Fail to boot after latest updates, ethernet fail too
Sorry I was asleep at the switch and gave the wrong adapter driver uninstall command earlier. I edited in the correct command.
First of all She,
Second I will put the command on the TTY, I don't know what all the rest that you say is! How can I search? Please guide me through the process!
then:
That's all you need to do.
:heart_eyes:
Ok removed, and with the blacklist command, it said cannot remove.
But I also hit sudo pacman-mirrors -f5 and I seem to HAVE internet connection now!
Now doing the sudo pacman -Syyu
to finish the updates. What next?
You might be better to use:
sudo pacman -Syyuu
I don't know how far behind on your updates you were. You might need the downgrade option in that command I gave.
Don't reboot.
When the command you ran is finished, run the command I just gave.
OK done. Now reboot? :vulcan_salute:
Did you run:
sudo pacman -Syyuu
Yes. :slightly_smiling_face:
Which kernel are you currently using, and do you have more than 1 kernel installed.
How do I see that? A command maybe?
uname -r
4.14.101-1-MANJARO. :slightly_smiling_face:
Run this:
sudo mhwd-kernel -i linux419
Ok done :trophy:
mhwd-kernel -li
Currently running linux 414 The following kernels are installed in your system: linux316 linux414 linux419
how old is this computer
Hahaha....2008. But with Manjaro it's like it is resurrected!
when was the last time you used linux316
