Hibernation with kernel lockdown on luks+lvm swap
For three years now I've been using systemd-logind to handle idle and automatic hibernation. All worked well with my partition layout:
| PART1: /boot/efi   | PART2: luks1            |
|                    | LVM1:  /   | LVM2: SWAP |
The system was using secure boot with the luks key within the encrypted initramfs (grub ask for the password). All went well and hibernation was working.
Since I updated to new LTS kernel and enabled the lockdown integrity feature, my hibernation isn't working anymore.
I've got these message in my logs:
Lockdown: swapper/0: hibernation is restricted; see kernel_lockdown.7
Lockdown: init: hibernation is restricted; see kernel_lockdown.7
Lockdown: systemd-logind: hibernation is restricted; see kernel_lockdown.7
I've checked what I've found online about it (because it seem man doesn't have a manpage for that specific entry).
https://www.mankier.com/7/kernel_lockdown
The only thing I've found is about the security of the swap partiton:
Unencrypted hibernation/suspend to swap are disallowed as the kernel image is saved to a medium that can then be accessed.
But my swap partition is encrypted so I don't see why it's not working. When systemd-logind try to put the system into hibernation, I've the last message (see above in the logs) before the system is shutdown.
Any advices ?
