Goldendict Strange CPU Usage
When I open Goldendict application it cause high CPU and GPU usage :confused:
Is this Manjaro problem or should I make a bug report.
Thanks
Description:Manjaro Linux
Release: 16.10
Codename: Fringilla
Kernel : 4.8.9-1
I start goldendict and search for 3 words
qt5ct: using qt5ct plugin
libpng warning: iCCP: known incorrect sRGB profile
qt5ct: D-Bus system tray: no
Load done
Dsl: Building the full-text index for dictionary: Urban Dictionary (En-En)
getResource: gdlookup://localhost?blank=1
scheme: gdlookup
host: localhost
scheme: gdlookup
host: localhost
getResource: gdlookup://localhost?word=Welcome!&group=4294967295
scheme: gdlookup
host: localhost
In-place finish.
====reading 16384 bytes
getResource: gdlookup://localhost?word=senior&group=4294967294&muted=a4854414ace46926d3c5105b75f5a58c,28a9d518398766e8d15c5b18c9fd5beb,663b6dcb768a7e35a4fa8131953653cd,ae6f89aac7151829681b85f035d54e48,624f04b92a199cc539b56c5047c5cb4a
scheme: gdlookup
host: localhost
some body finished
one finished.
erasing..
erase done..
one finished.
erasing..
erase done..
one not finished.
getResource: gico://b7ac05149cf731233ca129121e0a71ae/dicticon.png
scheme: gico
host: b7ac05149cf731233ca129121e0a71ae
In-place finish.
offset = 3f2b064
some body finished
one not finished.
offset = 5a294d2
offset = 4bf67fe
Warning: no corresponding opening tag for closing tag "m" found in "Longman DOCE 5th Ed. (En-En)", article "Senior".
offset = 5a2a550
some body finished
one not finished.
Warning: no corresponding opening tag for closing tag "m" found in "Longman DOCE 5th Ed. (En-En)", article "senior".
some body finished
one finished.
erasing..
erase done..
one finished.
erasing..
erase done..
one finished.
erasing..
erase done..
getResource: gico://8053257415949e9f25fdbc2bed17e38b/dicticon.png
scheme: gico
host: 8053257415949e9f25fdbc2bed17e38b
In-place finish.
getResource: gico://58f8c9264a0f57db47001f27d5377123/dicticon.png
scheme: gico
host: 58f8c9264a0f57db47001f27d5377123
In-place finish.
getResource: gico://fec3cf80d02b857c4b6da546c4827381/dicticon.png
scheme: gico
host: fec3cf80d02b857c4b6da546c4827381
In-place finish.
getResource: gdlookup://localhost?word=fish&group=4294967294&muted=a4854414ace46926d3c5105b75f5a58c,28a9d518398766e8d15c5b18c9fd5beb,663b6dcb768a7e35a4fa8131953653cd,ae6f89aac7151829681b85f035d54e48,624f04b92a199cc539b56c5047c5cb4a
scheme: gdlookup
host: localhost
some body finished
one not finished.
offset = 260207c
offset = 1af74b2
some body finished
one not finished.
some body finished
one finished.
erasing..
erase done..
one finished.
erasing..
erase done..
one not finished.
Warning: no corresponding opening tag for closing tag "m" found in "Longman DOCE 5th Ed. (En-En)", article "Fish".
offset = 26026a0
Warning: no corresponding opening tag for closing tag "m" found in "Longman DOCE 5th Ed. (En-En)", article "fish".
some body finished
one finished.
erasing..
erase done..
one not finished.
getResource: bres://8053257415949e9f25fdbc2bed17e38b/perch.jpg
scheme: bres
n is /home/mgundogdu/Manjaro_Files/GoldenDictionaries/longman 5th only text/perch.jpg
DSL: Failed loading resource "perch.jpg" for "Longman DOCE 5th Ed. (En-En)", reason: Can't open /home/mgundogdu/Manjaro_Files/GoldenDictionaries/longman 5th only text/En-En-Longman_DOCE5.dsl.files/perch.jpg: No such file or directory
In-place finish.
offset = 1fc25ea
offset = 1fc4374
some body finished
one not finished.
some body finished
one finished.
erasing..
erase done..
one finished.
erasing..
erase done..
getResource: gdlookup://localhost?word=cursor&group=4294967294&muted=a4854414ace46926d3c5105b75f5a58c,28a9d518398766e8d15c5b18c9fd5beb,663b6dcb768a7e35a4fa8131953653cd,ae6f89aac7151829681b85f035d54e48,624f04b92a199cc539b56c5047c5cb4a
scheme: gdlookup
host: localhost
offset = 1844ee8
offset = 123aed4
offset = 154d2bc
some body finished
one finished.
erasing..
erase done..
one finished.
erasing..
erase done..
one not finished.
Warning: no corresponding opening tag for closing tag "m" found in "Longman DOCE 5th Ed. (En-En)", article "cursor".
some body finished
one finished.
erasing..
erase done..
one not finished.
some body finished
one finished.
erasing..
erase done..
one not finished.
some body finished
one finished.
erasing..
erase done..
inxi -s result during goldendict running 2 minute
Sensors:   System Temperatures: cpu: 73.0C mobo: 72.0C
           Fan Speeds (in rpm): cpu: N/A
inxi -s result after shut goldendict 5 minutes
Sensors:   System Temperatures: cpu: 49.0C mobo: 49.0C
you should probably contact the developer of GoldenDict
Thanks. I just want to be sure :slight_smile:
Then people says: Hımm you are using Manjaro maybe its Manjaro issue :slight_smile:
Never heard of this program. Installed, runs fine.
One question - why did I immediately look up a rude word? :blush:
It is already reported
Goldendict high CPU usage
Just disable fultext search :slight_smile:
Everything is fine after that
