hi im noobie need help with GPU driver
now i get this
OpenGL vendor string: nouveau
OpenGL renderer string: NV126
OpenGL core profile version string: 4.3 (Core Profile) Mesa 20.0.7
OpenGL core profile shading language version string: 4.30
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.3 (Compatibility Profile) Mesa 20.0.7
OpenGL shading language version string: 4.30
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.0.7
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
and its same thing nothing changed
Try rebooting your system, then enter the command in your terminal again to see if the OpenGL vendor string text got changed to NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 960/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 440.82
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL version string: 4.6.0 NVIDIA 440.82
OpenGL shading language version string: 4.60 NVIDIA
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 440.82
ok its change :slight_smile: i was thinking I dont need reboot system :slight_smile:
let me check if game works good :?
Awesome! It appears that you're now using the more reliable proprietary drivers because of this:
thank you :slight_smile: i guess i havent (Click on Auto Install Proprietary Driver)
related to replay above :stuck_out_tongue:
:slight_smile: and i found some mapping to midi numark total control so i want play a lot any way but its nice to have a working all as its should :slight_smile:
You're very welcome. Again, welcome to the Manjaro community! :slight_smile:
thats why I have change system (windows)ER00 00003x00004155..
(Linux) --help :slight_smile:
i get something like help hope and understanding :slight_smile:
:100:
4 posts were split to a new topic: setting gpu driver
