Crash every 25min, NetworkManager blocked, gnome
2020-03-14T16:00:00Z
First time posting. Used to work flawlessly,but after upgrading on 3.14(possibly networkmanager-openvpn ?), my machine will stuck with a network failure about every 25min,every application is "blocked"?However, it only occurs when connect to wired network, wlan has no problem.
I am not sure if its something with my hardware or software.Logs with command 'journalctl -f':
Mar 15 17:28:41 MagicBookPro kernel: rtw_pci 0000:02:00.0: start vif 8e:cd:5c:33:d8:7e on port 0
Mar 15 17:28:41 MagicBookPro NetworkManager[578]: <info>  [1584264521.7776] device (wlp2s0): supplicant interface state: inactive -> disabled
Mar 15 17:28:41 MagicBookPro NetworkManager[578]: <info>  [1584264521.8095] device (wlp2s0): supplicant interface state: disabled -> inactive
Mar 15 17:28:41 MagicBookPro wpa_supplicant[1005]: wlp2s0: Reject scan trigger since one is already pending
**Mar 15 17:29:33 MagicBookPro kernel: usb 1-3.2: reset high-speed USB device number 5 using xhci_hcd**
Mar 15 17:31:10 MagicBookPro gnome-shell[1890]: JS WARNING: [resource:///org/gnome/shell/ui/popupMenu.js 533]: reference to undefined property "_delegate"
Mar 15 17:31:10 MagicBookPro gnome-shell[1890]: JS WARNING: [resource:///org/gnome/shell/ui/popupMenu.js 22]: reference to undefined property "_delegate"
Mar 15 17:31:38 MagicBookPro gnome-shell[1890]: Some code accessed the property 'discreteGpuAvailable' on the module 'appDisplay'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
Mar 15 17:31:46 MagicBookPro systemd[1771]: Started Application launched by gnome-shell.
Mar 15 17:31:59 MagicBookPro NetworkManager[578]: <info>  [1584264719.0415] manager: NetworkManager state is now CONNECTED_SITE
Mar 15 17:31:59 MagicBookPro dbus-daemon[577]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=578 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Mar 15 17:31:59 MagicBookPro systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 15 17:31:59 MagicBookPro dbus-daemon[577]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 15 17:31:59 MagicBookPro systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 15 17:31:59 MagicBookPro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 15 17:31:59 MagicBookPro kernel: audit: type=1130 audit(1584264719.051:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 15 17:32:09 MagicBookPro systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Mar 15 17:32:09 MagicBookPro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 15 17:32:09 MagicBookPro kernel: audit: type=1131 audit(1584264729.574:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 15 17:32:32 MagicBookPro kernel: INFO: task wpa_supplicant:1005 blocked for more than 122 seconds.
**Mar 15 17:32:32 MagicBookPro kernel:       Tainted: G           OE     5.4.24-1-MANJARO #1**
Mar 15 17:32:32 MagicBookPro kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
**Mar 15 17:32:32 MagicBookPro kernel: wpa_supplicant  D    0  1005      1 0x00000080**
Mar 15 17:32:32 MagicBookPro kernel: Call Trace:
Mar 15 17:32:32 MagicBookPro kernel:  ? __schedule+0x2f3/0x770
Mar 15 17:32:32 MagicBookPro kernel:  schedule+0x43/0xd0
Mar 15 17:32:32 MagicBookPro kernel:  schedule_preempt_disabled+0x14/0x20
Mar 15 17:32:32 MagicBookPro kernel:  __mutex_lock.isra.0+0x1ae/0x550
Mar 15 17:32:32 MagicBookPro kernel:  ? check_preempt_curr+0x4a/0x90
Mar 15 17:32:32 MagicBookPro kernel:  nl80211_pre_doit+0xf3/0x1a0 [cfg80211]
Mar 15 17:32:32 MagicBookPro kernel:  genl_family_rcv_msg+0x1e6/0x470
Mar 15 17:32:32 MagicBookPro kernel:  genl_rcv_msg+0x47/0x90
Mar 15 17:32:32 MagicBookPro kernel:  ? genl_family_rcv_msg+0x470/0x470
Mar 15 17:32:32 MagicBookPro kernel:  netlink_rcv_skb+0x75/0x140
Mar 15 17:32:32 MagicBookPro kernel:  genl_rcv+0x24/0x40
Mar 15 17:32:32 MagicBookPro kernel:  netlink_unicast+0x179/0x210
Mar 15 17:32:32 MagicBookPro kernel:  netlink_sendmsg+0x21e/0x3e0
Mar 15 17:32:32 MagicBookPro kernel:  sock_sendmsg+0x5e/0x60
Mar 15 17:32:32 MagicBookPro kernel:  ____sys_sendmsg+0x21b/0x290
Mar 15 17:32:32 MagicBookPro kernel:  ___sys_sendmsg+0xa3/0xf0
Mar 15 17:32:32 MagicBookPro kernel:  __sys_sendmsg+0x81/0xd0
Mar 15 17:32:32 MagicBookPro kernel:  do_syscall_64+0x4e/0x140
Mar 15 17:32:32 MagicBookPro kernel:  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Mar 15 17:32:32 MagicBookPro kernel: RIP: 0033:0x7f0d55fee887
Mar 15 17:32:32 MagicBookPro kernel: Code: Bad RIP value.
Mar 15 17:32:32 MagicBookPro kernel: RSP: 002b:00007ffd502881e8 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
Mar 15 17:32:32 MagicBookPro kernel: RAX: ffffffffffffffda RBX: 000055a443c18b50 RCX: 00007f0d55fee887
Mar 15 17:32:32 MagicBookPro kernel: RDX: 0000000000000000 RSI: 00007ffd50288220 RDI: 0000000000000006
Mar 15 17:32:32 MagicBookPro kernel: RBP: 000055a443c18a60 R08: 0000000000000004 R09: 000055a443c0e010
Mar 15 17:32:32 MagicBookPro kernel: R10: 00007ffd502882f4 R11: 0000000000000246 R12: 000055a443c57cc0
Mar 15 17:32:32 MagicBookPro kernel: R13: 00007ffd50288220 R14: 00007ffd502882f4 R15: 000055a443c6a150
Mar 15 17:32:32 MagicBookPro kernel: INFO: task kworker/2:0:3353 blocked for more than 122 seconds.
Mar 15 17:32:32 MagicBookPro kernel: kworker/2:0     D    0  3353      2 0x80004080
Mar 15 17:32:32 MagicBookPro kernel: Workqueue: events rtl_work_func_t [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  rpm_resume+0x18b/0x790
Mar 15 17:32:32 MagicBookPro kernel:  ? wait_woken+0x70/0x70
Mar 15 17:32:32 MagicBookPro kernel:  rpm_resume+0x302/0x790
Mar 15 17:32:32 MagicBookPro kernel:  __pm_runtime_resume+0x3b/0x60
Mar 15 17:32:32 MagicBookPro kernel:  usb_autopm_get_interface+0x18/0x50
Mar 15 17:32:32 MagicBookPro kernel:  rtl8152_set_mac_address+0x61/0x1c0 [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  set_ethernet_addr+0x83/0x90 [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  rtl8152_reset_resume+0x48/0x60 [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  usb_resume_interface.isra.0+0x46/0xd0
Mar 15 17:32:32 MagicBookPro kernel:  usb_resume_both+0xe8/0x140
Mar 15 17:32:32 MagicBookPro kernel:  ? usb_runtime_suspend+0x70/0x70
Mar 15 17:32:32 MagicBookPro kernel:  __rpm_callback+0x7b/0x130
Mar 15 17:32:32 MagicBookPro kernel:  rpm_callback+0x4f/0x70
Mar 15 17:32:32 MagicBookPro kernel:  rpm_resume+0x591/0x790
Mar 15 17:32:32 MagicBookPro kernel:  rtl_work_func_t+0x6b/0x2b1 [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  ? psi_avgs_work+0x6a/0xd0
Mar 15 17:32:32 MagicBookPro kernel:  process_one_work+0x1e1/0x3d0
Mar 15 17:32:32 MagicBookPro kernel:  worker_thread+0x4a/0x3d0
Mar 15 17:32:32 MagicBookPro kernel:  kthread+0xfb/0x130
Mar 15 17:32:32 MagicBookPro kernel:  ? process_one_work+0x3d0/0x3d0
Mar 15 17:32:32 MagicBookPro kernel:  ? kthread_park+0x90/0x90
Mar 15 17:32:32 MagicBookPro kernel:  ret_from_fork+0x22/0x40
Mar 15 17:32:32 MagicBookPro kernel: INFO: task ThreadPoolForeg:5907 blocked for more than 122 seconds.
Mar 15 17:32:32 MagicBookPro kernel: ThreadPoolForeg D    0  5907   5466 0x00000080
Mar 15 17:32:32 MagicBookPro kernel:  rtl8152_get_link_ksettings+0x27/0x80 [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  ethtool_get_settings+0xa7/0x1e0
Mar 15 17:32:32 MagicBookPro kernel:  dev_ethtool+0x1153/0x2be0
Mar 15 17:32:32 MagicBookPro kernel:  ? _raw_spin_unlock_irqrestore+0x20/0x40
Mar 15 17:32:32 MagicBookPro kernel:  ? __skb_try_recv_datagram+0xf8/0x170
Mar 15 17:32:32 MagicBookPro kernel:  dev_ioctl+0x3ba/0x580
Mar 15 17:32:32 MagicBookPro kernel:  sock_do_ioctl+0xee/0x190
Mar 15 17:32:32 MagicBookPro kernel:  sock_ioctl+0x281/0x3f0
Mar 15 17:32:32 MagicBookPro kernel:  do_vfs_ioctl+0x43d/0x6c0
Mar 15 17:32:32 MagicBookPro kernel:  ? alloc_file_pseudo+0xb5/0x120
Mar 15 17:32:32 MagicBookPro kernel:  ksys_ioctl+0x5e/0x90
Mar 15 17:32:32 MagicBookPro kernel:  __x64_sys_ioctl+0x16/0x20
Mar 15 17:32:32 MagicBookPro kernel: RIP: 0033:0x7f099f33b2eb
Mar 15 17:32:32 MagicBookPro kernel: RSP: 002b:00007f099bb97bd8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Mar 15 17:32:32 MagicBookPro kernel: RAX: ffffffffffffffda RBX: 0000000000000045 RCX: 00007f099f33b2eb
Mar 15 17:32:32 MagicBookPro kernel: RDX: 00007f099bb97d20 RSI: 0000000000008946 RDI: 0000000000000045
Mar 15 17:32:32 MagicBookPro kernel: RBP: 00007f099bb97da0 R08: 0000000000000002 R09: 0032753375336630
Mar 15 17:32:32 MagicBookPro kernel: R10: 5555555555555555 R11: 0000000000000246 R12: 00007f099bb97e30
Mar 15 17:32:32 MagicBookPro kernel: R13: 0000000000000000 R14: 00001a0397239280 R15: 00007f099bb97f78
Mar 15 17:32:32 MagicBookPro kernel: INFO: task ThreadPoolForeg:5908 blocked for more than 122 seconds.
Mar 15 17:32:32 MagicBookPro kernel: ThreadPoolForeg D    0  5908   5466 0x00000080
Mar 15 17:32:32 MagicBookPro kernel:  ? __switch_to_asm+0x40/0x70
Mar 15 17:32:32 MagicBookPro kernel:  __netlink_dump_start+0x54/0x1e0
Mar 15 17:32:32 MagicBookPro kernel:  ? rtnl_xdp_prog_skb+0x60/0x60
Mar 15 17:32:32 MagicBookPro kernel:  rtnetlink_rcv_msg+0x296/0x3c0
Mar 15 17:32:32 MagicBookPro kernel:  ? rtnl_calcit.isra.0+0x120/0x120
Mar 15 17:32:32 MagicBookPro kernel:  __sys_sendto+0x120/0x190
Mar 15 17:32:32 MagicBookPro kernel:  __x64_sys_sendto+0x25/0x30
Mar 15 17:32:32 MagicBookPro kernel: RIP: 0033:0x7f099f345984
Mar 15 17:32:32 MagicBookPro kernel: RSP: 002b:00007f0994ebdb00 EFLAGS: 00000293 ORIG_RAX: 000000000000002c
Mar 15 17:32:32 MagicBookPro kernel: RAX: ffffffffffffffda RBX: 00007f0994ebec20 RCX: 00007f099f345984
Mar 15 17:32:32 MagicBookPro kernel: RDX: 0000000000000014 RSI: 00007f0994ebec20 RDI: 0000000000000049
Mar 15 17:32:32 MagicBookPro kernel: RBP: 0000000000000000 R08: 00007f0994ebebc4 R09: 000000000000000c
Mar 15 17:32:32 MagicBookPro kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007f0994ebebc4
Mar 15 17:32:32 MagicBookPro kernel: R13: 00007f0994ebf2b0 R14: 00007f0994ebebe0 R15: 0000000000000049
Mar 15 17:32:32 MagicBookPro kernel: INFO: task kworker/2:1:5901 blocked for more than 122 seconds.
Mar 15 17:32:32 MagicBookPro kernel: kworker/2:1     D    0  5901      2 0x80004080
Mar 15 17:32:32 MagicBookPro kernel: Workqueue: events_long rtl_hw_phy_work_func_t [r8152]
Mar 15 17:32:32 MagicBookPro kernel:  rtl_hw_phy_work_func_t+0x24/0x90 [r8152]
Try uninstalling tlp & reboot.
After uninstalling tlp,it works smoothly.Thx.
If you are using a laptop, you really shouldn't leave tlp uninstalled. If this is a dektop tlp is not required. The best solution is to find the tlp setting that is causing your issue and change that configuration setting.
Currently i am using a laptop,with default tlp settings,after another installation(default settings), this problem seems to go away, havn't crash so far.Weird.
Tlp was experiencing some severe bugs, perhaps your new install contained a new version of tlp that corrected the issue in a bug fix. Either way, I'm glad you got your connection working again. :+1:
