[Gamemode] Command executed successfully?
Hi.
Can someone please confirm that the everything has been executed successfully?
[zeno@linux-box ~]$ sudo pacman -S lib32-gamemode gamemode
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for zeno:
resolving dependencies...
Packages (2) gamemode-1.5.1-1  lib32-gamemode-1.5.1-1
Total Download Size:   0.09 MiB
Total Installed Size:  0.32 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 gamemode-1.5.1-1...    83.4 KiB  3.39 MiB/s 00:00 [##########] 100%
 lib32-gamemode-1...    10.8 KiB  0.00   B/s 00:00 [##########] 100%
(2/2) checking keys in keyring                     [##########] 100%
(2/2) checking package integrity                   [##########] 100%
(2/2) loading package files                        [##########] 100%
(2/2) checking for file conflicts                  [##########] 100%
(2/2) checking available disk space                [##########] 100%
(1/2) installing gamemode                          [##########] 100%
Optional dependencies for gamemode
    systemd [installed]
(2/2) installing lib32-gamemode                    [##########] 100%
(1/1) Arming ConditionNeedsUpdate...
[zeno@linux-box ~]$ systemctl --user enable gamemoded
Created symlink /home/zeno/.config/systemd/user/default.target.wants/gamemoded.service → /usr/lib/systemd/user/gamemoded.service.
[zeno@linux-box ~]$ systemctl --user start gamemoded
[zeno@linux-box ~]$
Much obliged!
Your system can tell you with
systemctl --user status gamemoded
This did the trick! Thanks a lot :slight_smile:
