My touchpad works when it comes to moving cursor but i doesn't detect double taps to open any file like it used to any other distro or windows, kindly help
FYI, the Synaptics driver is no longer updated and libinput
is used instead. You already have the drivers installed by default.
Please also post the output of sudo libinput list-devices
Check the touchpad options in XFCE settings. Tap to click may be disabled
thanks
the problem has been solved
How did you solve it?
well since i was new to manjaro i didn't explore mouse and touchpad application, I just needed to enable tap touchpad to click and problem solved
thanks anyways
