Error During Installation
WhatsApp Image 2020-04-21 at 14.55.14
Has anyone faced this problem till now?
Please Help thanks
Can you please post if you were trying to run along side another OS, trying to install to a drive that you have anther data partition on, or trying to give Manjaro the entire drive? Also is that the USB live environment? I ask cause there is no dock booting in to the live environment, and I don't see the shortcuts for installing Manjaro or Architect Thanks
Yes I had Manjaro Gnome before but it had some issues so I tried to install it all over again giving entire drive. Yes this is USB live environment.
Now I have managed to free the entire the entire disk by deleting other boot options now also the problem is still there.
Boot into the live system, execute
sudo parted -l
and post the, formatted, result.
Screenshot from 2020-04-21 13-27-12
Please post the like this using the </> to wrap the text.
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 120GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name  Flags
 1      2097kB  317MB   315MB   fat32              msftdata
 2      317MB   98.0GB  97.7GB  ext4
 3      98.0GB  120GB   22.0GB  ext4
Model: ATA WDC WD10EARS-00Y (scsi)
Disk /dev/sdb: 1000GB
Disk Flags:
 1      1049kB  1000GB  1000GB  ext4         Movies
Model: ATA ST31500541AS (scsi)
Disk /dev/sdc: 1500GB
Disk Flags:
 5      1049kB  212GB   212GB  ext4         Music
 6      212GB   781GB   569GB  ext4         Movie Series
 7      781GB   1391GB  610GB  ext4         XXX
 1      1391GB  1500GB  109GB  ext4         Snapshots
Model: ASMedia AS2115 (scsi)
Disk /dev/sdd: 128GB
Disk Flags:
 1      1049kB  53.8GB  53.8GB  ext4         Downloads
 2      53.8GB  96.7GB  42.9GB  ext4         Music Vides
 3      96.7GB  128GB   31.3GB  ext4         My Docs
Model: Seagate Expansion (scsi)
Disk /dev/sde: 2000GB
Disk Flags:
 1      1049kB  1766GB  1766GB  ext4         Television
 5      1766GB  1767GB  315MB   fat32                    msftdata
 6      1767GB  1809GB  42.1GB  btrfs
 2      1832GB  1833GB  315MB   fat32                    msftdata
 3      1833GB  1930GB  97.7GB  ext4
 4      1978GB  2000GB  22.0GB  ext4
Model: ATA ST1000LM035-1RK1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
Model: SanDisk Cruzer Blade (scsi)
Disk /dev/sdb: 15.6GB
Partition Table: msdos
Disk Flags:
Number  Start  End  Size  Type  File system  Flags
/dev/sda should be fine.
Here is the Manjaro User Guide which navigates you through the installation process:
