Graphics (and other) issues
my reason is that i never used linux before, as i said, so i had no clue what's going on, but sure i cannot learn it if i only read about it, so i jumped, i try
i chose gnome on manjaro- obviously, but i like split screen on fm, and also i like to be free, what i choose to appear on the surface/menu... (i know probably i can do this with nautilus too, but i don't even dare to imagine about asking it; how :smiley: )
i found this dolphin the match, i swapped, but i'm not sure if could ever be able to find this things watching youtube videos :slight_smile:
now i understand this part
i'm considering it
i just didn't wanna write here with this thing straightaway, so i tried to look for it, and be a bit more self-sufficient as it was suggested
i've been lookin a lot, and to me seemed, that there is solution and i saw i'm not the only with this, i said to myself, i ask it here, as they spoke not beginner friendly language :smiley:
i wrote
because it is really not a big deal, at least now i have also learnt, i need to be a bit more attentive what or how i write here
i knew about that exist kde and gnome and etc but they said i can manage to change anything in case, in fact i did change, but came out this tiny issue
i appreciate your help anyway, sorry for essay
anyway as u can see i've got much more serious problem with the graphics, i should concentrate on that, but i'm stucked and waiting for some update, or a noob-friendly-pro.
for now that's the best i'm able to do :slight_smile:
the only main thing is not to go back to K%C3%A9perny%C5%91k%C3%A9p%20%E2%80%93%202018-10-20%2021-07-49
You can use nemo or PcmanFM-gtk3 or even spacefm they are all split screen the later is quatro split screen, all work better on gnome than dolphin,
yeah, i also saw nemo, i chose dolphin randomly.. sure i give it a go, now that i know what r better for gnome
thanks
Hi
I swapped to kde, this time I chose free option, after I set it up, I did the same commands
Would you guys have a look, if this time looks any better?
Plus I catched a few times (even before, on gnome/deepin) a display bug. Once in a while a line appears on the top of the screen- like 5 pixels wide- with pinky-vibrant colors. It takes less than a second. The other thing is, that I set the scaling to 1.1, and some part of the surface r not smooth. Is this a system bug, or also I can give the credit to my CPU?
Apart from these it looks fine.
Screenshot_20181022_132500
The logs:
-- Logs begin at Sun 2018-10-21 23:05:53 CEST, end at Mon 2018-10-22 12:34:50 CEST. --
okt 22 11:17:54 beelinkx55-pc kcheckpass[3501]: pam_tally(kde:auth): Error opening /var/log/faillog for update
okt 22 11:17:54 beelinkx55-pc kcheckpass[3501]: pam_tally(kde:auth): Error opening /var/log/faillog for read
okt 22 11:17:54 beelinkx55-pc kcheckpass[3501]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
okt 22 11:38:42 beelinkx55-pc knshandler[4242]: org.kde.knewstuff.core: Could not determine type of archive file ' "/tmp/DOtQUu-Numix.colors" '
okt 22 11:43:17 beelinkx55-pc systemsettings5[1948]: org.kde.knewstuff.core: Could not determine type of archive file ' "/tmp/cAbash-106536-GT3-colors-pack.rar" '
okt 22 12:19:01 beelinkx55-pc kcheckpass[6211]: pam_tally(kde:auth): Error opening /var/log/faillog for update
okt 22 12:19:01 beelinkx55-pc kcheckpass[6211]: pam_tally(kde:auth): Error opening /var/log/faillog for read
okt 22 12:19:01 beelinkx55-pc kcheckpass[6211]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
0: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
1: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
These are not important errors, actually informative.
You may correct them:
pam_tally is deprecated and superseded by pam_tally2, so you will want to comment out the pam_tally line:
#auth required pam_tally.so onerr=succeed file=/var/log/faillog
From Archwiki
What about performance? Is it improved, comparing to Gnome?
That line maybe a theme feature.
Well, on gnome I had mainly the launcher lag, on deepin was not such an issue, in fact that was flying, 15secs to boot. (kde about 30s).
But with kde apart from that small issues, seems quite good. Plus sometimes shows up a line also in terminal, that remains, until I open screenshot to make a proof. :smiley:
Just by curiosity I installed 0AD, it's laggy, but no surprise with this pc.
After I quit, the whole display was flashing. :open_mouth:
Now I try what u wrote, if I can handle :slight_smile:
Thanks
-- Logs begin at Sun 2018-10-21 23:05:53 CEST, end at Mon 2018-10-22 20:01:36 CEST. --
-- No entries --
better now?
e
nothing, sorry, I don't know what I do, it's the same, better if I just use as it is :smiley:
-- Logs begin at Sun 2018-10-21 23:05:53 CEST, end at Mon 2018-10-22 20:06:46 CEST. --
okt 21 23:05:53 beelinkx55-pc kernel: tpm tpm0: TPM self test failed
okt 21 23:13:56 beelinkx55-pc kernel: usb usb2-port1: cannot disable (err = -32)
okt 21 23:13:56 beelinkx55-pc systemd-udevd[1513]: inotify_add_watch(9, /dev/sdb, 10) failed: No such file or directory
okt 21 23:51:23 beelinkx55-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
okt 21 23:51:38 beelinkx55-pc kernel: tpm tpm0: TPM self test failed
okt 22 00:48:09 beelinkx55-pc kcheckpass[13208]: pam_tally(kde:auth): Error opening /var/log/faillog for update
okt 22 00:48:09 beelinkx55-pc kcheckpass[13208]: pam_tally(kde:auth): Error opening /var/log/faillog for read
okt 22 00:48:09 beelinkx55-pc kcheckpass[13208]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
okt 22 01:03:01 beelinkx55-pc crond[353]: (root) CAN'T OPEN (/etc/crontab): Nincs ilyen fájl vagy könyvtár
okt 22 01:11:08 beelinkx55-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
okt 22 11:38:42 beelinkx55-pc knshandler[4242]: org.kde.knewstuff.core: Could not determine type of archive file ' "/tmp/DOtQUu-Numix.colo>
okt 22 11:43:17 beelinkx55-pc systemsettings5[1948]: org.kde.knewstuff.core: Could not determine type of archive file ' "/tmp/cAbash-10653>
okt 22 13:35:35 beelinkx55-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
okt 22 13:51:08 beelinkx55-pc NetworkManager[367]: <error> [1540209068.6169] audit: failed to open auditd socket: A protokoll nem támogato>
-- Reboot --
okt 22 13:54:47 beelinkx55-pc kernel: ata1.00: failed to set xfermode (err_mask=0x40)
okt 22 14:06:29 beelinkx55-pc kcheckpass[1107]: pam_tally(kde:auth): Error opening /var/log/faillog for update
okt 22 14:06:29 beelinkx55-pc kcheckpass[1107]: pam_tally(kde:auth): Error opening /var/log/faillog for read
okt 22 14:06:29 beelinkx55-pc kcheckpass[1107]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
okt 22 15:00:41 beelinkx55-pc sudo[4977]:      ii9 : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp-ii9/aur-uvesafb-dkms ; USER=>
okt 22 15:01:55 beelinkx55-pc sudo[7648]:      ii9 : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp-ii9/aur-uvesafb-dkms ; USER=>
okt 22 15:06:33 beelinkx55-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
okt 22 15:37:46 beelinkx55-pc kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
okt 22 16:27:37 beelinkx55-pc systemd-coredump[3187]: Process 3171 (systemsettings5) of user 1000 dumped core.
                                                      Stack trace of thread 3171:
                                                      #0  0x00007f4790a22210 _ZN12KQuickAddons12ConfigModule9needsSaveEv (libKF5QuickAddon>
                                                      #1  0x00007f4790b556cc n/a (libKF5KCMUtils.so.5)
                                                      #2  0x00007f478f655bd0 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                                      #3  0x00007f477d64c8be n/a (kcm_launchfeedback.so)
                                                      #4  0x00007f477d64f06b n/a (kcm_launchfeedback.so)
                                                      #5  0x00007f478e7a65b5 _ZN3QV414QObjectWrapper11setPropertyEPNS_15ExecutionEngineEP7>
                                                      #6  0x00007f478e7a733f _ZN3QV414QObjectWrapper14setQmlPropertyEPNS_15ExecutionEngine>
                                                      #7  0x00007f478e7a7436 _ZN3QV414QObjectWrapper3putEPNS_7ManagedEPNS_6StringERKNS_5Va>
                                                      #8  0x00007f478e7ba66c _ZN3QV47Runtime20method_storePropertyEPNS_15ExecutionEngineER>
                                                      #9  0x00007f478e7c625a n/a (libQt5Qml.so.5)
                                                      #10 0x00007f47700663bd n/a (n/a)
                                                      #11 0x00007f478e7b1ba4 n/a (libQt5Qml.so.5)
                                                      #12 0x00007f478e88bfbe n/a (libQt5Qml.so.5)
                                                      #13 0x00007f478e88c437 n/a (libQt5Qml.so.5)
                                                      #14 0x00007f478f656352 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                                      #15 0x00007f4790036e14 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (li>
                                                      #16 0x00007f479003e6e1 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.>
                                                      #17 0x00007f478f62bc39 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (lib>
                                                      #18 0x00007f478f62eccc _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11Q>
                                                      #19 0x00007f478f67f9d4 n/a (libQt5Core.so.5)
                                                      #20 0x00007f478cd5a3cf g_main_context_dispatch (libglib-2.0.so.0)
                                                      #21 0x00007f478cd5bf89 n/a (libglib-2.0.so.0)
                                                      #22 0x00007f478cd5bfce g_main_context_iteration (libglib-2.0.so.0)
                                                      #23 0x00007f478f67efc9 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoo>
                                                      #24 0x00007f4788ef5e12 n/a (libQt5XcbQpa.so.5)
                                                      #25 0x00007f478f62a8cc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5>
                                                      #26 0x00007f478f632bc6 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                                      #27 0x00005602413e9465 n/a (systemsettings5)
                                                      #28 0x00007f478f08b223 __libc_start_main (libc.so.6)
                                                      #29 0x00005602413e94ee _start (systemsettings5)
                                                      Stack trace of thread 3173:
                                                      #0  0x00007f478f157c21 __poll (libc.so.6)
                                                      #1  0x00007f478d9cb630 n/a (libxcb.so.1)
                                                      #2  0x00007f478d9cd2db xcb_wait_for_event (libxcb.so.1)
                                                      #3  0x00007f4788e5fc5a n/a (libQt5XcbQpa.so.5)
                                                      #4  0x00007f478f47df65 n/a (libQt5Core.so.5)
                                                      #5  0x00007f478da0aa9d start_thread (libpthread.so.0)
                                                      #6  0x00007f478f162b23 __clone (libc.so.6)
                                                      Stack trace of thread 3174:
                                                      #1  0x00007f478cd5bee0 n/a (libglib-2.0.so.0)
                                                      #2  0x00007f478cd5bfce g_main_context_iteration (libglib-2.0.so.0)
                                                      #3  0x00007f478f67efc9 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoo>
                                                      #4  0x00007f478f62a8cc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5>
                                                      #5  0x00007f478f473eb9 _ZN7QThread4execEv (libQt5Core.so.5)
                                                      #6  0x00007f478f8d0ba6 n/a (libQt5DBus.so.5)
                                                      #7  0x00007f478f47df65 n/a (libQt5Core.so.5)
                                                      #8  0x00007f478da0aa9d start_thread (libpthread.so.0)
                                                      #9  0x00007f478f162b23 __clone (libc.so.6)
                                                      Stack trace of thread 3181:
                                                      #6  0x00007f478e88e859 n/a (libQt5Qml.so.5)
                                                      Stack trace of thread 3175:
                                                      #0  0x00007f478da10afc pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                                      #1  0x00007f477f6211ac n/a (i965_dri.so)
                                                      #2  0x00007f477f620ee8 n/a (i965_dri.so)
                                                      #3  0x00007f478da0aa9d start_thread (libpthread.so.0)
                                                      #4  0x00007f478f162b23 __clone (libc.so.6)
okt 22 16:31:49 beelinkx55-pc systemd-coredump[3722]: Failed to send coredump datagram: Connection reset by peer
-- Reboot --
okt 22 18:50:22 beelinkx55-pc kglobalaccel5[14819]: Could not connect to any X display.
okt 22 20:00:18 beelinkx55-pc kernel: watchdog: watchdog0: watchdog did not stop!
Here is a neverseen-before beauty
Screenshot_20181022_210012
I also catched the terminals' brand-new fakematrix friend
Screenshot_20181022_210529
Set the compositor to OpenGL 3.1.
Post
cat /var/log/Xorg.0.log
I don't know if it's ok, or I did st wrong, but the first line is not the command as it used to be, I copy as it shows. I did set opengl 3.1
https://bpaste.net/show/b7e4b1b8dbca
This section is repeated many times:
[   360.429] (II) modeset(0): EDID vendor "GSM", prod id 23025
[   360.429] (II) modeset(0): Using hsync ranges from config file
[   360.429] (II) modeset(0): Using vrefresh ranges from config file
[   360.429] (II) modeset(0): Printing DDC gathered Modelines:
[   360.429] (II) modeset(0): Modeline "2560x1080"x0.0  185.58  2560 2624 2688 2784  1080 1083 1093 1111 -hsync -vsync (66.7 kHz eP)
[   360.429] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   360.429] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[   360.429] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   360.429] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   360.429] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   360.429] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   360.429] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   360.429] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   360.429] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   360.429] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   360.429] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   360.429] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   360.429] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   360.429] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   360.429] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   360.429] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   360.429] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   360.429] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   360.429] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[   360.429] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
Please don't paste walls of repeated text in the forum.
Either pick out the relevant parts, or paste them in full to a pastebin site (e.g. bpaste.net) and link to them here.
I wish I could find out which part is the relevant. Shall I delete it?
Or if it's urgent I ask u to do so.
I've fixed up the posts.
Something to consider is that the laptop isn't Linux-compatible and isn't going to work well, no matter what you do.
You should definitely try kernels 4.18 and 4.19 though, to see if they add/improve support for your hardware.
Actually, you left out the beginning of the Xorg log file, which includes relevant info. :smile:
Please, post the full log to a paste-bin service.
Also post
journalctl -b -k -g "intel|i915|drm"
cat /etc/modprobe.d/*.conf
not that we can surely find a solution, but rather for reference and more eyes can see it..
Have you adjusted the compositor?
̶T̶h̶e̶ ̶t̶h̶i̶n̶g̶ ̶i̶s̶,̶ ̶t̶h̶a̶t̶ ̶j̶o̶n̶a̶t̶h̶o̶n̶ ̶a̶l̶s̶o̶ ̶d̶e̶l̶e̶t̶e̶d̶ ̶m̶y̶ ̶c̶o̶m̶m̶e̶n̶t̶,̶ ̶a̶c̶t̶u̶a̶l̶l̶y̶ ̶I̶ ̶w̶r̶o̶t̶e̶ ̶t̶h̶a̶t̶ ̶I̶ ̶d̶i̶d̶ ̶s̶e̶t̶ ̶t̶o̶ ̶o̶p̶e̶n̶g̶l̶ ̶3̶.̶1̶,̶ ̶a̶n̶d̶ ̶w̶h̶e̶n̶ ̶I̶ ̶p̶u̶t̶ ̶t̶h̶e̶ ̶c̶o̶m̶m̶a̶n̶d̶,̶ ̶I̶ ̶g̶o̶ ̶t̶o̶ ̶t̶h̶e̶ ̶b̶e̶g̶i̶n̶n̶i̶n̶g̶,̶ ̶i̶t̶ ̶s̶t̶a̶r̶t̶s̶ ̶w̶i̶t̶h̶ ̶t̶h̶e̶ ̶l̶i̶n̶e̶,̶ ̶i̶n̶s̶t̶e̶a̶d̶ ̶o̶f̶ ̶t̶h̶e̶ ̶u̶s̶u̶a̶l̶ ̶[̶i̶i̶9̶@̶b̶e̶e̶l̶i̶n̶k̶x̶5̶5̶-̶p̶c̶ ̶~̶]̶$̶.̶.̶.̶.̶:̶
fixed
[ 10.715] (II) Initializing extension XFree86-DRI...
This time, this is the first line, it's so long, that I needed to paste it in two boxes and got warned :slight_smile:
So I cannot see the part, that u mean.
The others
-- Logs begin at Sun 2018-10-21 23:05:53 CEST, end at Tue 2018-10-23 10:05:36 CEST. --
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: DBG2 0x0000000079DD11F0 000072 (v00 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: DBGP 0x0000000079DD1270 000034 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: HPET 0x0000000079DD12B0 000038 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: LPIT 0x0000000079DD12F0 00005C (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: APIC 0x0000000079DD1350 000084 (v04 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: NPKT 0x0000000079DD13E0 000065 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: SSDT 0x0000000079DD1450 003E72 (v02 INTEL  DptfTab  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: SSDT 0x0000000079DD52D0 00153E (v01 Intel_ Platform 00001000 INTL 20160930)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: SSDT 0x0000000079DD6810 0000B1 (v01 Intel_ ADebTabl 00001000 INTL 20160930)
okt 23 09:56:12 beelinkx55-pc kernel: ACPI: DMAR 0x0000000079DDA4C0 0000A8 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
okt 23 09:56:12 beelinkx55-pc kernel: Reserving Intel graphics memory at 0x000000007c000000-0x000000007fffffff
okt 23 09:56:12 beelinkx55-pc kernel: smpboot: CPU0: Intel(R) Pentium(R) Silver J5005 CPU @ 1.50GHz (family: 0x6, model: 0x7a, stepping>
okt 23 09:56:12 beelinkx55-pc kernel: Performance Events: PEBS fmt3+, Goldmont plus events, 32-deep LBR, full-width counters, Intel PMU>
okt 23 09:56:12 beelinkx55-pc kernel: intel_idle: MWAIT substates: 0x11242020
okt 23 09:56:12 beelinkx55-pc kernel: intel_idle: v0.4.1 model 0x7A
okt 23 09:56:12 beelinkx55-pc kernel: intel_idle: lapic_timer_reliable_states 0xffffffff
okt 23 09:56:12 beelinkx55-pc kernel: intel_pstate: Intel P-state driver initializing
okt 23 09:56:12 beelinkx55-pc kernel: intel_rdt: Intel RDT L2 allocation detected
okt 23 09:56:12 beelinkx55-pc kernel: input: Intel HID events as /devices/platform/INT33D5:00/input/input3
okt 23 09:56:12 beelinkx55-pc kernel: intel-hid INT33D5:00: platform supports 5 button array
okt 23 09:56:12 beelinkx55-pc kernel: input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input4
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.2: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.3: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.4: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.5: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.6: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.7: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.8: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.9: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.12: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.13: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: idma64 idma64.14: Found Intel integrated DMA 64-bit
okt 23 09:56:12 beelinkx55-pc kernel: Intel(R) Wireless WiFi driver for Linux
okt 23 09:56:12 beelinkx55-pc kernel: Copyright(c) 2003- 2015 Intel Corporation
okt 23 09:56:12 beelinkx55-pc kernel: Bluetooth: hci0: read Intel version: 370810011003110e00
okt 23 09:56:12 beelinkx55-pc kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
okt 23 09:56:12 beelinkx55-pc kernel: [drm] Memory usable by graphics device = 4096M
okt 23 09:56:12 beelinkx55-pc kernel: fb: switching to inteldrmfb from EFI VGA
okt 23 09:56:12 beelinkx55-pc kernel: [drm] Replacing VGA console driver
okt 23 09:56:12 beelinkx55-pc kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
okt 23 09:56:12 beelinkx55-pc kernel: [drm] Driver supports precise vblank timestamp query.
okt 23 09:56:12 beelinkx55-pc kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
okt 23 09:56:12 beelinkx55-pc kernel: [drm] Initialized i915 1.6.0 20170818 for 0000:00:02.0 on minor 0
okt 23 09:56:12 beelinkx55-pc kernel: [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
okt 23 09:56:12 beelinkx55-pc kernel: snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
okt 23 09:56:12 beelinkx55-pc kernel: iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
okt 23 09:56:12 beelinkx55-pc kernel: fbcon: inteldrmfb (fb0) is primary device
okt 23 09:56:13 beelinkx55-pc kernel: i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
okt 23 09:56:13 beelinkx55-pc kernel: intel_telemetry_core Init
okt 23 09:56:13 beelinkx55-pc kernel: intel_telemetry: version 1.0.0 loaded
okt 23 09:56:13 beelinkx55-pc kernel: Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated
okt 23 09:56:13 beelinkx55-pc kernel: intel_rapl: Found RAPL domain package
okt 23 09:56:13 beelinkx55-pc kernel: intel_rapl: Found RAPL domain core
okt 23 09:56:13 beelinkx55-pc kernel: intel_rapl: Found RAPL domain uncore
okt 23 09:56:13 beelinkx55-pc kernel: intel_rapl: Found RAPL domain dram
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:0e.0/sound/card0/input8
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:0e.0/sound/card0/input9
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input10
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input11
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input12
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input13
okt 23 09:56:13 beelinkx55-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input14
okt 23 09:56:14 beelinkx55-pc kernel: [drm] RC6 on
The second is quite short
blacklist r8169
Let me know, if there's a way to do the 1. command correct, thanks
I'll keep in mind, thanks
I'm almost sure, that I'm gonna ask now a total bull-sheet, but better if i learn (at least the reason), so I'll do, in worst case u r gonna laugh or do a facepalm :slight_smile:
Is it possible, to install the windows driver for Intel® UHD Graphics 605 through wine or st?
Didn't use wine yet, have no clue what it is able to do..
Or maybe I should go for pheonix os plus linux deploy for gimp or any multitasking.
Still it wouldn't solve my problem, but I could use the android for many things, and at least I'd be able to handle.
Do u have any xp with this option?
I tried
Nothing's changed :confused:
Nope.
Hey
I have some new info, maybe it helps to figure out the solution.
My problem is with the compositor, as if I press Shift-Alt-F12, all the flickering stop showing up. I can live without all the nice animations, but definitely would prefer to have them working without this issue. I tried all the option r given there in the settings, but all the same. Is there any chance, to tweak or anything, that I could give a try?
