When I open my application launcher it shows two firefox icons which although run normally as tehy should. The problem is the shortcut iI set for firefox Ctrl+Alt+F
does not work. I have deleted and again set that shortcut but it doesn't work. I think somehow the two things are related.
I am running KDE Plasma latest stable version.
Right click, remove from favourites.
As to the shortcut, it shouldn't have any effect at all. Try resetting the shortcut to say super+f - does that work?
Yeah I removed it from favourites.
No, Super+f also does not work.
I didnt changed any firefox settings after installation. I don't understand why its happening. All my other Ctrl+Alt
combinations work like for konsole.
That is weird, can you post a screenshot of the firefox hotkey settings?
Do other hotkeys work?
What does:
which firefox
return?
Remove it and re-setup in custom shortcuts, that is the only thing I can think of.
Although I was looking why that thing didn't worked but this works just fine too. Thanks.
