Hi ,
New in manjaro , using KDE , installed Duplicati Backup from AUR , but can not access Home folder as a backup source , Duplicati opens in any browser with http://localhost:8200 without any problem , but there must be some permission issue so that cant use / access home folder or any folder inside home .
Please help me .
thanks in advanced ..
Please provide more relevant information:
Which package did you install?
What does
ls -ahl ~
show as well as
lsblk
and
inxi -Fxxxza --no-host
Put these where it says
type or paste code here
when using the button </> above the text field where you type.
Thanks for your reply
I have installed "Duplicati-latest 2.0.5.104-1"
Here is the output
[sukhendu@moon ~]$ ls -ahl ~
total 168K
drwxr-x---+ 25 sukhendu sukhendu 4.0K May 7 18:46 .
drwxr-xr-x 3 root root 4.0K May 6 14:03 ..
-rw-r-----+ 1 sukhendu sukhendu 863 May 7 13:37 .bash_history
-rw-r--r--+ 1 sukhendu sukhendu 21 Feb 17 17:01 .bash_logout
-rw-r--r--+ 1 sukhendu sukhendu 57 Feb 17 17:01 .bash_profile
-rw-r--r--+ 1 sukhendu sukhendu 3.8K Feb 17 17:01 .bashrc
drwxr-xr-x+ 23 sukhendu sukhendu 4.0K May 7 20:53 .cache
drwxr-xr-x+ 31 sukhendu sukhendu 4.0K May 7 20:57 .config
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 6 14:07 Desktop
-rw-r--r--+ 1 sukhendu sukhendu 4.8K Oct 30 2017 .dir_colors
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 7 08:50 Documents
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 7 20:52 Downloads
-rw-r--r--+ 1 sukhendu sukhendu 3.7K Apr 26 12:34 .face
lrwxrwxrwx 1 sukhendu sukhendu 5 Apr 26 12:34 .face.icon -> .face
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 7 12:40 .freedownloadmanager
drwxr-x---+ 4 sukhendu sukhendu 4.0K May 6 15:39 .gnupg
-rw-r--r--+ 1 sukhendu sukhendu 353 May 7 19:50 .gtkrc-2.0
drwxr-xr-x+ 5 sukhendu sukhendu 4.0K May 6 22:09 .icons
drwxr-xr-x+ 3 sukhendu sukhendu 4.0K May 7 09:30 .java
drwxr-xr-x+ 3 sukhendu sukhendu 4.0K May 6 14:07 .kde4
drwxr-xr-x+ 3 sukhendu sukhendu 4.0K Apr 26 13:37 .local
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 6 21:44 MEGAsync
drwxr-x---+ 6 sukhendu sukhendu 4.0K May 6 20:58 .mozilla
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 6 14:07 Music
drwxr-x---+ 3 sukhendu sukhendu 4.0K May 6 15:22 .nv
-rw-r--r--+ 1 sukhendu sukhendu 1.5K May 7 19:40 .nvidia-settings-rc
drwxr-xr-x+ 3 sukhendu sukhendu 4.0K May 7 08:47 .openjfx
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 7 20:22 Pictures
drwxr-x---+ 3 sukhendu sukhendu 4.0K May 6 18:39 .pki
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 6 14:07 Public
drwxr-xr-x+ 7 sukhendu sukhendu 4.0K May 7 11:03 SG
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 6 14:07 Templates
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 6 14:07 Videos
drwxr-xr-x+ 2 sukhendu sukhendu 4.0K May 7 21:06 .vmware
-rw-r-----+ 1 sukhendu sukhendu 49 May 7 18:46 .Xauthority
-rwxr-xr-x+ 1 sukhendu sukhendu 100 Oct 30 2017 .Xclients
-rwxr-xr-x+ 1 sukhendu sukhendu 1.6K Apr 26 12:34 .xinitrc
-rw-r--r--+ 1 sukhendu sukhendu 9.5K Aug 13 2018 .zshrc
[sukhendu@moon ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 232.9G 0 disk
├─sda1 8:1 0 300M 0 part /boot/efi
├─sda2 8:2 0 223.8G 0 part /
└─sda3 8:3 0 8.8G 0 part [SWAP]
[sukhendu@moon ~]$ inxi -Fxxxza --no-host
System: Kernel: 5.6.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
root=UUID=3b9223b1-1bfc-4337-a0ce-76e1eb4b8efd rw quiet
resume=UUID=7f3f146d-bae8-471b-88b3-fdf398db1d87 udev.log_priority=3
Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2 info: plank wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: H310M S2H 2.0 v: x.x serial: <filter>
UEFI: American Megatrends v: F12 date: 08/13/2019
CPU: Topology: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: A (10) microcode: CA L2 cache: 9216 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 34814
Speed: 3973 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 3903 2: 3543
3: 3561 4: 3495 5: 3792 6: 3421
Type: l1tf
Graphics: Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ZOTAC driver: nvidia v: 440.82
bus ID: 01:00.0 chip ID: 10de:128b
Display: x11 server: X.Org 1.20.8 driver: nvidia compositor: kwin_x11 tty: N/A
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82
direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0f
Sound Server: ALSA v: k5.6.8-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 232.89 GiB used: 88.18 GiB (37.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 4B6Q scheme: GPT
Partition: ID-1: / raw size: 223.79 GiB size: 219.28 GiB (97.98%) used: 38.49 GiB (17.6%)
fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 8.80 GiB used: 256 KiB (0.0%) fs: swap
swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sda3
Sensors: System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info: Processes: 258 Uptime: 2h 34m Memory: 15.59 GiB used: 3.52 GiB (22.6%)
Init: systemd v: 244 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
running in: konsole inxi: 3.0.37
What is the output of
systemctl status duplicati
Please, put your output between ``` at the beginning and the end or use the </> button.
● duplicati.service - Duplicati
Loaded: loaded (/usr/lib/systemd/system/duplicati.service; enabled; vendor pre
Active: active (running) since Thu 2020-05-07 18:45:53 IST; 3h 14min ago
Main PID: 451 (mono)
Tasks: 11 (limit: 19129)
Memory: 111.3M
CGroup: /system.slice/duplicati.service
└─451 /usr/bin/mono /opt/duplicati-latest/Duplicati.Server.exe --webse
May 07 18:45:53 moon systemd[1]: Started Duplicati.
[sukhendu@moon ~]$ ```
Thank you for formatting the output!
Could you please give me:
cat /usr/lib/systemd/system/duplicati.service
How exactly did you enable and start this service?
[sukhendu@moon ~]$ cat /usr/lib/systemd/system/duplicati.service
[Unit]
Description=Duplicati
After=network.target
[Service]
ExecStart=/usr/bin/mono /opt/duplicati-latest/Duplicati.Server.exe --webservice-port=8200
Restart=on-abort
Environment=AUTOUPDATER_Duplicati_SKIP_UPDATE=1
User=duplicati
Group=duplicati
[Install]
WantedBy=default.target[sukhendu@moon ~]$```
Please do:
sudo cp /usr/lib/systemd/system/duplicati.service /etc/systemd/system/duplicati.service
Then edit the /etc/systemd/system/duplicati.service with root rights like so:
sudo nano /etc/systemd/system/duplicati.service
and remove
Save and close, then
sudo systemctl disable --now duplicati.service
sudo systemctl enable --now duplicati.service
It should now work.
