Can someone recommend a dual band PCI card that works more or less out of the box? Alternatively can someone help me get this card working
TP-link archer T6E AC1300 Wireless Dual Band PCI Express Adapter
clues here, should work with broadcom-wl-dkms which @philm has packaged for the extra repository
edit- that said, it may be better to use the kernel specific package instead. e.g. linux419-broadcom-wl
match the kernel number to your installed ones. i take it manjaro settings manager didn't offer the driver and mhwd didn't find the card either during install?
if you are unsure which kernel you are currently running open a terminal and type uname -mrs
then press enter.
This post of mine has detailed instructions on how to install the broadcom-wl-dkms driver
This worked thank you.
