Can you give the output of sudo fdisk -l
please?
And I'm about to leave for a New Year's Eve party in a few minutes. So if I don't get back to you right away, I'll be back in a few hours, or perhaps
someone else will pop in.
please?
Disk /dev/mmcblk0: 58.2 GiB, 62537072640 bytes, 122142720 sectors
Disklabel type: gpt
Disk identifier: 7E0D452A-AB37-4904-B8B2-FEF17A1D0AF4
Device Start End Sectors Size Type
/dev/mmcblk0p1 34 514047 514014 251M Microsoft basic data
/dev/mmcblk0p2 514048 9107455 8593408 4.1G Linux swap
/dev/mmcblk0p3 9107456 122142686 113035231 53.9G Linux filesystem
Disk /dev/mmcblk0boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0boot0: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/sda: 14.6 GiB, 15682240512 bytes, 30629376 sectors
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 3464447 3464384 1.7G cd unknown
/dev/sda2 3464448 3472639 8192 4M ef EFI (FAT-12/16/32)
Yes, it looks like SDA is a 16GB removable flash drive. Your command looks good, I'm out the door, good luck and I'll catch up with you next year
This seems to have done the trick. I'm up and running again. Thanks!
This topic was automatically closed after 180 days. New replies are no longer allowed.
