How do I get my bcm4360 to work?
Finally downloaded Manjaro only to find out my WiFi is nonexistent. I have a TP-Link AC1300, Archer T6E WiFi adapter that plugs into the motherboard. (I just made the PC myself) Anyways, I cant use the disk it comes with to install the drivers because I dont think it works on Linux and I've surfed the web for drivers but I cant find any to get my WiFi to work. Currently I'm just using my phone as a hotspot. Any help is appreciated please...
Try to make a good picture of the output of
inxi -Fxxxz
It looks like it's a Broadcom chip inside.
https://wikidevi.com/wiki/TP-LINK_Archer_T6E
I don't see the driver in the repos. @Wollie Maybe you'll have better luck?
Broadcom 4352 supposedly.
Oh revision chip 4360
poop Is this good... btw Im an absolute noob at linux.
Oh ya I tried downloading that but when its unzipped or whatever its just a bunch of files I have no idea what they are.
Yeah, you need to pkgbuild it to work right.
It should be in the repos. Looking now.
Wait, first. Type mhwd -la See if it's listed there. Probably not but never know. Or take a pic and we'll look.
If not, try this?
sudo pacman -S broadcom-wl-dkms
What am I looking for in the listpoop2
It's LA but little letters. :wink:
Is it that 8th line?
Just type mhwd -la (LA)
poop3
Broadcom chip will be tough to get it running, newest fastest AC cards don’t have great Linux support yet. How you connect to the hotspot?
Type mhwd -i --pci network-broadcom-wl
Through data on an IPhone
I see.
poop4
Ok, uh... mhwd -i network-broadcom-wl ?
poop5
sudo mhwd -i network-broadcom-wl
Eventually I'll get it. Grrr
