Has anyone used hardened malloc ? Pros and cons
I am new to Arch and looking for ways to make my Manjaro installation secure. One interesting topic that I came across in the Security Page in Arch Wiki is the recommendation of using hardened malloc.
Does it replace all malloc functions on the system with hardened malloc ?
So has anyone used it ? Does it provide any benefits ? Does it give you a performance hit ?
What are you thoughts on this ?
Depending on how new you are (You only mention Manjaro, not your background):
  1. Seasoned Linux developer, wanting to become member of the Manjaro team and start testing by getting man to play nicely with hardened_malloc: Go for it! The Manjaro Team will welcome you!
  2. Manjaro user, doesn't even know that malloc() is memory allocation: Avoid it like the plague!
Oh, you're somewhere in-between? I'd advise it up to 1.1 and maybe 1.2, not for 1.3→1.9.
I wouldn't touch it with a 10-foot pole! (And I'm a 1.5 )
:innocent: :wink:
Well I am a developer but I am new to Linux. Is hardended_malloc needed to improve the security of your system ?
You mention that developers are using it. But my question is that is it needed if I want to secure my system ?
The reason I ask is because in comparison to Fedora which gives you certain security features enabled out of the box like SELinux. What does Manjaro give in this aspect ?
What do you mean by:
You're a 1.6: Don't touch it with a 10 foot pole!
¯\_(ツ)_/¯
What is your threat model? Which threats do you hope to prevent with hardended_malloc?
Are you saying that for a normal user it is unnecessary to go through the trouble of hardened_malloc ? I mean is it overkill ?
As to threat model you can say the reason I want to do this is make all malloc operations as secure as possible. So that I don't have any buffer overflows or heap vulnerabilities. I don't even know whether I have ASLR on by default.
I apologize for being blunt, but I still don't understand what you mean to say.
Sorry was off the grid. Yes, for a normal user who does not have a server on the Internet, it's total overkill.
Once you start developing your own applications, please use it!
man is the most used application for all *nix pros or would-be pros (=Manual) and even that stops working if you do a sed 's/malloc/hardened_malloc/g' *.c...
Or to quote a cliché: With extraordinary security comes extraordinary responsibility...
:slight_smile:
Yes, I think it is. Not all programs will work with it. So you have to carefully test and decide which one you want to start with LD_PRELOAD=... . Others might need a recompile with special options, otherwise hardened_malloc might have no effect.
But if you have time, want to experiment and don't need a stable system, go for it.
Then check it.
cat /proc/sys/kernel/randomize_va_space
https://www.kernel.org/doc/Documentation/sysctl/kernel.txt
search for "randomize_va_space:"
I am confused/curious as to why you think this. I would think that hardened_malloc is responsible for only the memory allocation, albeit in a secure way. It will still return allocated memory right ? So why do you think some applications wont work with it ?
MX Linux/Debian has hardening-runtime package that can just be installed with apt-get install hardening-runtime.
Does arch have something similar ? Will installing the linux-hardened package make a difference ?
The output of
is 2
So I guess ASLR is enabled with heap randomization.
I guess so I am trying to understand how many security measures are can I pack in to my install before I break it.
What can I say I might be a Linux noob but I am paranoid one.
:smile:
It's always about the use case:
  • if you have a server on the Internet: all these things matter.
  • If it's just a PC behing a NAT router: most of it is overkill, but hardened_malloc is especially dangerous. Take a full Cold System Backup
P.S. It's not because you're paranoid that they aren't out there to get you!
:stuck_out_tongue_winking_eye: :crazy_face:
This has nothing to do with hardened_malloc. It just sets some options to the kernel command line and add sysctl options. If you want to use them, add them to your config. No need to install a package for this.
Yes this has nothing to do with hardended_malloc but how do I go about adding them in my config ?
Anything in the Arch Wiki about this ?
add the Kernel options you want form the package to your grub GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub . Don't forget to run sudo update-grub after you changed the grub config file.
And put the sysctl config file form the package in /etc/sysctl.d , make sure it ends in .conf
Read up on what the options do, to avoid surprises.
Thank you so much for all your help.
