Enlightenment/Econnman
FYI : Econnman doesnt start:
[gpunk@kili ~]$ econnman-bin
  File "/usr/bin/econnman-bin", line 18, in <module>
    import efl.evas as evas
ModuleNotFoundError: No module named 'efl'
During handling of the above exception, another exception occurred:
  File "/usr/bin/econnman-bin", line 45, in <module>
    import elementary as elm
ModuleNotFoundError: No module named 'elementary'
[gpunk@kili ~]$
[gpunk@kili ~]$ inxi -Fxxxz
System:    Host: kili Kernel: 5.7.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Gnome 3.36.1 dm: LightDM 1.30.0
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Nitro AN515-42 v: V1.16 serial: <filter>
           Mobo: RR model: Freed_RRS v: V1.16 serial: <filter> UEFI: Insyde v: 1.16 date: 08/05/2019
Battery:   ID-1: BAT1 charge: 44.3 Wh condition: 45.7/48.9 Wh (93%) volts: 17.0/15.2
           model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x00C6 type: Li-ion serial: <filter> status: Charging
CPU:       Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31948
           Speed: 3375 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 3261 2: 3329 3: 1356 4: 1373 5: 1336
           6: 1335 7: 1380 8: 1454
Graphics:  Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI
           driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67ef
           Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Acer Incorporated ALI
           driver: amdgpu v: kernel bus ID: 04:00.0 chip ID: 1002:15dd
           Display: x11 server: X.org 1.20.8 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
           compositor: enlightenment resolution: <xdpyinfo missing>
           OpenGL: renderer: AMD RAVEN (DRM 3.36.0 5.7.0-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.4 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.7.0-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
           v: kernel port: 2000 bus ID: 02:00.1 chip ID: 10ec:8168
           IF: enp2s0f1 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
           port: 2000 bus ID: 03:00.0 chip ID: 168c:003e
           IF: wlan0 state: down mac: <filter>
           IF-ID-1: usb0 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:    Local Storage: total: 585.00 GiB used: 65.56 GiB (11.2%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 2B6Q
           scheme: GPT
           ID-2: /dev/sdb vendor: Toshiba model: THNSNH128G8NT size: 119.24 GiB speed: 6.0 Gb/s serial: <filter> rev: N101
           scheme: GPT
Partition: ID-1: / size: 116.58 GiB used: 65.56 GiB (56.2%) fs: ext4 dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 59.2 C mobo: N/A
           GPU: device: amdgpu temp: 59 C device: amdgpu temp: 45 C
Info:      Processes: 246 Uptime: 14m Memory: 14.62 GiB used: 1.71 GiB (11.7%) Init: systemd v: 245 Compilers: gcc: N/A
           Shell: bash v: 5.0.16 running in: terminology inxi:
Econnman requires python-efl. Other than that I do not know. I have not used any upstream, or AUR, packages for EFL/Enlightenment in years.
It is already installed ... :frowning:
Updated 1,889 Days Ago
Does that give you a clue? :wink:
hmmm,
I have install the git version, which works fine .
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
