hot corners for manjaro LXQT
hi, i'm testing Manjaro LXQT and i'm very pleased with it, actually i'm using Manjaro Cinnamon and i want switch but LXQT don't has hot corners, is possible get it in lxqt?
LXQt is build with the Openbox window manager.
You can build the AUR package brightside to have hot corners. (fixed spelling - the link is the correct spelling)
You could change window manager e.g. kwin
i builded brigthside, that tool is comand line?, i cant see it anywhere , and if i write : " sudo brigthside " only get errors
Spelling?..
BRIGHTSIDE
sorry, english is not my main language and i'm not using a traduction service,
edit: your say spelling in terminal? , yes i'm wrote BRIGHTSIDE correctly, here i dont used copy past hehe xD
sudo brigthside will give errors.
sudo brightside may not give errors.
i'm checked that and was wrote correctly, maybe the problem is in the past i switched a couple times between openbox and kwin and change linux kernel to 4.19, i will go to reinstall
Are you sure sudo brightside is the correct command?
no hehe XD, i never seen brightside before, searching for google i see a gui named : "screen actions", but i cant found after Build brightside, and in the package manager dont exists button "launch" for that, too i cant found in google commands for use brightside, for that i supossed is sudo brightside
I hate hot corners - so I have no experience of the actual usage - just knowing it exist.
But brightside is a user tool
just run
 brightside-properties
and add brightside to your autorun
ah! that works perfectly , thanks
