Docker problems
Hello everyone,
I have installed Docker, but I am not able to start the docker deamon. I considered the arch wiki.
Is Docker generally working under manjaro?
Is there any helpful manual?
My problem is:
$ sudo systemctl start docker
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
$ journalctl -xe
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit docker.service has begun starting up.
Dez 02 19:16:12 lenovo dockerd[5419]: time="2016-12-02T19:16:12.996501797+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: time="2016-12-02T19:16:14.005120037+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: time="2016-12-02T19:16:14.057386339+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: time="2016-12-02T19:16:14.057712018+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: time="2016-12-02T19:16:14.057740685+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: time="2016-12-02T19:16:14.058212319+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: time="2016-12-02T19:16:14.065642917+01:00"
Dez 02 19:16:14 lenovo dockerd[5419]: Error starting daemon: Error initializing
Dez 02 19:16:14 lenovo systemd[1]: docker.service: Main process exited, code=exi
Dez 02 19:16:14 lenovo systemd[1]: Failed to start Docker Application Container
-- Subject: Unit docker.service has failed
-- Defined-By: systemd
-- Unit docker.service has failed.
-- The result is failed.
Dez 02 19:16:14 lenovo systemd[1]: docker.service: Unit entered failed state.
Dez 02 19:16:14 lenovo systemd[1]: docker.service: Failed with result 'exit-code
Dez 02 19:16:14 lenovo polkitd[661]: Unregistered Authentication Agent for unix-
$ systemctl status docker.service
● docker.service - Docker Application Container Engine
   Loaded: loaded (/usr/lib/systemd/system/docker.service; disabled; vendor pres
   Active: failed (Result: exit-code) since Fr 2016-12-02 19:16:14 CET; 3min 49s
     Docs: https://docs.docker.com
  Process: 5419 ExecStart=/usr/bin/dockerd -H fd:// (code=exited, status=1/FAILU
 Main PID: 5419 (code=exited, status=1/FAILURE)
I have really no clue how to solve this :expressionless:. It's the AUR git version, but the normal version had the same problem.
Thank you
Hi
I'm using Docker on Manjaro (standard repo) often and without problems.
Unfortunately - your errors dump is wrapped, please repost journalctl -xe with --no-pager
Thank you for your answer.
Although I restarted my pc and change to 4.4.33 kernel it didn't work.
However yesterday I tried it again to start the serve with the same command and it works! I don't know why it suddenly works but it works. I am a little bit confused about it.
