Help me get rid of these weird GUI bugs in Anki.
Anki has these weird GUI bugs that is making using the application very difficult. Without further ado let me show a screenshot which will make the issue immediately apparent:
Screenshot_2020-06-27_19-43-03
I do not experience these problems with other GTK/QT applications.
$ inxi -Fx
System:    Host: PC0 Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Xfce 4.14.2
           Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: N/A model: N/A serial: <root required> BIOS: American Megatrends v: 080015 date: 11/07/2013
CPU:       Topology: Dual Core model: Intel Core2 Duo E7400 bits: 64 type: MCP arch: Penryn rev: A L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 11173
           Speed: 1731 MHz min/max: N/A Core speeds (MHz): 1: 1731 2: 1748
Graphics:  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia v: 440.82 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82 direct render: Yes
Audio:     Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Sound Server: ALSA v: k5.6.16-1-MANJARO
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel port: e800 bus ID: 02:00.0
           IF: ens32 state: up speed: 100 Mbps duplex: full mac: 00:e0:4c:07:03:70
Drives:    Local Storage: total: 2.22 TiB used: 1.31 TiB (59.0%)
           ID-1: /dev/sda vendor: A-Data model: SP550 size: 111.79 GiB
           ID-2: /dev/sdb vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
           ID-3: /dev/sdc vendor: Western Digital model: WD3200AAJS-22L7A0 size: 298.09 GiB
Partition: ID-1: / size: 48.26 GiB used: 43.69 GiB (90.5%) fs: ext4 dev: /dev/sda3
           ID-2: swap-1 size: 3.91 GiB used: 61.0 MiB (1.5%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 51 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Info:      Processes: 203 Uptime: 20m Memory: 3.42 GiB used: 2.20 GiB (64.5%) Init: systemd Compilers: gcc: 10.1.0
           clang: 10.0.0 Shell: bash v: 5.0.17 inxi: 3.0.37
There are NO BUGS ! Go to the system settings and adjust Theme and fonts !!!!
True. I changed the "style" in "Appearance" app and now all those issue have gone away.
It is interesting that only anki has this problem but not other apps.
The issue came back. No combination of themes and fonts is doing the trick. In XFCE I see this issue but not in MATE.
It is tiring to switch to MATE whenever I want to use ANKI.
I hope there is a solution is to this.
The issues are caused by a low DPI value.
Solutions:
  1. Use default DPI. Appearance -> Fonts -> Custon DPI (Uncheck). (Recommended)
  2. Use higher DPI.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
