Having an issue with miniconda update using AUR packaging - Trying to upgrade miniconda 4.6 -> 4.7
Screenshot_20190802_122235
Post the actual output, not a screenshot.
Read the Comments https://aur.archlinux.org/packages/miniconda3/
jadelord commented on 2019-08-02 09:26
This package simply follows the pkgbuild of anaconda in AUR (https://aur.archlinux.org/packages/anaconda/). The packaging scripts have changed. There is no straightforward way to install 4.7.10 right now. If no solution surfaces then I would go back to the old version.
Users are discouraged to install miniconda3 as an AUR package as there is no official howto on packaging it in linux distros (https://github.com/conda/conda/issues/1235). You may be better served as just running:
curl -LO <https://repo.continuum.io/miniconda/Miniconda3-latest-Linux-x86_64.sh>
bash Miniconda3-latest-Linux-x86_64.sh -p /path/to/miniconda
lerhard commented on 2019-08-01 18:57
I cannot install the package due to:
==> Starting package()... -> Packaging miniconda3 for installation to /opt/miniconda3 PREFIX=/home/lukas/.cache/yay/miniconda3/pkg/miniconda3/opt/miniconda3 Unpacking payload ... [5169] mod is NULL - structTraceback (most recent call last): File "/spare/local/nwani/pyinstaller_stuff/dev/lib/python3.6/struct.py", line 13, in ModuleNotFoundError: No module named '_struct' [5169] mod is NULL - pyimod02_archiveTraceback (most recent call last): File "/spare/local/nwani/pyinstaller_stuff/dev/lib/python3.6/site-packages/PyInstaller/loader/pyimod02_archive.py", line 28, in ModuleNotFoundError: No module named 'struct' [5169] mod is NULL - pyimod03_importersTraceback (most recent call last):
File "/spare/local/nwani/pyinstaller_stuff/dev/lib/python3.6/site-packages/PyInstaller/loader/pyimod03_importers.py", line 24, in ModuleNotFoundError: No module named 'pyimod02_archive' Traceback (most recent call last): File "site-packages/PyInstaller/loader/pyiboot01_bootstrap.py", line 15, in ModuleNotFoundError: No module named 'pyimod03_importers' [5169] Failed to execute script pyiboot01_bootstrap ERROR: could not extract tar starting at offset 000000000000018891+9231072+2 ==> ERROR: A failure occurred in package(). Aborting... Error making: miniconda3
I tried to copy but couldn't so I posted a ss, and this is my first post on this forums.
Thank you sir.
