From KDE Plasma to I3
Hi
I have Manjaro KDE Plasma installed.
Now i installed I3wm
When logging off en choosing I3 it runs, after reboot it starts KDE Plasma again.
Where do i configure that I3 has to be started??
.xinitrc in $HOME didn't do it...
Any pointers?
Thanks!
Ray
Dutch thread: Van Kde Plasma naar I3
You probably set KDE Plasma to Auto Login. Go to Settings > Startup and Shutdown > Login Screen (SDDM) and in Advanced tab set your session to the prefer one or disable Auto Login checkmark then Apply.
Well i want to auto login with I3 instead of KDE Plasma...
Can that also be accomplished for I3?
Ah! See it now, thanks!
Ray
