Error: Failed to launch shortcut "<Primary>Escape / Xmodmap
Hi, very odd error I just started receiving, see attached. Yesterday I was remapping keys. So this somehow seems related. Along with this, my Mod key mapping stopped functioning when I booted up today. The Xmodmap is:
xmodmap:  up to 3 keys per modifier, (keycodes in parentheses):
shift       Shift_L (0x32),  Shift_R (0x3e)
lock
control     Control_L (0x25),  Control_R (0x69)
mod1        Alt_L (0x40),  Alt_R (0x6c),  Meta_L (0xcd)
mod2        Escape (0x9)
mod3        Super_R (0x86),  Super_R (0x87)
mod4        Super_L (0x85),  Super_L (0xce),  Hyper_L (0xcf)
mod5        ISO_Level3_Shift (0x5c),  Mode_switch (0xcb)
The CapsLock as Escape in vim still seems to work but the keymappings using Menu (mod3) within Awesome do not. I reverted to my old rc.lua so I can work. Any help with this would be great, thanks in advance.
System:    Host: zenlinux Kernel: 4.19.126-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Awesome 4.3
           dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: SABERTOOTH X79 v: Rev 1.xx serial: <filter> BIOS: American Megatrends
           v: 4801 date: 07/25/2014
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU:       Topology: 6-Core model: Intel Core i7-3960X bits: 64 type: MT MCP arch: Sandy Bridge rev: 7
           L2 cache: 15.0 MiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 79252
           Speed: 1216 MHz min/max: 1200/3900 MHz Core speeds (MHz): 1: 1206 2: 1201 3: 1201 4: 1201 5: 1201
           6: 1201 7: 1201 8: 1201 9: 1200 10: 1201 11: 1201 12: 1201
Graphics:  Device-1: NVIDIA GM204GL [Quadro M4000] driver: nvidia v: 430.64 bus ID: 01:00.0 chip ID: 10de:13f1
           Display: x11 server: X.org 1.20.8 driver: nvidia resolution: <xdpyinfo missing>
Audio:     Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:1d20
           Device-2: NVIDIA GM204 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:0fbb
           Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo bus ID: 4-1.2:3
           chip ID: 046d:0843 serial: <filter>
           Device-4: RODE Microphones type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 4-1.4:5
           chip ID: 19f7:0003
           Sound Server: ALSA v: k4.19.126-1-MANJARO
Network:   Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe driver: e1000e v: 3.2.6-k port: f040
           bus ID: 00:19.0 chip ID: 8086:1503
Drives:    Local Storage: total: 10.22 TiB used: 1.54 TiB (15.1%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 Series size: 111.79 GiB speed: 6.0 Gb/s serial: <filter>
           rev: 8B0Q scheme: MBR
           ID-2: /dev/sdb vendor: Samsung model: SSD 840 Series size: 111.79 GiB speed: 6.0 Gb/s serial: <filter>
           ID-3: /dev/sdc vendor: Western Digital model: WD2002FAEX-007BA0 size: 1.82 TiB speed: 6.0 Gb/s
           serial: <filter> rev: 1D05 scheme: MBR
           ID-4: /dev/sdd vendor: Samsung model: SSD 860 EVO 2TB size: 1.82 TiB speed: 6.0 Gb/s serial: <filter>
           rev: 2B6Q scheme: MBR
           ID-5: /dev/sde type: USB vendor: Western Digital model: WD My Passport 2627 size: 4.55 TiB
           serial: <filter> rev: 4008 scheme: GPT
           ID-6: /dev/sdf type: USB vendor: Western Digital model: WD My Passport 25E2 size: 1.82 TiB
           serial: <filter> rev: 4005 scheme: MBR
Partition: ID-1: / size: 109.53 GiB used: 70.99 GiB (64.8%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 36.0 C mobo: 42.0 C gpu: nvidia temp: 80 C
           Fan Speeds (RPM): cpu: 0 fan-1: 0 fan-2: 2125 fan-3: 1058 fan-4: 0 fan-5: 0 gpu: nvidia fan: 65%
           Voltages: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.30
Info:      Processes: 348 Uptime: 1h 10m Memory: 62.85 GiB used: 6.40 GiB (10.2%) Init: systemd v: 245 Compilers:
           gcc: 10.1.0 clang: 10.0.0 Shell: zsh v: 5.8 running in: sakura inxi: 3.0.37
Ok, I got the mod keys straightened out by reapplying the Menu keysym to the line for keycode assignment thusly
keycode 135 = Super_R Menu
still though whenever I release control of the mouse from awmtt I get this error listed above
I have to correct that the error also shows up when I hit the key combination of Ctrl-CapsLock or Ctrl-Escape, remember that Escape has been assigned to CapsLock. I can consistently cause it by hitting those key combinations
