Gnome integration for pamac
For some time, gnome has had really neat integration between gnome-shell and gnome-software. You can click application launcher icons. Many other distros like Fedora and Ubuntu use gnome-software as their package manager frontend. However, for Manjaro, there are many reasons not to do the same. For one, gnome-software runs as 300Mb background process, and as a package manager it simply isn't as powerful as pamac.
Now, you don't need gnome-software to get that sweet sweet integration
In gnome-control-center, applications tab lets you open apps in pamac:
Screenshot from 2020-03-17 15-41-21
You can also open apps in pamac by right clicking them in gnome-shell app drawer. And if you search for an app you don't have, pamac offers to install it for you:
Provided by pamac-gnome-integration package.
Huge thanks for @guinux for making this awesome application!
That's great! What if you also add a "remove" button? Could be a very neat feature to remove applications from the context-menu.
That exists for Cinnamon via the cinnamon-remove-application AUR package. I wonder if it can be ported to GNOME?
The Show Details menu entry allows you to remove the app in three clicks.
True. But what if the context menu would allow you to remove it directly from there? Like you can with appimages...
@Chrysostomus @guinux
Is pamac-gnome-integration intentionally conflicting with gnome-software?
Yes, they have conflicting files. They provide the same shortcut in the menu. Alternative implementation that would have allowed to use them side by side would have been too much work.
I see, thanks for the explanation!
