After some updates GRUB window does not appear anymore on my imac.
I am currently running kernel 5.1.19-1.
Before I make any changes I just wanted to be sure these would not brake the installation.
I was wondering if changing the partition flags would help in way.
The /boot/efi/EFI/ directory already exists.
I was wondering if changing the flags using gparted would help.
Following is the partitions list,
And the flags for the bootable partition
I was wondering if setting the bios_grub
flag would help.
Following are the kernel parameters:
quiet radeon.dpm=0 acpi_backlight=vendor
Thanks a lot for your help
