Discord closes after some time while on call
Hi there,
Sorry if this is not an appropriate place, but I could not seem to find a similar issue on discord help pages so it could be manjaro issue?
Discord closes itself approximately every half an hour-ish when I am in call. When I am not in call it never closes. I do not know why this occurs. I tried different headsets (via bluetooth, audio jack, and USB) but this did not work. I tried turning off all the optimisations thinking this could be affecting this closing but does not work either. Is anyone else having issues with this?
Thanks,
Scott
  Kernel: 5.7.0-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel, cairo-dock
  wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: Dell product: XPS 13 9370 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0F6P3V v: A00 serial: <filter> UEFI: Dell v: 1.12.1
  date: 12/11/2019
  ID-1: BAT0 charge: 44.9 Wh condition: 44.9/52.0 Wh (86%) volts: 8.7/7.6
  model: SMP DELL G8VCF6C type: Li-poly serial: <filter> status: Full
  RAM: total: 15.36 GiB used: 2.36 GiB (15.3%)
  RAM Report:
  Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 8192 KiB bogomips: 32012
  Speed: 1500 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 1500 2: 1500
  3: 1500 4: 1500 5: 1500 6: 1500 7: 1500 8: 1500
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
  art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
  lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
  pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
  pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
  xsaves xtopology xtpr
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5917
  Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
  alternate: fbdev,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.0.7
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
  Sound Server: ALSA v: k5.7.0-3-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Bigfoot Networks Killer 1435 Wireless-AC driver: ath10k_pci
  v: kernel port: f040 bus ID: 02:00.0 chip ID: 168c:003e
  Local Storage: total: 491.78 GiB used: 167.91 GiB (34.1%)
  ID-1: /dev/mmcblk0 model: SS16G size: 14.84 GiB serial: <filter>
  scheme: MBR
  ID-2: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV512G NVMe 512GB
  size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: AADA4106
  scheme: GPT
  ID-1: / size: 451.53 GiB used: 167.90 GiB (37.2%) fs: ext4
  dev: /dev/nvme0n1p2 label: N/A uuid: a80024c3-690e-403b-b952-0e6abdd515e0
  ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
  dev: /dev/nvme0n1p1 label: N/A uuid: 6E27-B79F
  ID-3: /var/lib/snapd/snap/bitwarden/24 raw size: 54.6 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop7
  label: N/A uuid: N/A
  ID-4: /var/lib/snapd/snap/bitwarden/25 raw size: 54.6 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop3
  ID-5: /var/lib/snapd/snap/core18/1754 raw size: 54.9 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop0
  ID-6: /var/lib/snapd/snap/gnome-3-28-1804/116 raw size: 160.2 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop2
  ID-7: /var/lib/snapd/snap/gnome-3-28-1804/128 raw size: 161.4 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop1
  ID-8: /var/lib/snapd/snap/gtk-common-themes/1506 raw size: 62.1 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop6
  ID-9: /var/lib/snapd/snap/snap-store/415 raw size: 43.2 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop4
  ID-10: /var/lib/snapd/snap/snapd/7264 raw size: 27.1 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop5
  ID-11: /var/lib/snapd/snap/snapd/7777 raw size: 30.3 MiB
  size: <root required> used: <root required> fs: squashfs dev: /dev/loop8
  ID-12: swap-1 size: 16.90 GiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/nvme0n1p3 label: N/A uuid: ea6943ed-ea1e-4d9d-a217-d8a02b7688aa
  ID-1: /dev/mmcblk0p1 size: 14.83 GiB fs: vfat label: N/A uuid: 6438-3130
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002
  Device-1: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
  driver: uvcvideo interfaces: 4 rev: 2.1 speed: 480 Mb/s chip ID: 0bda:58f4
  serial: <filter>
  Device-2: 1-7:4 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
  interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0489:e0a2
  Device-3: 1-10:5 info: Shenzhen Goodix Fingerprint Reader
  type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
  speed: 12 Mb/s chip ID: 27c6:5385 serial: <filter>
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003
  System Temperatures: cpu: 52.5 C mobo: N/A
  Processes: 268 Uptime: 45m Init: systemd v: 245 Compilers: gcc: 10.1.0
  Shell: bash v: 5.0.17 running in: xfce4-terminal inxi: 3.0.37
The best thing you could do probably, to try to get the info you would need to fix this, would be to start discord via console and have a look at the output when it crashes.
Discord 0.0.10
Starting app.
Starting updater.
[Modules] Modules initializing
[Modules] Distribution: remote
[Modules] Host updates: enabled
[Modules] Module updates: enabled
[Modules] Module install path: /home/scott/.config/discord/0.0.10/modules
[Modules] Module installed file path: /home/scott/.config/discord/0.0.10/modules/installed.json
[Modules] Module download path: /home/scott/.config/discord/0.0.10/modules/pending
[15047:0621/195731.447242:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
[Modules] No updates to install
[Modules] Checking for host updates.
[Modules] Host is up to date.
[Modules] Checking for module updates at https://discordapp.com/api/modules/stable/versions.json
[Modules] No module updates available.
[15047:0621/195731.956656:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
[Modules] Starting to install discord_krisp...
[Modules] Fetching discord_krisp@0 from https://discordapp.com/api/modules/stable/discord_krisp/0
[Modules] Streaming discord_krisp@0 to /home/scott/.config/discord/0.0.10/modules/pending/discord_krisp-0.zip
Error downloading with electron net: HTTP Error: Status Code 403
Falling back to node net library..
(electron) 'isAccessibilitySupportEnabled function' is deprecated and will be removed. Please use 'accessibilitySupportEnabled property' instead.
(electron) 'setBadgeCount function' is deprecated and will be removed. Please use 'badgeCount property' instead.
[Modules] Failed fetching module discord_krisp@0: Error: HTTP Error: Status Code 403
[Modules] Finished module downloads. [success: 0] [failure: 1]
Failed to get crash dump id.
Report Id:
Segmentation fault (core dumped)
