Grub password prompt is not shown, when chained after Clover
Hey,
I'm currently working on a encrypted dual boot hackintosh with a chained bootloader CLOVER -> GRUB2. Individual both work great but combined I've got some graphic problems.
CLOVER works, but when loading the encrypted (is it encypted?) grubx64.efi the password prompt isn't shown anymore. It still works, when entering the correct password GRUB is shown.
Here's a video of the behavior:
https://streamable.com/wugo6
OS: Manjaro Linux x86_64
Host: Z370N WIFI
Kernel: 4.14.74-1-MANJARO
Resolution: 2560x1080
DE: Xfce
WM: Xfwm4
CPU: Intel i7-8700 (12) @ 4.600GHz
GPU: NVIDIA GeForce GTX 1060 6GB
Memory: 2428MiB / 15994MiB
Grub config:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="quiet cryptdevice=UUID=ae1756fe-1f42-417c-935d-cb95cc8f3255:luks-ae1756fe-1f42-417c-935d-cb95cc8f3255 root=/dev/mapper/luks-ae1756fe-1f42-417c-935d-cb95cc8f3255 resume=/dev/mapper/luks-ae1756fe-1f42-417c-935d-cb95cc8f3255"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
# Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT=5
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
# you can see them in real GRUB with the command `vbeinfo'
# GRUB_GFXMODE=auto
# changed by me, but had no effect
GRUB_GFXMODE=2560x1080
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
relevant Clover pList Entry:
<dict>
	<key>Disabled</key>
	<false/>
	<key>FullTitle</key>
	<string>Manjaro</string>
	<key>Hidden</key>
	<false/>
	<key>Ignore</key>
	<false/>
	<key>Path</key>
	<string>\EFI\Manjaro\grubx64.efi</string>
	<key>Type</key>
	<string>Linux</string>
	<key>Volume</key>
	<string>FC290B65-1A4B-4DA6-8F93-845406E550DC</string>
	<key>VolumeType</key>
	<string>Internal</string>
</dict>
Hackintosh issues should be addressed to the "dedicated" forum, not here. In the same time, multipurpose custom boot loader issues should be addressed to the developers of it, or simply check the documentation. With all that said, i'll give you a hint.
Manjaro prefers to use it's default boot loader for whatever multiboot systems installs.
Some info about here and here and another one here
Boot issues with Manjaro and it's particularities: encrypted or non encrypted, can be addressed here, and you will receive the proper replies; but you don't have such issue.
Personally i think this topic is way off topic and the purpose of this forum.
