Hi there I have installed manjaro xfce stable version.
Good to have OS like this, but I am facing a problem regarding WiFi. I am not able to see any WiFi network in my network manager box. The only way to connect system to network is using ethernet or USB tethering.
Menu > settings > Network Connections
add (bottom left +)
hth
Hi,
Thank for reply but could not understand what you are trying to say with
add (bottom left +)
What I need to do :
well I have added WiFi connection manually but still not showing WiFi network.
Please post:
inxi -Fxxzv8
lspci -knnvvv | grep -i net
journalctl -b -1 --no-pager | grep wl
dmesg | grep 'wl\|firm'
find /etc/modprobe.d -type f -name "*.conf" -print -execdir cat '{}' \; -execdir echo \;
grep -r "blacklist\|install\|options" /etc/modprobe.d/ returns same output as the above command in a more compact output
Please post the input/outputs of all requested commands via the terminal as text, (not as pics).
Information on how to properly post hardware specs and logs:
Please format any terminal output with three backticks before and after, as shown in this picture:
Thanks for reply
I am posting the Output of your commands
And please excuse me and tell me if I made any mistake in formatting the output:
Output for
1. inxi -Fxxzv8
Host: nayan-pc Kernel: 4.19.6-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.2.1 Desktop: N/A wm: xfwm4 dm: LightDM 1.28.0 Distro: Manjaro Linux
Type: Portable System: Dell product: Vostro 3546 v: N/A serial: <filter>
Chassis: type: 8 serial: <filter>
Mobo: Dell model: 0KF6NV v: A12 serial: <filter> UEFI: Dell v: A12
date: 06/20/2017
ID-1: BAT0 charge: 4.4 Wh condition: 18.8/41.4 Wh (45%) volts: 15.5/14.8
model: LGC-LGC2.8 DELL T1G4M49 type: Li-ion serial: <filter>
status: Charging
RAM: total: 3.76 GiB used: 1.23 GiB (32.8%)
RAM Report: permissions: Unable to run dmidecode. Are you root?
Permissions: Unable to run dmidecode. Are you root?
Topology: Dual Core model: Intel Core i3-4005U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 24
L2 cache: 3072 KiB bogomips: 13574
Speed: 899 MHz min/max: 800/1700 MHz Core speeds (MHz): 1: 898 2: 898
3: 898 4: 898
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
xsave xsaveopt xtopology xtpr
Vulnerabilities: Type: l1tf
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB, IBRS_FW
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
vendor: Dell driver: nouveau v: kernel bus ID: 08:00.0 chip ID: 10de:1140
Display: x11 server: X.org 1.20.3 driver: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.2.6
compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k4.19.6-1-MANJARO
vendor: Dell driver: r8168 v: 8.045.08-NAPI port: e000 bus ID: 07:00.0
chip ID: 10ec:8168
IF: enp7s0 state: down mac: <filter>
IF-ID-1: enp0s29u1u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 2.27 TiB used: 618.15 GiB (26.5%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Seagate model: BUP Slim BK size: 1.82 TiB
block size: physical: 4096 B logical: 512 B serial: <filter> rev: 0108
scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW SU-208GB rev: D100
dev-links: cdrom
ID-1: / raw size: 457.19 GiB size: 449.01 GiB (98.21%)
used: 16.08 GiB (3.6%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 3bda4cc7-a5ee-42fb-9ced-c0c8a63bf67d
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 264 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 43BE-CDFB
ID-3: /run/media/nayan/D901-BCC4 raw size: 1.82 TiB
size: 1.82 TiB (99.98%) used: 602.07 GiB (32.3%) fs: vfat dev: /dev/sdb1
label: N/A uuid: D901-BCC4
ID-4: swap-1 size: 8.28 GiB used: 12 KiB (0.0%) fs: swap
swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sda3
label: N/A uuid: c2f73ab0-9678-4d3e-b331-8261a7416a30
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel ports: 8 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8000
Device-1: 1-1.1:5
info: Seagate RSS LLC Backup Plus Slim Portable Drive 1 TB
type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 0bc2:ab26 serial: <filter>
Device-2: 1-1.2:14 info: Motorola PCS type: Bluetooth,CDC-Data
driver: rndis_host interfaces: 3 rev: 2.0 speed: 480 Mb/s
chip ID: 22b8:2e25 serial: <filter>
Device-3: 1-1.5:3 info: Realtek type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5756 serial: <filter>
Device-4: 1-1.8:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: 49.0 C
Fan Speeds (RPM): cpu: 0
1: https://osmirror.org/manjaro/stable/$repo/$arch
2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
3: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
4: https://manjaro.grena.ge/stable/$repo/$arch
5: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
6: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
7: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5
1: cpu: 10.1% command: chrome pid: 2100 mem: 245.2 MiB (6.3%)
2: cpu: 3.9% command: chrome pid: 1963 mem: 187.9 MiB (4.8%)
3: cpu: 3.1% command: chrome pid: 2002 mem: 96.8 MiB (2.5%)
4: cpu: 2.4% command: skypeforlinux pid: 1142 mem: 150.9 MiB (3.9%)
5: cpu: 1.9% command: xorg pid: 664 mem: 55.3 MiB (1.4%)
Memory top: 5
1: mem: 247.6 MiB (6.4%) command: skypeforlinux pid: 1352 cpu: 1.7%
2: mem: 245.2 MiB (6.3%) command: chrome pid: 2100 cpu: 10.1%
3: mem: 187.9 MiB (4.8%) command: chrome pid: 1963 cpu: 3.9%
4: mem: 168.6 MiB (4.3%) command: dropbox pid: 1145 cpu: 0.4%
5: mem: 150.9 MiB (3.9%) command: skypeforlinux pid: 1142 cpu: 2.4%
Processes: 193 Uptime: 1h 35m Init: systemd v: 239 Compilers: gcc: 8.2.1
Shell: bash v: 4.4.23 running in: xfce4-terminal inxi: 3.0.27
2. lspci -knnvvv | grep -i net
07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
Subsystem: Dell RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1028:0662]
3. journalctl -b -1 --no-pager | grep wl
There is noting in output
[nayan@nayan-pc ~]$ journalctl -b -1 --no-pager | grep wl
[nayan@nayan-pc ~]$
4. dmesg | grep 'wl|firm'
[nayan@nayan-pc ~]$ dmesg | grep 'wl\|firm'
[ 0.285296] Spectre V2 : Enabling Restricted Speculation for firmware calls
5. find /etc/modprobe.d -type f -name "*.conf" -print -execdir cat '{}' ; -execdir echo ;
[nayan@nayan-pc ~]$ find /etc/modprobe.d -type f -name "*.conf" -print -execdir cat '{}' \; -execdir echo \;
/etc/modprobe.d/r8169_blacklist.conf
blacklist r8169
6. grep -r "blacklist|install|options" /etc/modprobe.d/
[nayan@nayan-pc ~]$ grep -r "blacklist\|install\|options" /etc/modprobe.d/
/etc/modprobe.d/r8169_blacklist.conf:blacklist r8169
That is not good, the adapter is not detected at all.
Do you have WiFi enabled in your bios.
Do you know your adapter model or the driver of this adapter.
Is the adapter detected on the live boot disk.
Does this adapter work on any other Linux (live or installed) version.
If so what is the adapter identified as.
Does this adapter work correctly in Windows.
Are you dual booting or multi-booting this laptop.
Please ensure you answer all these questions, and please post:
sudo fkill list all
lsmod
I will let you know all after some time.
1. sudo fkill list all
Well I think fkill should be rfkill
[nayan@nayan-pc ~]$ sudo fkill list all
[sudo] password for nayan:
sudo: fkill: command not found
[nayan@nayan-pc ~]$ sudo rfkill list all
[nayan@nayan-pc ~]$
2. lsmod
[nayan@nayan-pc ~]$ lsmod
Module Size Used by
rndis_host 16384 0
cdc_ether 16384 1 rndis_host
usbnet 49152 2 rndis_host,cdc_ether
mii 16384 1 usbnet
uas 28672 1
usb_storage 69632 1 uas
xfs 1634304 0
jfs 208896 0
btrfs 1372160 0
xor 24576 1 btrfs
raid6_pq 122880 1 btrfs
fuse 118784 3
nls_iso8859_1 16384 2
nls_cp437 20480 2
vfat 24576 2
fat 81920 1 vfat
snd_hda_codec_hdmi 57344 1
joydev 24576 0
uvcvideo 118784 0
mousedev 24576 0
rtsx_usb_ms 20480 0
hid_rmi 20480 0
rmi_core 90112 1 hid_rmi
memstick 16384 1 rtsx_usb_ms
videobuf2_vmalloc 16384 2 rmi_core,uvcvideo
videobuf2_memops 16384 1 videobuf2_vmalloc
videobuf2_v4l2 28672 2 rmi_core,uvcvideo
videobuf2_common 53248 3 rmi_core,videobuf2_v4l2,uvcvideo
i915 2097152 11
videodev 217088 4 rmi_core,videobuf2_v4l2,uvcvideo,videobuf2_common
wmi_bmof 16384 0
dell_wmi 16384 0
media 45056 2 videodev,uvcvideo
ofpart 16384 0
cmdlinepart 16384 0
intel_rapl 24576 0
intel_spi_platform 16384 0
kvmgt 28672 0
intel_spi 20480 1 intel_spi_platform
sparse_keymap 16384 1 dell_wmi
nouveau 2187264 1
spi_nor 36864 1 intel_spi
vfio_mdev 16384 0
mdev 20480 2 kvmgt,vfio_mdev
iTCO_wdt 16384 0
iTCO_vendor_support 16384 1 iTCO_wdt
mtd 69632 5 cmdlinepart,intel_spi,ofpart
hid_generic 16384 0
vfio_iommu_type1 28672 0
x86_pkg_temp_thermal 16384 0
intel_powerclamp 16384 0
vfio 32768 3 kvmgt,vfio_mdev,vfio_iommu_type1
mxm_wmi 16384 1 nouveau
coretemp 16384 0
kvm_intel 245760 0
ttm 126976 1 nouveau
i2c_algo_bit 16384 2 i915,nouveau
kvm 737280 2 kvmgt,kvm_intel
snd_hda_codec_realtek 110592 1
snd_hda_codec_generic 86016 1 snd_hda_codec_realtek
snd_hda_intel 45056 4
snd_hda_codec 151552 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
drm_kms_helper 208896 2 i915,nouveau
irqbypass 16384 1 kvm
dell_laptop 24576 0
snd_hda_core 94208 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
crct10dif_pclmul 16384 0
rfkill 28672 2 dell_laptop
crc32_pclmul 16384 0
ghash_clmulni_intel 16384 0
pcbc 16384 0
drm 495616 9 drm_kms_helper,i915,ttm,nouveau
snd_hwdep 16384 1 snd_hda_codec
aesni_intel 200704 0
aes_x86_64 20480 1 aesni_intel
crypto_simd 16384 1 aesni_intel
cryptd 28672 3 crypto_simd,ghash_clmulni_intel,aesni_intel
intel_gtt 24576 1 i915
glue_helper 16384 1 aesni_intel
dell_smbios 28672 2 dell_wmi,dell_laptop
snd_pcm 131072 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
agpgart 49152 4 intel_gtt,ttm,nouveau,drm
dell_wmi_descriptor 16384 2 dell_wmi,dell_smbios
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
snd_timer 36864 1 snd_pcm
snd 98304 16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
intel_cstate 16384 0
intel_uncore 135168 0
soundcore 16384 1 snd
intel_rapl_perf 16384 0
dcdbas 16384 1 dell_smbios
sysimgblt 16384 1 drm_kms_helper
r8168 540672 0
psmouse 172032 0
fb_sys_fops 16384 1 drm_kms_helper
dell_smm_hwmon 16384 0
input_leds 16384 0
pcspkr 16384 0
wmi 28672 6 dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor,mxm_wmi,nouveau
battery 24576 0
pcc_cpufreq 16384 0
mei_me 45056 0
i2c_hid 28672 0
hid 139264 3 i2c_hid,hid_generic,hid_rmi
mei 114688 1 mei_me
lpc_ich 28672 0
ac 16384 0
evdev 24576 15
mac_hid 16384 0
i2c_i801 32768 0
gpio_lynxpoint 16384 0
nf_log_ipv6 16384 5
ip6t_REJECT 16384 1
nf_reject_ipv6 16384 1 ip6t_REJECT
xt_hl 16384 22
ip6t_rt 16384 3
nf_log_ipv4 16384 5
nf_log_common 16384 2 nf_log_ipv4,nf_log_ipv6
ipt_REJECT 16384 1
nf_reject_ipv4 16384 1 ipt_REJECT
xt_LOG 16384 10
xt_limit 16384 13
xt_addrtype 16384 4
xt_tcpudp 16384 22
xt_conntrack 16384 16
ip6table_filter 16384 1
ip6_tables 32768 53 ip6table_filter
nf_conntrack_netbios_ns 16384 0
nf_conntrack_broadcast 16384 1 nf_conntrack_netbios_ns
nf_nat_ftp 16384 0
nf_nat 36864 1 nf_nat_ftp
nf_conntrack_ftp 20480 1 nf_nat_ftp
nf_conntrack 163840 6 xt_conntrack,nf_nat,nf_nat_ftp,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_conntrack_ftp
nf_defrag_ipv6 20480 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
libcrc32c 16384 4 nf_conntrack,nf_nat,btrfs,xfs
iptable_filter 16384 1
uinput 20480 0
crypto_user 16384 0
ip_tables 28672 11 iptable_filter
x_tables 45056 13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
ext4 733184 1
crc32c_generic 16384 0
crc16 16384 1 ext4
mbcache 16384 1 ext4
jbd2 126976 1 ext4
fscrypto 32768 1 ext4
rtsx_usb_sdmmc 28672 0
mmc_core 176128 1 rtsx_usb_sdmmc
rtsx_usb 20480 2 rtsx_usb_sdmmc,rtsx_usb_ms
sr_mod 28672 0
cdrom 69632 1 sr_mod
sd_mod 61440 6
ahci 40960 3
libahci 40960 1 ahci
serio_raw 16384 0
atkbd 32768 0
libata 278528 2 libahci,ahci
libps2 16384 2 atkbd,psmouse
scsi_mod 253952 5 sd_mod,usb_storage,uas,libata,sr_mod
crc32c_intel 24576 3
ehci_pci 16384 0
ehci_hcd 94208 1 ehci_pci
i8042 32768 1 dell_laptop
serio 28672 7 rmi_core,serio_raw,atkbd,psmouse,i8042
Sorry if I typoed:
Try this please:
rfkill list all
Please install kernel 4.14 with Manjaro Settings Manager. Do not uninstall kernel 4.19. Reboot and test operation on k 4.14.
I have pasted the output for the command in previous reply
And as I am watching the setup option
There Integrated NIC is enabled
Okk I will try this too
Hello tbg
I am now on kernel 4.14 and I am getting same output of all command as before .
I need to know what adapter you have. Until I find that info it's all guess work. Please answer as many of these as you can now:
Can you please tell me how to know what adapter I have .
Please answer as many as possible ^^^
Okk It will take time but I will try to answer them as soon as possible
Answer the ones you can now please.
Are you dual booting or multi-booting this laptop?
- No I am not dual booting this laptop
Do you have WiFi enabled in your bios?
- Yes NIC is enabled from the BIOS
And let me know you that when I first installed Manjaro the WiFi was working fine in live mode as well as after installation but the problem occurs 4-5 days after installation.
And for other question I need to have a bootable pendrive that will take time to post all answers.
I may be able to find the info online, but if not you will need to:
Boot from a live distribution where your wifi is detected. This can be a Manjaro, Ubuntu, or other live boot where the wifi is detected.
In the live environment run these commands:
lsmod
Post those outputs.
Save any open documents and close all open programs.
Run the following commands:
sudo systemctl stop NetworkManager
sleep 2
sudo modprobe -r dell_laptop
sleep 2
sudo rfkill unblock wifi
sleep 2
sudo systemctl start NetworkManager
sleep 2
nmcli r wifi off
sleep 2
nmcli r wifi on
Then test your wifi.
If your wifi is not working put your laptop into suspend.
Wait 30 seconds then bring laptop out of suspend and test your wifi again.
If the laptop freezes you may have to do a hard power down.
Please post all input/outputs and report any changes you notice.
Hi tbg,
I am running Xubuntu liveboot
Here also I'm not able to see the WiFi network
Output of your commands are as fallows
1. lspci -knnvvv | grep -i net
xubuntu@xubuntu:~$ lspci -knnvvv | grep -i net
2. lsmod
xubuntu@xubuntu:~$ lsmod
Module Size Used by
rndis_host 16384 0
usbnet 45056 2 rndis_host,cdc_ether
rtsx_usb_ms 20480 0
hid_rmi 24576 0
dell_wmi 16384 0
dell_laptop 20480 0
intel_rapl 20480 0
coretemp 16384 0
kvm_intel 200704 0
kvm 593920 1 kvm_intel
uvcvideo 90112 0
videobuf2_vmalloc 16384 1 uvcvideo
videobuf2_v4l2 24576 1 uvcvideo
videobuf2_core 40960 2 uvcvideo,videobuf2_v4l2
dell_led 16384 0
videodev 172032 3 uvcvideo,videobuf2_core,videobuf2_v4l2
dell_smbios 16384 3 dell_wmi,dell_led,dell_laptop
snd_hda_codec_hdmi 49152 1
pcbc 16384 0
aesni_intel 167936 0
snd_hda_codec_realtek 90112 1
media 40960 2 uvcvideo,videodev
snd_hda_codec_generic 73728 1 snd_hda_codec_realtek
snd_soc_rt5640 118784 0
snd_hda_intel 36864 5
cryptd 24576 3 crypto_simd,ghash_clmulni_intel,aesni_intel
snd_soc_rl6231 16384 1 snd_soc_rt5640
snd_hda_codec 126976 4 snd_hda_intel,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek
intel_cstate 20480 0
snd_soc_core 233472 1 snd_soc_rt5640
joydev 20480 0
input_leds 16384 0
serio_raw 16384 0
snd_hda_core 81920 5 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek
snd_compress 20480 1 snd_soc_core
ac97_bus 16384 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
elan_i2c 36864 0
snd_pcm 102400 7 snd_hda_intel,snd_hda_codec,snd_pcm_dmaengine,snd_hda_core,snd_soc_rt5640,snd_hda_codec_hdmi,snd_soc_core
snd_seq_midi 16384 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 32768 1 snd_seq_midi
snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 32768 2 snd_seq,snd_pcm
snd 77824 23 snd_compress,snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_soc_core,snd_pcm
mei_me 40960 0
dw_dmac 16384 0
dw_dmac_core 24576 1 dw_dmac
mei 102400 1 mei_me
i2c_designware_platform 16384 0
8250_dw 16384 0
snd_soc_sst_acpi 16384 0
i2c_designware_core 20480 1 i2c_designware_platform
lpc_ich 24576 0
snd_soc_sst_match 16384 1 snd_soc_sst_acpi
shpchp 36864 0
spi_pxa2xx_platform 24576 0
mac_hid 16384 0
dell_rbtn 16384 0
parport_pc 32768 0
ppdev 20480 0
lp 20480 0
parport 49152 3 lp,parport_pc,ppdev
autofs4 40960 2
aufs 241664 3789
nls_utf8 16384 1
isofs 40960 1
nls_iso8859_1 16384 0
dm_mirror 24576 0
dm_region_hash 20480 1 dm_mirror
dm_log 20480 2 dm_mirror,dm_region_hash
uas 24576 0
usb_storage 69632 2 uas
nouveau 1601536 1
i915 1449984 8
ttm 98304 1 nouveau
i2c_algo_bit 16384 2 nouveau,i915
drm_kms_helper 151552 2 nouveau,i915
psmouse 139264 0
drm 352256 12 nouveau,i915,ttm,drm_kms_helper
ahci 36864 1
r8169 81920 0
libahci 32768 1 ahci
mii 16384 2 r8169,usbnet
wmi 16384 4 dell_wmi,dell_led,mxm_wmi,nouveau
sdhci_acpi 16384 0
video 40960 4 dell_wmi,dell_laptop,nouveau,i915
sdhci 45056 1 sdhci_acpi
i2c_hid 20480 0
hid 118784 2 i2c_hid,hid_rmi
fjes 77824 0
