i dont know wht y computer is all i know its a hp with a amd r8 i belive pls help
Start with checking for updates. For example, in a terminal run:
sudo pacman-mirrors -f3
sudo pacman -Syyu
Then, read this thread:
and this:
http://catb.org/~esr/faqs/smart-questions.html#translations
After that, post a question which someone might be able to answer.
Thread title changed from "Ethernet randomly dissconects freezeing having to hard reboot new to linux so dont know how to fix pls help" to "Ethernet randomly disconnects, PC freezes, have to hard reboot" to make the issue more clear with less begging
Install and test newer and older kernel versions to see if the problem still exists.
Please post your hardware specs:
inxi -Fxzc0
