Hello Everyone,
Last night I updated my manjaro system to the latest Manjaro Stable branch and everything seemed to go well, nothing was interupted and I didnt see any errors, I even rebooted my system to make sure that everything was alright and it worked. However when I tried to run the system in the morning, I started getting the boot error Failed to load kernel modules and I am no longer able to boot.
I tried the solutions posted here
but it didnt solve anything. I am not able to open a tty but am able to chroot into the system.
Any help would be appreciated
I can try to click a picture but i doubt i can it comes for a second then goes away in the boot screen. After the boot sequence fails the screen is blank with a single _.
dmesg is showing the kernel version of the boot drive. If you look into in the grub.cfg the kernel version is 4.19.91.
How do I access the dmesg with chroot?
In post #9, you show dmesg.
The first lines of dmesg shows the kernel version:
[ 0.000000] Linux version 4.19.28-1-MANJARO (builduser@development) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Sun Mar 10 08:32:42 UTC 2019
