Hi, I am trying to packg the CoreApps to Flatpack, i am able to build the app and all are runs fine. But here are some issues i am facing.
the app saves the config files to var folder, i want them in real config folder in home. i added the "--filesystem=home", but nothing changed.
also i want access to the user/shear folder. how to do that.
basically i want the flatpack app to act like a native app, i don't want file system restrictions.
"app-id": "com.example.coregarage",
"branch": "master",
"build-options": {
"no-debuginfo": true,
"strip": true
"command": "coregarage",
"finish-args": [
"--share=ipc",
"--socket=x11",
"--socket=pulseaudio",
"--share=network",
"--socket=system-bus",
"--device=dri",
"--own-name=com.example.coregarage"
"modules": [
"name": "libcprime",
"no-autogen": true,
"no-make-install": false,
"no-parallel-make": false,
"sources": [
"branch": "master",
"type": "git",
"url": "file:///home/asd/Pictures/libcprime/"
"commands": [
"qmake PREFIX=/app libcprime.pro",
"make install"
"dest-filename": "configure",
"type": "script"
"name": "coregarage",
"build-options": {
"env": {
"LD_LIBRARY_PATH": "/usr/lib/"
"no-autogen": true,
"sources": [
"branch": "master",
"type": "git",
"url": "file:///home/asd/Pictures/coregarage/"
"commands": [
"qmake -config release PREFIX=/app \"LIBS+=-L/app/lib -lcprime\" coregarage.pro",
"make install"
"type": "script"
"runtime": "org.kde.Platform",
"runtime-version": "5.12",
"sdk": "org.kde.Sdk",
"separate-locales": false
