Dears,
Today I have installed on my laptop Manjaro but the installation of boot loader failed.
After the first reboot, start the PXE boot cause the boot loader isn't installed correctly.
On my laptop I have 3 OS: Linux, Windows and OSX; with a legacy MBR / GPT partition table.
Here the disk partitions:
[4540s ~]# fdisk -l
Disk /dev/sda: 465,78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Hitachi HTS54505
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 86DAC89C-584F-4DC2-B723-E69600624999
Dispositivo Start Fine Settori Size Tipo
/dev/sda1 40 409639 409600 200M EFI System
/dev/sda2 409640 293378383 292968744 139,7G Apple HFS/HFS+
/dev/sda3 586610688 848328703 261718016 124,8G Linux filesystem
/dev/sda5 293640528 586609271 292968744 139,7G Microsoft basic data
/dev/sda7 880102304 976510983 96408680 46G Apple HFS/HFS+
Here the partition table GPT:
[4540s ~]# gdisk -l /dev/sda
GPT fdisk (gdisk) version 1.0.4
Partition table scan:
MBR: hybrid
BSD: not present
APM: not present
GPT: present
Found valid GPT with hybrid MBR; using GPT.
Disk /dev/sda: 976773168 sectors, 465.8 GiB
Model: Hitachi HTS54505
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): 86DAC89C-584F-4DC2-B723-E69600624999
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 976773134
Partitions will be aligned on 8-sector boundaries
Total free space is 32299317 sectors (15.4 GiB)
Number Start (sector) End (sector) Size Code Name
1 40 409639 200.0 MiB EF00 EFI System
2 409640 293378383 139.7 GiB AF00 Apple HFS/HFS+
3 586610688 848328703 124.8 GiB 8300
5 293640528 586609271 139.7 GiB 0700 Microsoft basic data
7 880102304 976510983 46.0 GiB AF00 Apple HFS/HFS+
Here the MBR data:
Disk size is 976773168 sectors (465.8 GiB)
MBR disk identifier: 0x00000000
MBR partitions:
Number Boot Start Sector End Sector Status Code
1 1 586610687 primary 0xEE
2 * 586610688 848328703 primary 0x83
To load Manjaro I have modified the MBR with gdisk, making the MBR hybrid with the boot on partition 3, now the error on startup is changed and I see the grub rescue.
With grub rescue I have load manually the grub configuration.
There is a way to install grub with legacy GPT (I have tried to install grub with grub-install but without success)? Or I have to use Chamaleon / Clover?
Thanks in advance for your support.
