
jún 29 19:07:06 HP systemd[1]: Started GNOME Display Manager.
jún 29 19:07:21 HP gdm-password][1874]: gkr-pam: unable to locate daemon control file
jún 29 19:07:21 HP gdm-password][1874]: gkr-pam: stashed password to try later in open session
jún 29 19:07:21 HP gdm-password][1874]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 29 19:07:21 HP gdm-password][1874]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 29 19:18:33 HP gdm[1539]: Tried to look up non-existent conversation gdm-launch-environment
jún 29 19:18:33 HP systemd[1]: Stopping GNOME Display Manager...
jún 29 19:18:34 HP gdm[1539]: Freeing conversation 'gdm-launch-environment' with active job
jún 29 19:18:34 HP gdm[1539]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
jún 29 19:18:34 HP gdm[1539]: Freeing conversation 'gdm-password' with active job
jún 29 19:18:34 HP gdm[1539]: Child process -1561 was already dead.
jún 29 19:18:34 HP systemd[1]: gdm.service: Succeeded.
jún 29 19:18:34 HP systemd[1]: Stopped GNOME Display Manager.
-- Reboot --
jún 29 19:19:04 HP systemd[1]: Starting GNOME Display Manager...
jún 29 19:19:04 HP systemd[1]: Started GNOME Display Manager.
jún 29 19:19:20 HP gdm-password][1851]: gkr-pam: unable to locate daemon control file
jún 29 19:19:20 HP gdm-password][1851]: gkr-pam: stashed password to try later in open session
jún 29 19:19:20 HP gdm-password][1851]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 29 19:19:20 HP gdm-password][1851]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
jún 29 19:19:43 HP gdm[2586]: [6] INFO: # Xorg pre-start hook
jún 29 19:19:43 HP gdm[2586]: [6] INFO: Requested mode is: nvidia
jún 29 19:19:43 HP gdm[2586]: [6] INFO: Checking for GDM display servers
jún 29 19:19:43 HP gdm[2586]: [27] INFO: Found a Xorg GDM process (PID 1538), killing it...
jún 29 19:19:44 HP gdm[2586]: [49] INFO: Loaded extra Intel Xorg options (0 lines)
jún 29 19:19:44 HP gdm[2586]: [50] INFO: Loaded extra Intel Xorg options (0 lines)
jún 29 19:19:44 HP gdm[2586]: [50] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
jún 29 19:19:44 HP gdm[2586]: [50] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20200629T191943', 'requested_mode': 'nvidia'}
jún 29 19:19:44 HP gdm[2586]: [51] INFO: Xorg pre-start hook completed successfully.
jún 29 19:21:36 HP gdm-password][2897]: gkr-pam: unable to locate daemon control file
jún 29 19:21:36 HP gdm-password][2897]: gkr-pam: stashed password to try later in open session
jún 29 19:21:36 HP gdm-password][2897]: pam_unix(gdm-password:session): session opened for user olividir by (uid=0)
jún 29 19:21:37 HP gdm-password][2897]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
lines 620-674/674 (END)
Your issue isnt some sort of inherent problem.
Its configuration+tool (optimus-manager)
If you just wanted to use it regular (using PRIME) then you would default to the intel and run things on the nvidia using prime-run.
But you want to use optimus-manager which is a bit different than the regular setup.
And add on top of that you dont have a 'clean' install as you converted KDE to Gnome.
And add to that you are not very familiar with any of the above things...
its not some inherent problem.
I did not "convert" KDE to gnome, I did a clean install of gnome (erased the disk and installed gnome). I don't know how that misunderstanding became to surface. I honestly don't know how to convert any other way than clean install.
But I will try prime-run or just switch between TTY to get it to work.
Anyway, thanks for the help.
If you are OK with the normal setup then you should probably undo everything you did up until now, force reinstall the intel-nvidia-prime profile through mhwd .. and again I will mention that nvidia-prime does not work with intel i915 driver. It must be modesetting.
But once that is all 'normal' then yes its simple .. everything uses intel.
When you want nvidia use prime-run
(note in the case of steam use game launch options and set to prime-run %command%)
https://wiki.manjaro.org/index.php?title=Configure_Graphics_Cards
No need to undo anything because I haven't done anything (except remove video-linux). Have rebooted, played a game. Everything works fine, except needing to empty TTY and back again.
Hope optimus project will continue and developed further. This setup works a lot better for me than PRIME with Nvidia, see this link
And just to be clear, I made a clean install after trying Prime (everything deleted and set up again).
What do you mean? ... from that post:
check your setup like:
inxi -G && prime-run inxi -G
I mean that I get better GPU performance with optimus (at least that is what it feels like).
~ >>> inxi -G && prime-run inxi -G
  Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 440.82
  Display: x11 server: X.org 1.20.8 driver: nvidia
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.0.7
  OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82
Have to admit that I didn't notice I was running i915 driver, will fix that after work today.
