Hi guys. I got a few issues on my video card and I'm booting with nomodeset. I wanna change my screen resolution because I got only 800x600.
Maybe change in /etc/default/grub ,( 'videoinfo' in grub).
# you can see them in real GRUB with the command `vbeinfo' must be videoinfo
GRUB_GFXMODE="1280x1024,auto"
then
$ sudo update-grub
But .. honestly .. whats the point ?
'nomodeset' should just be a way for you to boot and more easily configure things properly so that nomodeset is no longer required (and then the resolution thing becomes a non-issue)
I can only boot with 1280x1024? I need 1920x1080.
When I'm booting my system without "Nomodeset" then I get a problem. I see No Signal on my monitor. I tried my things but no one is doesn't worked.
Did you not read my response?
I am sorry things are not working 'automatically' for you .. but 'nomodeset' is just a way for you to boot so you can fix those problems.. you should not just be running a 'nomodeset' system all day every day.
Maybe this is a case of 'asking the wrong questions'.
..so .. maybe your graphics/drivers are not configured well .. so maybe you start with something like
inxi -Fxxxza --no-host
[report output using the </>
code button .. and people might be able to help fix the real problem]
Kernel: 4.19.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
Desktop: KDE Plasma 5.15.2 tk: Qt 5.12.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Gigabyte model: F2A68HM-DS2 v: x.x serial: <filter>
UEFI: American Megatrends v: FE date: 10/09/2018
Topology: Quad Core model: AMD Athlon X4 860K bits: 64 type: MCP
arch: Steamroller family: 15 (21) model-id: 30 (48) stepping: 1
microcode: 6003106 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 29558
Speed: 2802 MHz min/max: 1700/3700 MHz boost: enabled
Core speeds (MHz): 1: 2777 2: 2577 3: 2602 4: 2519
Vulnerabilities: Type: l1tf status: Not affected
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Turks PRO [Radeon HD 6570/7570/8550]
vendor: Hightech Information System driver: radeon v: kernel
bus ID: 01:00.0 chip ID: 1002:6759
Display: x11 server: X.Org 1.20.4 driver: radeon FAILED: ati
unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 4.19.28-1-MANJARO LLVM 7.0.1)
v: 3.3 Mesa 18.3.4 compat-v: 3.1 direct render: Yes
Device-1: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1022:780d
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: Hightech Information System driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 1002:aa90
Device-3: Kingston type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-1:2 chip ID: 0951:16a4 serial: <filter>
Sound Server: ALSA v: k4.19.28-1-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 938.98 GiB used: 5.09 GiB (0.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1CH162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC49
scheme: GPT
ID-2: /dev/sdb type: USB model: USB DISK 2.0 size: 7.46 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw size: N/A size: 5.85 GiB used: 157.1 MiB (2.6%) fs: overlay
source: ERR-102
System Temperatures: cpu: 51.6 C mobo: N/A gpu: radeon temp: 67 C
Processes: 193 Uptime: 9m Memory: 7.80 GiB used: 1.78 GiB (22.9%)
Init: systemd v: 241 Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0
running in: konsole inxi: 3.0.32
Did you install the vesa driver ?
But your system Xorg has 1080p.
If you mean grub menu screen, you can't always have it. It's configured as @sgs advice, but you have to find if your monitor can have what you set.
Check Archwiki on grub.
I'm talking about normal screen resolution, not grub menu.
Then explain this (is it an old report?):
I do but I get black screen after the install.
This without "Nomodeset" boot report. When I'm trying boot normal then I'm getting "No signal" on my screen.
Please post
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
What have you tried already?
Start again (I suggest). Because
- Boot without
nomodeset
- If you get to GUI, post logs (
journalctl -p -3
and xorg log ) - If not, reboot and post logs from previous boot
How to change video drivers or configuration and troubleshoot
How to provide information about your issues
