Constant freezing after latest update
issue
Recently after upgrading to the newest version of Manjaro (20.0.3), every single time I use my laptop, when I adjust the brightness or use google chrome, KDE just freezes, then my mouse stops working. The keyboard still works and I can open a terminal with ctrl+alt+t but strangely the terminal prompt doesn't show up. This has worsened to the point where it is unusable. I may have to switch back to Windows due to my urgent need of the laptop. Please advise on what I should do now. Thanks!
system info
System:    Host: surface Kernel: 5.7.9-arch1-1-surface x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-linux-surface root=UUID=5702874d-3a61-47d1-9b54-4b02fdb09435 rw quiet
           resume=UUID=7a2f5ee6-3150-456f-8a81-6e8fd16312de udev.log_priority=3
           Desktop: KDE Plasma 5.19.3 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Microsoft product: Surface Laptop 2
           v: 124000000000000000000000D:F B:0CA56289 F:U C:0A P:C1 S:01 serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Microsoft model: Surface Laptop 2 serial: <filter> UEFI: Microsoft v: 138.3193.768 date: 03.25.2020
Battery:   ID-1: BAT1 charge: 38.6 Wh condition: 41.1/45.2 Wh (91%) volts: 8.4/7.6 model: DYN M1005922 type: Li-ion
           serial: <filter> status: Discharging cycles: 285
CPU:       Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
           stepping: A (10) microcode: D6 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
           Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 799 8: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Microsoft driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
           Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
           tty: N/A
           OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.3 direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging Unit driver: ipu3-imgu bus ID: 00:05.0
           chip ID: 8086:1919
           Device-2: Intel driver: ipu3-cio2 bus ID: 00:14.3 chip ID: 8086:9d32
           Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
           Sound Server: ALSA v: k5.7.9-arch1-1-surface
Network:   Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie v: 1.0 port: 3000 bus ID: 02:00.0
           chip ID: 11ab:2b38
           Device-2: Marvell Bluetooth and Wireless LAN Composite Device type: USB driver: btusb bus ID: 1-5:2
           chip ID: 1286:204c serial: <filter>
Drives:    Local Storage: total: 119.24 GiB used: 11.85 GiB (9.9%)
           ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 119.24 GiB block size: physical: 512 B logical: 512 B
           speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: ADMS0101 scheme: GPT
Partition: ID-1: / raw size: 110.15 GiB size: 107.92 GiB (97.98%) used: 11.85 GiB (11.0%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default) cache pressure: 100 (default)
           dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 38.0 C mobo: N/A
Info:      Processes: 229 Uptime: 12m Memory: 7.70 GiB used: 1.43 GiB (18.6%) Init: systemd v: 245 Compilers: gcc: 10.1.0
           Shell: zsh v: 5.8 running in: alacritty inxi: 3.0.37
Maybe uninstall random?
:woman_shrugging:
Oh I see. a 'surface' kernel ..
What package is that exactly?
Have you tried with other kernels ?
It looks like you arent using a manjaro kernel.
What did you install, how, why ?
Have you tried booting a different kernel, such as a regular manjaro kernel ?
I am using the linux surface kernel. I've tried booting the stock manjaro kernel too but the problem was still there. I have also tried downgrading the kernel to linux-54 but the problem still existed. Seems like this isn't a kernel issue after all.
journalctl -xb -p3
Might tell us more .. or maybe checking something like htop system monitor while using.
journalctl output:
-- Logs begin at Wed 2020-07-22 13:42:36 +08, end at Thu 2020-07-23 20:01:20 +08. --
Jul 23 19:59:58 surface kernel: Bluetooth: hci0: unexpected event for opcode 0x0000
Jul 23 20:00:05 surface kded5[1041]: org.kde.plasma.dataengine.geolocation: error:  "Unknown host location.services.mozilla.com: Host not found"
Jul 23 20:00:05 surface bluetoothd[885]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Jul 23 20:00:05 surface bluetoothd[885]: RFCOMM server failed for :1.56/Profile/HSPHS/00001108-0000-1000-8000-00805F9B34FB: rfcomm_bind: Address already in use (98)
This is not an initrd build by Manajro.
What branch are you using? Even if you are using unstable branch - then using a kernel build by upstream Arch may be inconsistent with other drivers build by Manjaro and probably present on your system.
Please do - the surface laptop is a Microsoft backed product - just like Manjaro has tweaked the distribution to fit certain peculiarities - I am sure Microsoft has done the same thing - so the OS may have some tweaks added to make the hardware shine when used with Windows.
Thank you so much for the advice. I really enjoyed using Manjaro for the past few months and using linux in general, unfortunately the Surface isn't fit for it.
I am having the same problems as the OP except I am using XFCE on a new Asus VivoBook 15. The laptop came with Windows 10 Home, and I wiped it out to do a clean install of Manjaro. It was running perfectly for two weeks, until two nights ago when I allowed some updates. I don't know what a kernel is or which one I'm using. I am brand new to Manjaro. Is there a patch likely to be sent out soon? Or do I need to reinstall?
That's strange. It probrably means that this issue is not only a Surface issue nor a KDE only issue. It might have something to do with Manjaro itself.
