So I'm kinda new to keybinds I recently started using Manjaro BSPWM and its a little confusing, I've messed around with Dconf but that's about it. I would really like some help with setting up a shutdown keybind and possibly writing shell scripts/terminal commands that I could run via keybinds!
See what is the shutdown command in the menu config. Then see the file ~/.config/sxhkd/sxhkd.conf how key binding are defined there. Find an unused keybinding and make it perform the bsprc shutdown command in a similar way.
This is what I tried
#sleep
super + q
XF86Sleep
systemctl suspend
#sleep
super + q
systemctl suspend
Not working
Think I need to add some kind of command before
systemctl suspend
Sorry I'm really newbie and don't know how to figure this out
Have you run Super+Shift+Escape after saving changes to sxhkdrc? This reloads the settings.
BTW: I have
XF86Sleep
systemctl suspend
in my sxhkdrc.
proper indentation is required in the sxhkdrc file if you want your keybindings to work
Is indentation like the layout, I don't know much about this. Ill give it ago tomorrow. Pretty sure I followed the format correctly.
I have a feeling I need to add some extra code to get this working
