Hi there, I've recently installed Manjaro with xfce and i'm fairly new to this whole linux thing, so please be gentle.
My problem: There is ~5-10secs(on rare occurrence - higher) delay before any web content starts loading which doesn't occur on the same system with Windows 10.
For example: I reboot, open chromium, small delays occurs when opening any web page, then i go to youtube, another small delay occurs when loading any video, after this delay happened, loading time is back to normal(loads everything instantly, like on Windows10). Then i can open firefox and it will do same exact thing described higher. Same goes to Discord.(Afaik all 3 essentially are browsers, so it's probably a poor sample to test on, but i don't know how else i could test this)
I've googled around and this seems to be somehow related to my mobo having 2 NIC's, but i'm not sure and even if it is, i have no idea how exactly i can fix it, so any help/suggestions is greatly appreciated.
Here's output of inxi -Fzxxx
System: Host: arch Kernel: 5.6.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Xfce 4.14.2 tk: Gtk 3.24.20
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: Z370 AORUS Gaming 7 v: N/A serial: <filter>
Mobo: Gigabyte model: Z370 AORUS Gaming 7 v: x.x serial: <filter> UEFI: American Megatrends v: F6 date: 04/03/2018
Battery: ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.0/N/A model: Logitech G Pro Wireless Gaming Mouse
type: N/A serial: <filter> status: Discharging
CPU: Topology: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 88824
Speed: 1300 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 1300 2: 1300 3: 1300 4: 1300 5: 1300 6: 1300 7: 1300
8: 1300 9: 1300 10: 1300 11: 1300 12: 1300
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia v: 440.82 bus ID: 01:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:10f0
Device-3: Focusrite-Novation Scarlett 2i2 USB type: USB driver: snd-usb-audio bus ID: 1-2:3 chip ID: 1235:8202
Sound Server: ALSA v: k5.6.11-1-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: 3.2.6-k port: f000 bus ID: 00:1f.6
chip ID: 8086:15b8
IF: enp0s31f6 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte driver: alx v: kernel port: d000
bus ID: 07:00.0 chip ID: 1969:e0b1
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.28 TiB used: 20.88 GiB (1.6%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-21WN4A0 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: 1A01 scheme: MBR
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB speed: 6.0 Gb/s serial: <filter> rev: 4B6Q
scheme: GPT
ID-3: /dev/sdc vendor: Corsair model: Force GS size: 119.24 GiB speed: 6.0 Gb/s serial: <filter> rev: 5.24
scheme: GPT
ID-4: /dev/sdd type: USB vendor: Kingston model: DataTraveler 2.0 size: 28.88 GiB serial: <filter> rev: PMAP
scheme: MBR
Partition: ID-1: / size: 97.93 GiB used: 20.86 GiB (21.3%) fs: ext4 dev: /dev/sdb5
Sensors: System Temperatures: cpu: 30.0 C mobo: 29.8 C gpu: nvidia temp: 51 C
Fan Speeds (RPM): cpu: 0 fan-2: 0 fan-3: 0 gpu: nvidia fan: 19%
Voltages: 12v: N/A 5v: N/A 3.3v: 1.68 vbat: 1.64
Info: Processes: 295 Uptime: 1h 19m Memory: 15.58 GiB used: 2.22 GiB (14.3%) Init: systemd v: 245 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.16 running in: xfce4-terminal inxi: 3.0.37
