$ systemctl status sensord
● sensord.service - Log hardware monitoring data
Loaded: loaded (/usr/lib/systemd/system/sensord.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2020-07-25 21:23:51 IST; 11min ago
Main PID: 731 (sensord)
Tasks: 1 (limit: 9343)
Memory: 5.8M
CGroup: /system.slice/sensord.service
└─731 /usr/sbin/sensord -i 60s -l 30m -f daemon
Jul 25 21:23:51 Predator sensord[731]: Core 5: 55.0 C
Jul 25 21:23:51 Predator sensord[731]: Chip: pch_cannonlake-virtual-0
Jul 25 21:23:51 Predator sensord[731]: Adapter: Virtual device
Jul 25 21:23:51 Predator sensord[731]: temp1: 55.0 C
Jul 25 21:23:51 Predator sensord[731]: Chip: iwlwifi_1-virtual-0
Jul 25 21:23:51 Predator sensord[731]: Error getting sensor data: iwlwifi_1/#0: Can't read
Jul 25 21:23:51 Predator sensord[731]: sensor read error (-1)
Jul 25 21:23:51 Predator systemd[1]: Started Log hardware monitoring data.
Jul 25 21:35:01 Predator systemd[1]: /usr/lib/systemd/system/sensord.service:8: PIDFile= referen>
Edit :-
$ systemctl --user --failed && systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
$ sudo journalctl -p 3 -xb
[sudo] password for lucifer:
-- Logs begin at Sat 2020-07-25 14:51:40 IST, end at Sat 2020-07-25 21:41:22 IST. --
Jul 25 21:23:50 Predator systemd-udevd[358]: Error running install command '/bin/false' for modu>
Jul 25 21:23:52 Predator kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
Jul 25 21:23:52 Predator wpa_supplicant[982]: nl80211: kernel reports: Attribute failed policy v>
Jul 25 21:23:52 Predator wpa_supplicant[982]: Failed to create interface p2p-dev-wlp0s20f3: -22 >
Jul 25 21:23:52 Predator wpa_supplicant[982]: nl80211: Failed to create a P2P Device interface p>
Jul 25 21:24:05 Predator kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
Jul 25 21:24:08 Predator kwin_x11[1158]: kwin_xkbcommon: XKB: couldn't find a Compose file for l>
Jul 25 21:24:10 Predator kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f080>
Jul 25 21:24:10 Predator kernel: snd_hda_codec_hdmi hdaudioC1D0: out of range cmd 0:7:707:ffffff>
Jul 25 21:24:10 Predator bluetoothd[780]: RFCOMM server failed for Headset Voice gateway: rfcomm>
Jul 25 21:24:10 Predator bluetoothd[780]: RFCOMM server failed for :1.59/Profile/HSPHSProfile/00>
Jul 25 21:24:12 Predator kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
Jul 25 21:24:24 Predator kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f010>
Jul 25 21:33:15 Predator kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f010>
Please help to get rid of that error.
