Grub does not display anything but works
I'm on testing branch after updates wanted to reinstall grub because there were some updates for it but I see it does not display anything just black screen. I still can use keys to choose manjaro or windows. Here is my grub config.
I tried setting GRUB_GFXMODE to auto or 1366x768 (my screen resolution) but still the same.
I have laptop lenovo Z580 with Nvidia GeForce GT 630M + Intel HD Graphics 4000.
Please help, I can provide additional information if needed
It would be much better if you actually posted the contents of your grub file. Please open your grub file copy the contents and paste here using the </> in the formatting tools to properly format your posted text. Thanks
After some deep search i found it's a bug
Setting legacy support helped but it's a bit uncomfortable
You sure you don't just have it set to hidden instead of setting it for menu? In Manjaro it's the first thing I do after landing on the desktop. menu instead of hidden and timeout 30 seconds instead of 10.
Yeah im sure. I checked hidden, coutdown and menu
GRUB_DEFAULT="saved"
GRUB_TIMEOUT="3"
GRUB_TIMEOUT_STYLE="menu"
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="splash reboot=pci"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT="true"
GRUB_ENABLE_CRYPTODISK="y"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
#GRUB_GFXMODE="auto"
GRUB_GFXPAYLOAD_LINUX="keep"
#GRUB_DISABLE_LINUX_UUID="true"
# GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_COLOR_HIGHLIGHT="orange/black"
#GRUB_INIT_TUNE="480 440 1"
GRUB_THEME="/usr/share/grub/themes/Vimix/theme.txt"
#GRUB_DISABLE_LINUX_RECOVERY="true"
#GRUB_DISABLE_RECOVERY="true"
I never had the parentheses on GRUB_TIMEOUT or GRUB_TIMEOUT_STYLE.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=30
GRUB_TIMEOUT_STYLE=menu
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
But its not a problem. Config is fine. Grub works fine after enabled legacy support which is temporarily solutions to that bug
