Display sync is not working when using Nvidia card in PRIME settings
I am using an Nvidia 940MX card in PRIME settings on my laptop. But I cannot turn on display sync so I'm having occassional tearing. I have tried to follow most things I could find in forums but to no avail.
mhwd -li
> Installed PCI configs:
         network-r8168            2016.04.20                true            PCI
    video-nvidia-430xx            2019.10.25               false            PCI
> Warning: No installed USB configs!
xrandr --prop
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
	EDID:
		00ffffffffffff0009e52b0700000000
		011b0104951f117802e7b0955c599429
		22505400000001010101010101010101
		010101010101c83680cc703814403020
		360035ad1000001a862480cc70381440
		6464440535ad1000001a000000000000
		00000000000000000000000000000002
		000a40ed0a3c6e11101a75000000008e
	PRIME Synchronization: 0
		supported: 0, 1
	scaling mode: Full aspect
		supported: Full, Center, Full aspect
	Colorspace: Default
		supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
	max bpc: 12
		range: (6, 12)
	Broadcast RGB: Automatic
		supported: Automatic, Full, Limited 16:235
	link-status: Good
		supported: Good, Bad
	CONNECTOR_ID: 95
		supported: 95
	non-desktop: 0
		range: (0, 1)
   1920x1080     60.02*+  60.01    59.97    59.96    59.93    39.27
   1680x1050     59.95    59.88
   1400x1050     59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     60.02
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1280x800      59.99    59.97    59.81    59.91
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   640x400       59.88    59.98
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
	PRIME Synchronization: 1
		supported: 0, 1
	HDCP Content Type: HDCP Type0
		supported: HDCP Type0, HDCP Type1
	Content Protection: Undesired
		supported: Undesired, Desired, Enabled
	max bpc: 12
		range: (8, 12)
	content type: No Data
		supported: No Data, Graphics, Photo, Cinema, Game
	Colorspace: Default
		supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
	aspect ratio: Automatic
		supported: Automatic, 4:3, 16:9
	audio: auto
		supported: force-dvi, off, auto, on
	link-status: Good
	CONNECTOR_ID: 102
		supported: 102
	non-desktop: 0
		range: (0, 1)
If I do `xrandr --output eDP-1-1 --set PRIME Synchronizati
on 1`, the screen blinks but synchronization stays turned off.
UPDATE : Seems like the kernel might've been a problem. Switching to 4.19 seems to be better. I'll update if that's really the case after some time.
UPDATE 2 : It really seems that the problem's been fixed by changing the kernel. It shows now in nvidia-settings that synchronization is on.
