I've just tried running pacman -Syyu
, but I get the following error message after entering Y
to proceed with the installation:
error: pacman-mirrorlist: missing required signature
error: uboot-pinebookpro: missing required signature
error: failed to commit transaction (package missing required signature)
I've tried running pacman-mirrorlist -g
, but it hasn't helped.
Here's my output from inxi -Fxz
System: Host: Scatha Kernel: 5.4.0-2-MANJARO-ARM aarch64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.17.4
Distro: Manjaro ARM
Machine: Type: ARM Device System: Pine64 Pinebook Pro details: N/A serial: <filter>
Battery: ID-1: cw2015-battery charge: 100% condition: N/A model: N/A status: Full
CPU: Topology: 6-Core (2-Die) model: N/A variant-1: cortex-a72 variant-2: cortex-a53 bits: 64 type: MCP MCM arch: ARMv8
rev: 4
features: Use -f option to see features bogomips: 0
Speed: 1008 MHz min/max: 408/1416:2000 MHz Core speeds (MHz): 1: 408 2: 408 3: 408 4: 408 5: 1008 6: 1008
Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus ID: N/A
Device-2: rk3399-mali driver: panfrost v: kernel bus ID: N/A
Display: x11 server: X.org 1.20.6 driver: modesetting resolution: <xdpyinfo missing>
Audio: Device-1: simple-audio-card driver: asoc_simple_card bus ID: N/A
Device-2: simple-audio-card driver: N/A bus ID: N/A
Sound Server: ALSA v: k5.4.0-2-MANJARO-ARM
Network: Device-1: wlan-platdata driver: N/A bus ID: N/A
IF-ID-1: wlan0 state: up mac: <filter>
Drives: Local Storage: total: 116.48 GiB used: 64.76 GiB (55.6%)
ID-1: /dev/mmcblk2 model: DA4128 size: 116.48 GiB
Partition: ID-1: / size: 114.60 GiB used: 64.76 GiB (56.5%) fs: ext4 dev: /dev/mmcblk2p1
Sensors: System Temperatures: cpu: 18.8 C mobo: N/A
Info: Processes: 172 Uptime: 21m Memory: 3.77 GiB used: 589.4 MiB (15.3%) Init: systemd Compilers: gcc: 9.1.0
clang: 9.0.0 Shell: bash v: 5.0.11 inxi: 3.0.37
