deep-plasma
just turned computer on opened google-chrome it loaded instantly its fixed but all goood
arch0
Screenshot_20190714_141438
Screenshot_20190714_141755
Screenshot_20190714_155620
Screenshot_20190722_193728
Screenshot_20190726_193745
Screenshot_20190711_155301
deep plasma has started freezing up programs again ie google-chrome,chromium ,thunderbird cant put my finger on the problem maybe a reinstall might fix it
Not really,
you need to troubleshoot what the problem is, otherwise your just going to end up in a reinstall loop.
What if you reinstall and you end up with the same problem?
i have allread reinstalled no problem so far but now i cant get into sudoers to add user
I couldn't reproduce this on my system last night. Although the only variable I believe we have based on the information posted thus far is I don't use thunderbird. maybe try removing that package and its dependencies and see if that resolves the problem. Then dig back into why thunderbird is causing the issue.
now it wont let me add user to sudoers i want to run sudo pacmam -Syy
I did a quick search and apparently there are some real security issues brewing around thunderbird recently:
https://security.archlinux.org/ASA-201905-8
There are many more and not just arch based complaints of freezes.
how do i add user to sudoers this problem has jjust occuered since new install
The only time I saw something like this happen with this ISO was when I had a corrupted USB. I downloaded a fresh ISO, checked the Sha Sum, reformatted the stick, and re-imaged the ISO. Then reinstalled. Although the error I was getting was the user did not have permission over the home folder.
ye i fixed it mate it was skipping one part on the install script all good now sudoers works just cleaned this computer out ready for new asrock x570 motherboard maybe it will be installed tomorrow
This time try and stay away from Thunderbird. make sure everything works and then if you have problems again after installing Thunderbird you know it was the culprit :laughing:
Glad you got it sorted.
just finished reinstalling all apps and thunderbird no problem with google-chrome or chromium this time
so had no idea what was wrong but the clean install appears to fix it and also the speed of the install of deep-plasma was incredible 15 minutes from clearing all hard drives and partitioning sda and install os to reboot i am as happy as a pig in ā– ā– ā– ā– ā–
This is a guide after installing deep-plasma (archlinux)
The very First thing I do after a clean install of archlinux is check the journalctl
journalctl:
In a terminal:
journalctl -p 0 -xb the number zero is for Emergency and needs fixing, if possible
journalctl -p 1 -xb the number one is for Alert and should be fixed, if possible
journalctl -p 2 -xb the number two is for Critical and should be fixed, if possible
journalctl -p 3 -xb the number three is for Error and should be investigated for a possible fix
There are more per this but these are the important ones.
journalctl -p 4 -xb the number four will display Warnings, normally not a problem, but looking through may yield interesting info.
An internet search should get you on your way to fixing most of the problems found in the journal
Ideally you want a clean journalctl -p 3 -xb if possible.
Screenshot_20190712_175232
dmesg:
Another place to look through is dmesg some errors maybe found in here that was never shown in the above, again a quick internet search should give you more info and a possible fix.
Screenshot_20190712_182144
Other useful commands:
sudo systemctl --failed what services have failed, if any
systemd-analyze blame check for causing slow boot up
systemd-analyze the time it took to boot up
After going through all the above and fixing any errors / bugs etc I then move on to installing drivers etc, checking with journalctl -p 3 -xb in between installing them. Software is my next stage and then tweaking my system for optimal performance.
Another thing to do is journalctl -p 3 -xb just before you shut down after various tasks, that should give you any software bugs, if any.
This is what I do straight after installing on any system, assuming it boots, that's another subject for another day :wink:
thanks for that ant that is really helpful
heres what i get
grumpy@archplasma ~]$ journalctl -p 3 -xb
-- Logs begin at Fri 2019-07-12 16:52:14 +07, end at Sat 2019-07-13 02:44:02 +07. --
Jul 13 02:28:09 archplasma kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jul 13 02:28:09 archplasma kernel: kvm: disabled by bios
the only thing is watchdog will look it up later
thanks once again
[grumpy@archplasma ~]$ sudo systemctl --failed
[sudo] password for grumpy:
0 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
[grumpy@archplasma ~]$ systemd-analyze
Startup finished in 15.705s (firmware) + 6.302s (loader) + 4.947s (kernel) + 7.643s (userspace) = 34.598s
graphical.target reached after 7.643s in userspace
[grumpy@archplasma ~]$ systemd-analyze blame
          6.575s pacman-init.service
          1.387s systemd-logind.service
           701ms lvm2-monitor.service
           477ms udisks2.service
           444ms dev-sda2.device
           271ms systemd-udevd.service
           210ms systemd-journald.service
           204ms systemd-journal-flush.service
           157ms upower.service
           116ms NetworkManager.service
            94ms var-lib-snapd-snap-core-7270.mount
            93ms var-lib-snapd-snap-spotify-35.mount
            84ms polkit.service
            82ms boot-efi.mount
            78ms systemd-modules-load.service
            73ms systemd-udev-trigger.service
            61ms ldconfig.service
            50ms user@1000.service
            46ms dde-filemanager-daemon.service
            42ms systemd-fsck@dev-disk-by\x2dpartuuid-e7721945\x2dfe76\x2d4adb\x2daa6a\x>
            32ms systemd-fsck@dev-disk-by\x2dpartuuid-1e019d94\x2def22\x2d4099\x2db108\x>
            29ms systemd-tmpfiles-clean.service
            20ms wpa_supplicant.service
lines 1-23
what do you think of that ant
heres the inxi
  Host: archplasma Kernel: 5.2.0-arch2-1-ARCH x86_64 bits: 64
  Desktop: KDE Plasma 5.16.3 Distro: Arch Linux
  Type: Desktop Mobo: ASRock model: X470 Taichi serial: <root required>
  UEFI: American Megatrends v: P1.10 date: 03/30/2018
  Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP L2 cache: 4096 KiB
  Speed: 2404 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 2413 2: 2422 3: 2424
  4: 2433 5: 2416 6: 2420 7: 2737 8: 2811 9: 2410 10: 2409 11: 2922 12: 2974 13: 2396
  14: 2477 15: 1773 16: 1796
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] driver: amdgpu
  v: kernel
  Display: x11 server: X.Org 1.20.5 driver: modesetting resolution: 2560x1080~60Hz
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  driver: snd_hda_intel
  Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
  Device-3: Logitech type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
  Sound Server: ALSA v: k5.2.0-arch2-1-ARCH
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
  IF: wlp39s0 state: up mac: 68:ec:c5:bf:24:44
  Device-2: Intel I211 Gigabit Network driver: igb
  IF: enp42s0 state: down mac: 70:85:c2:80:98:63
  Local Storage: total: 1.11 TiB used: 9.01 GiB (0.8%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
  ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
  ID-3: /dev/sdc vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
  ID-4: /dev/sdd vendor: Intel model: SSDSC2BW240A4 size: 223.57 GiB
  ID-5: /dev/sde vendor: Intel model: SSDSC2BW240A4 size: 223.57 GiB
  ID-1: / size: 47.81 GiB used: 7.44 GiB (15.6%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 170.51 GiB used: 1.57 GiB (0.9%) fs: ext4 dev: /dev/sda3
  System Temperatures: cpu: 46.6 C mobo: N/A gpu: amdgpu temp: 40 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 935
  Processes: 321 Uptime: 12m Memory: 62.90 GiB used: 1.07 GiB (1.7%) Shell: bash
  inxi: 3.0.34
Screenshot_20190714_120717
:wink:
