Disable ipv6 completely on pinebook pro
Hi,
I want to disable ipv6 completely since after connecting via OpenVPN to a vpn does not hide my ipv6 address. So far I found
How do we do this on Manjaro 20.04 on a pinebook pro?
Do you have NetworkManager enabled? If so, you may want to read the following section on disabling IPv6 when a VPN connection is made.
https://wiki.archlinux.org/index.php/NetworkManager#Use_dispatcher_to_disable_IPv6_on_VPN_provider_connections
If that doesn't work you may disable IPv6 completely with the suggestions below.
https://wiki.archlinux.org/index.php/IPv6#Disable_IPv6
This topic was automatically closed 89 days after the last reply. New replies are no longer allowed.
