Sharing the experience of a fresh install of XFCE Manjaro 18.0 by and explaining some hiccups that came up and how they were solved (or disappeared).
Creation of boot USB, live boot and installation went without a hitch. Here is the method I prefer: [howto] writing Manjaro ISOs to USB with dd
Followed these guidelines for updating using
pacman
. [wiki] UPDATES and IMPORTANT pacman knowledge ; Applying manjaro update from TTY ; rebooted the system. -
First problem was the absence of tab-completion in terminal emulator which was fixed with help from the forum. Tab-completion shows installed executables instead of package names after pacman in terminal
Second problem was xfce4-display-settings crashing showing a segmentation fault. Similar problems were reported on the forum. Time restrictions forced me to shut down to fix later and this apparently fixed the issue (without it being my intention). Seems that a reboot alone was not sufficient for some of the updates (?
Third problem was the inability to suspend. Here is the thread for what worked for me (so far). Sporadic problems with suspend . NOTE: It involves switching to kernel 4.18. 4.19 might get a fix in near future.
UPDATE: problem in 4.19 fixed in this stable update. -
Last and most subtle problem was display not blanking as configured in xfce4-power-manager. Got it working satisfactory for me with this: Xfce power management settings for display has no effect . At least one of the display modes (blank, stand-by or power-off) are triggered requiring a password on resume and suspends after inactivity as configured. Not really a solution and the real problem is still unknown to me, but "if it works it ain't stupid", right?
I also picked up that a special character map was missing which I use often for characters with " or ^ on top. Just installed
gucharmap
to fix this. -
That's it. Everything else seems to be in working order. PDF files open up, multiple audio and video formats play without any problems. None of that "install
ubuntu-extras
" for those familiar with Ubuntu seems to be necessary.
Now it just a matter of tailoring it to suit me as a daily driver ..
