Energy settings missing on Deepin
When Deepin shows the lock screen, it only wakes up when the laptop keys are pressed. The Usb keyboard is ignored.
I was facing the same issue in Plasma. It was solved by unticking "Screen energy saving" on all three tabs from [System settings -> Power management].
I would like to know if there is something similar in Deepin and where could I edit such preferences.
I have solved this by using Powertop. There, I enabled Usb devices in the WakeUp tab.
Strangely enough, after this, the screenlock without suspend (from Deepin) started working.
Well, that's it.
