Hello,
I noticed that Manjaro always installs Bumblebee as default for graphics. But that makes it incompatible with External Monitors at least my experience. One Reason of switching to Manjaro was that External Monitors and Dual Graphics in Ubuntu were a Pain always had to use Nvidia proprietary Driver and even then only 1 external Monitor worked after Tweaking a lot.
Is there any way to handle that in Manjaro? Since Bumblebee is installed now no external Monitor is detected.
My Setup where I want Manjaro to work is:
I have one external Monitor connected via DVI D and one other connected via VGA, plus the Display of my Laptop. I have the Integrated Intel Graphics and a dedicated Nvidia Card.
I also take the Laptop with me for Work often, so Battery Life on the go is just as important as the external Monitors too work. Bumblebee has the great battery life while Nvidia Driver offered at least partially Multi Monitors, but crappy Battery Life. A Dream would be Bumblebee working properly and still be able to use External Monitors.
Does anyone has a similar Setup and knows how to get it to work? Or any Idea how?
I read the multi monitor Page on the Arch Wiki and 2 older sources where someone got it to work in Ubuntu before, but seems not to work anymore.
> System: Host: svenja-pc Kernel: 4.9.16-1-MANJARO x86_64 (64 bit gcc: 6.3.1)
> Desktop: KDE Plasma 5.9.3 (Qt 5.8.0) Distro: Manjaro Linux
> Machine: Device: laptop System: LENOVO product: 24476J7 v: ThinkPad W530
> Mobo: LENOVO model: 24476J7
> UEFI [Legacy]: LENOVO v: G5ET98WW (2.58 ) date: 04/01/2014
> Battery BAT0: charge: 56.4 Wh 60.6% condition: 93.0/93.6 Wh (99%)
> model: LGC 45N1011 status: Discharging
> CPU: Quad core Intel Core i7-3740QM (-HT-MCP-) cache: 6144 KB
> flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 21561
> clock speeds: max: 3700 MHz 1: 1249 MHz 2: 1327 MHz 3: 1301 MHz 4: 1219 MHz
> 5: 1248 MHz 6: 1235 MHz 7: 1395 MHz 8: 1310 MHz
> Graphics: Card-1: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
> Card-2: NVIDIA GK107GLM [Quadro K2000M] bus-ID: 01:00.0
> Display Server: X.Org 1.19.3 driver: intel Resolution: 1920x1080@60.00hz
> GLX Renderer: Mesa DRI Intel Ivybridge Mobile
> GLX Version: 3.0 Mesa 17.0.1 Direct Rendering: Yes
> Audio: Card Intel 7 Series/C216 Family High Definition Audio Controller
> driver: snd_hda_intel bus-ID: 00:1b.0
> Sound: Advanced Linux Sound Architecture v: k4.9.16-1-MANJARO
> Network: Card-1: Intel 82579LM Gigabit Network Connection
> driver: e1000e v: 3.2.6-k port: 6080 bus-ID: 00:19.0
> IF: enp0s25 state: down mac: <filter>
> Card-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi bus-ID: 03:00.0
> IF: wlp3s0 state: up mac: <filter>
> Drives: HDD Total Size: 500.1GB (3.2% used)
> ID-1: /dev/sda model: HGST_HTS725050A7 size: 500.1GB
> Partition: ID-1: / size: 25G used: 8.3G (36%) fs: ext4 dev: /dev/sda5
> ID-2: /home size: 122G used: 984M (1%) fs: ext4 dev: /dev/sda8
> ID-3: /var size: 9.8G used: 1.7G (18%) fs: ext4 dev: /dev/sda9
> ID-4: /boot size: 945M used: 47M (6%) fs: ext4 dev: /dev/sda7
> ID-5: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
> Sensors: System Temperatures: cpu: 45.0C mobo: N/A
> Fan Speeds (in rpm): cpu: 0
> Info: Processes: 212 Uptime: 7 min Memory: 895.6/7542.2MB
> Init: systemd Gcc sys: 6.3.1 Client: Shell (bash 4.4.121) inxi: 2.3.8
