Desktop Wallpaper Images
Just installed Manjaro XFCE 18.1 on a new laptop and noticed that some the wallpapers are not there anymore. There's only 5. Have the others been removed or are they in another folder?
Screenshot_2019-10-19_10-30-28
Have you checked in /usr/share/backgrounds to see if there are other folders containing wallpapers?
Yeah, it's just those.
That's odd!
I am afraid I'm clueless as to what might have happened to the wallpapers. Was this an installation from a "freshly" downloaded iso?
There are multiple wallpaper packages in the repos, for each DE and also from different years/releases. Just look them up and install them.
Looks like you downloaded the minimal ISO ?? which has less wallpapers...
Me? No, but the OP might have :slight_smile:
Those for Deepin are made by you, correct? Cool stuff!
Sorry @bogdancovaciu I hit the wrong reply button, not been up long :rofl:
Yes, some of them, I believe I have more in other distro's, not just deepin.
thank you very much :wink:
No it was the full XFCE install
Check the dropdown menu by the Folder:
you're right - it was the minimal install - DOH!
I admire your honesty, most people would of said nothing, good for you, we all do it.... :wink:
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
