failing to install rufus in manjaro
can't find rufus in user repo or AUR an dthe downloads link that's in the rufus website is a .exe file . Can't use etcher as im gonna use that for windows. How can I install rufus in mnajaro gnome
Use woeusb to flash windows ISO on USB disk
Rufus is only on windows
getting one weird error in woeUSB
https://gyazo.com/895516d0649e471e75d90e83079dbb3e
Remove all partitions on the USB stick and create one with all free space in format NTFS, and try it again, to do that use eg.: gparted
also, try to unmount the NTFS partition(Right click on the partition in gparted and there will be option unmount so click that, Not the whole USB stick just the partition) and then let the woeusb flash it
now im getting an error on formatting
Use gparted, that should work
also, close all file managers that has opened the usb or some partition from the usb
the problem is when i try to open my usb device after formatting it throws an error
https://gyazo.com/08fa7c6c43b1191c0e755c2a65d1a93a
i wonder if that is causing the error
Try this
instead of the sdX put your id of the NTFS partition you created
mount /dev/sdX /mnt
You cannot - Windows only.
Manual creation of a Windows bootable USB from a Windows ISO using the terminal.
Remove your USB stick and open a terminal and list known disk devices
lsblk -la
Insert your USB stick and list your devices one more time
lsblk -la
Make a note of the extra device listed. If you only have one disk then it will probably be /dev/sdb.
Please do double check the device id
In the terminal clear the disk of any partition info, using this command (replace X with device letter from above).
sudo dd if=/dev/zero of=/dev/sdX bs=1M count=10 oflag=sync
Then use fdisk to create the filesystem needed for the Windows ISO (replace X with device letter from above).
sudo fdisk /dev/sdX
The commands in fdisk is as follows
  1. o - create a new empty DOS partition table
  2. n - add a new partition
  3. Enter - accept default partition type primary
  4. Enter - accept default partition number 1
  5. Enter - accept default first sector 2048
  6. Enter - accept default last sector
  7. t - change partition type
  8. c - select W95 FAT32 (LBA)
  9. a - set bootable flag for partition 1
  10. w - write changes to disk
Now format the device to FAT32 (replace X with device letter from above).
sudo mkfs.vfat -F 32 /dev/sdX1
  1. Rightclick your ISO file using your file manager and select Open with...Disk Image Mounter
  2. Select all files using Ctrla.
  3. Copy the files to your clipboard using Ctrlc
  4. Use your file manager to open your USB stick and paste the files using Ctrlv
This operation is going to take a long time and is all depending on your USB port speed and your USB.
When the copy is done - use the eject function of your file manager to eject the USB device and wait until all data is written to it.
When all data is flushed to the device and you can safely remove it you should be able to boot to your Windows install media.
Created a HowTo from this
this is what shows on the first command.
is everything ok? my 8GB RAM isn't showing
https://gyazo.com/8751c5fb74ded27f84f43423f1297582
Your USB is not listed.
Insert your usb and repeat
And ram is not shown - only block devices (disks)
theres no option for open with disc image mounter
https://gyazo.com/7a74791cf6b6db2ccda2c83a98389cdf
It is a part of gnome-disk-utility package installed by default.
Click View all applications and locate it.
yeah found that
you see the file that's selected here
i did the same to it but nothing opens up.
where would I ctrl + a then?
https://gyazo.com/ae68ee7e41a2d51625ab492c7f02a53e
.part files is files which is not fully downloaded.
You should also ensure the file is complete and the checksums match.
now i did with the fully downloaded file
https://gyazo.com/807619e32a235599642fb4f6334c53f8
and this is what shows
https://gyazo.com/cab8df73b619cde3072254cf72b6dfee
and as usual nothing is opening up
so im basically stuck with these steps
https://gyazo.com/07f48f7bbcc58d8fb297672a241cf99d
Then try following the part after the USB formatting from the new HowTo
see this is what i get
https://gyazo.com/d9262a5d156b608effa0fc4636d9469f
Please don't post screenshots of text outputs. Paste the text and use the </> button to make it preformatted text.
Also, in the last command remove the space after Downloads
