Give root access to Pulseaudio
I'm using ffmpeg to capture my screen. I'm using the kmsgrab device to get video directly from the video card which is a lot more efficient than using x11grab. kmsgrab requires superuser privileges to work correctly, and I invoke those privileges using pkexec, as I am recording the desktop of a non-sudo user. This means that ffmpeg is running under a different user and can no longer access pulseaudio, even with superuser privileges.
I am aware of the option of running pulseaudio system-wide, but I'd like to avoid this as it is a potential security issue. Is there a way of giving only root access to pulseaudio temporarily?
A workaround would be to record audio separately and then merge audio and video, but I'm worried about running into synchronization issues.
Did you already try pulseaudio -D as root?
If you are aware of the implications and the potential risks imposed
Even if it is a bad idea - it is your system - and your responsibility
https://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/
Summary
Summary
