Expressvpn issue
Hi to everyone
I have expressvpn installed on my kde and it works pretty well!
But everytime I disconnect it, the whole internet disconnects and no wifi will be displayed
I should every time type systemctl restart NetworkManager to make it right
How can i fix it?
I think it is a recurring issue with expressvpn.
I am sure you can find something by using the search function.
Numerous people have reported the espressvpn isn't properly replacing /etc/resolv.conf when it exits. I haven't personally experienced this but there are lots of reports on it.
It should probably be reported to expressvpn support.
I searched a lot but found nothing useful
I don't use ExpressVPN, so maybe I am completely off here, but in MullvadVPN:s app there is a setting that blocks internet, when the VPN connections goes down. It sounds to me like something like that is active, but some people suggests that it is a bug so maybe not.
Thank you
I searched but nothing like that exists on expressvpn
