gpg: keyserver receive failed: General error
I am trying to install docky and i need to import the key.
After gpg --recv-keys <key> i get
I really like docky :slight_smile: is it doable?
See if the following post will work for you:
Thanks, it works :slight_smile: but what is the root of the problem? No fallback keyservers?
Looks like the keyserver being used has had some issues recently. If I am not mistaken due to an expired SSL certificate (I read somewhere). And apparently no fallback servers.
You can change the keyserver adding: keyserver pool.sks-keyservers.net
in /etc/pacman.d/gnupg/gpg.conf for pacman,
and ~/.gnupg/gpg.conf for aur.
For me this keyserver works without problems but may not for you.
@Marte
Thanks this solved my issue.
Welcome to Manjaro Forum @swmiller6!
Glad you got your issue resolved!
